new shoes on, but there is a clicking noise
Old Feb 5, 2006 | 12:47 AM
eddie081's Avatar
I just test fit my wheels on my C203, anyways the rear has a clicking noise is the lugs too long?
Old Feb 5, 2006 | 12:56 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
if it's coming from the rear, it sounds like the lugs are rubbing against the e-brake... be careful or else you may damage the e-brake.
Old Feb 5, 2006 | 01:06 AM
eddie081's Avatar
Ok, what size are you all using?
I just drive it in and out of the drive way, so I think it's still okay
Old Feb 5, 2006 | 01:08 AM
SEXSPHERE's Avatar
//WALD C320 Magnifique [sold], BMW Z4 3.0i 6spd[sold]
I got the same problem last time with my brabus rims, offset was 35 and it was 18 inch. Used it for almost 3 months, no problem with my ebrake, but dont risk it. Just buy shorter lugs and it will be fine.
Old Feb 5, 2006 | 01:09 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
12x1.50 32mm shank
Old Feb 5, 2006 | 01:16 AM
eddie081's Avatar
Originally Posted by FrankW
12x1.50 32mm shank
I have +35mm on the rears, I think I am using 12x1.5 24mm or 27mm, should I go with the 23mm?
Thanks guys, I just want to drive may car , still waiting for my Teins
Old Feb 5, 2006 | 07:22 PM
SEXSPHERE's Avatar
eddie pls post some pics of ur car. Really want to know how those wheels look in ur car
Old Feb 5, 2006 | 07:39 PM
eddie081's Avatar
I will have to take some pictures, get them up ASAP. Anyone watching Superbowl?
Ed
Old Feb 5, 2006 | 08:19 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
just go with the shortest bolts possible that still allows you to have 4-5 turns.
Old Feb 6, 2006 | 03:23 AM
eddie081's Avatar
Cool thanks Frank, so as long as it has 4-5 full turns then I am fine?
Ed
Old Feb 6, 2006 | 03:39 AM
DACHIGGA's Avatar
2002 CL203
Ed
BTW, shouldn't it be 6-7 turns? That's what I hear.
Old Feb 6, 2006 | 02:18 PM
eddie081's Avatar
6-7 turns? I am not sure, but if it hits then I think I will just have to torque the shorter ones more
Old Feb 6, 2006 | 02:55 PM
xxbenzc230kxx's Avatar
is not yet completed
post some pics man... yeh i had the same problem .. i just changed out the bolts to sumthing a lil shorter.. and after that its fine... im not sure wat length bolt i used tho..
Old Feb 6, 2006 | 04:01 PM
eddie081's Avatar
I just order some 23mm bolts, they are the shortest I found. I got the wheels off but once I put them back on I will have pictures
Ed
Old Feb 7, 2006 | 12:38 AM
white_w203's Avatar
is SOLD
you could also cut the bolt shorter, but make sure not to mess up the thread pitch
Old Feb 7, 2006 | 04:04 PM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
This is a common problem when trading for aftermarket wheels. Shorter lugs will take care of the problem. Unfortunately, I learned the hard way. I'm glad that you've gotten this taken care of.
Old Feb 8, 2006 | 04:47 AM
eddie081's Avatar
Thanks guys, I am waiting of the shorter lugs, once I get them on again I will take lots of pictures
I am looking at getting a HU but I have no idea what works and what don't
Ed
Old Feb 8, 2006 | 09:29 AM
jpog's Avatar
2014 E350 Sport, 2015 ML350 4Matic
My shop wouldn't give me the car unless they could get 6 turns. Be careful.
JPOG
Old Feb 8, 2006 | 09:41 PM
eddie081's Avatar
JPOG
Safty first, I will see how many turns the new bolts will turn, but I really have no choice
Old Mar 13, 2006 | 01:18 AM
SEXSPHERE's Avatar
Have you guys figured out which size of bolt is the correct one?? I might be having the same problem soon i got my wheels installed. thxx
Old Mar 13, 2006 | 02:16 AM
eddie081's Avatar
Yes, I use the 23mm ones
Good Luck
Old Mar 13, 2006 | 12:45 PM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Good Luck
Where are those pics???????? Currently shopping for new rims and would like to see yours!!!
Old Mar 13, 2006 | 03:52 PM
SEXSPHERE's Avatar
Good Luck
Did you change everything or just the rear? So this is the correct size right 12x1.5 23mm? Also how many turns? Thanks
