Help on shift knob install
#51
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
bone stock E55 AMG
BRABUS Illuminated Shift Knob Installed
just installed brabus shift knob today.
light works great.
however, when i move the gear from P to D, the top part of the leather boot stretches all the way and it's actually bit short.
when the gear is in neutral, reverse and park, it's fine.
i already tried several times and every time with same result.
any suggestions?
light works great.
any suggestions?
#53
BMW 135i
LUcky you wheni orderd my brabus shift knob for my 2005 6speed coupe IT DID NOT FIT , and i sent it back.. just found out afew days ago its becouse the 6spd on my coupe is a short sifter
#61
Super Moderator Alumni
Removing an Auto Shifter Knob w/boot?
I just finished a search of the W203 forums on removing a shifter knob in a 2002 W203, with limited success.
I am hoping for more details than were in previous threads to replace my chipped shifter knob with a sweet carbon fiber aftermarket knob.
My 02 C32 has the leather boot around the auto shift lever. I managed to remove the chrome ring and shift indicator assembly. I even got the lower plastic retainer ring off by twisting it clockwise. Now I'm stuck. The knob does not budge. I appears to have a conicle shaped, plastic "tightening" nut now holding the boot and knob in place. Any ideas on how this nut comes out? It is too tight to finger-loosen and to cone shaped to grab with a tool.
Thanks,
Scott
Thanks,
Scott
#63
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
This is the best shift knob removal thread:
https://mbworld.org/forums/showthrea...ove+shift+knob
Sounds like you got the first few steps, just need to twist it to get it out. Takes a little elbow grease, from what I remember, but once you twist the knob off the latch, it should come right out.
#65
Originally Posted by FrankW
you already did all you need to do. only thing left is twist and pull.
After I pulled the knob straight up and off, I had to pinch in the clips at the bottom of the next retainer to release the knob from the boot. Worked perfectly. I did not have to demolish the chipped OEM knob and did not have to cut the leather to reuse the boot.
#66
Originally Posted by ScottW911
Thanks guys. I can't believe it was that easy. I thought I was going to need a special tool to get it the rest of the way.
Glad you were able to get it done. Any pics of the new shifter?
#67
![Help on shift knob install-dscf0069.jpg](https://mbworld.org/forums/attachments/c-class-w203/86138d1468963534t-help-shift-knob-install-dscf0069.jpg)
#68
Thanks. I am a little dissapointed that the new knob sits lower on the shifter itself. It causes the boot to bunch up at the bottom. I'm going to have to find a way to shorten the leather up. Take a look. It is hard to tell in the photos, but the knob is carbon aft, chrome forward. Matches better in person with the console in the C32 AMG, with its faux carbon, than in the photo.
Attachment 86138
Attachment 86138
#70
Originally Posted by rlee02135
i have that shift knob ![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
This new one is great.
#71
2004 C32 ///AMG
It sure has a much nicer feel to it than the original. I think that, in 2002, AMG just glued a plastic overlay onto a stock C-class knob. The overlay sat higher than the leather surrounding it on the knob itself. This led to discomfort and chipping of the C32 logo overlay.
#73
2002 C230 coupe
Thanks to this thread I now have installed my old shift knob from my previous car, never thought it would fit since it was off a honda. Looks just like Scotts but instead of the chrome part mine is black. Looks amazing and feels alot better than the factory knob.
#74
2004 C32 ///AMG
Originally Posted by italn
great info on here!!
ANyone have any good sites to browse for shift knobs.
Thanks for all the info deff going to be using it.
you got the projector fogs? how do you like them?
do they remind you of star wars?
#75
