Panoramic Moonroof popping noise
Old Apr 9, 2006 | 10:41 PM
famoussd's Avatar
2002 C230K
OK.. this just started happening yesterday. My moonroof opens up just fine, but when I go to close it.. it closes about halfway, then it starts making a popping noise (i.e. pop, pop, pop, pop) until fully closed.. I WD40'd the tracks but it's still doing it.. any insight as to what's going on? Thanks in advance..
Old Apr 11, 2006 | 01:57 AM
famoussd's Avatar
2002 C230K
anyone...?
Old Apr 11, 2006 | 01:59 AM
wtfpwn's Avatar
been having that problem, took it to the dealer over 10 times... All they did was greese the sunroof, and it would be gone for a couple days...
Mercedes seem to think greese will fix everything!
Old Apr 11, 2006 | 12:10 PM
famoussd's Avatar
2002 C230K
Question
I'd take my car to the dealer but my car is out of the regular warranty and in the extended warranty period.. which the moonroof isn't covered.. any other suggestions?
Old Apr 11, 2006 | 02:51 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
could you post pics of your panoramic moon roof... ive hardly ever seen these on a mb before... i just randomly saw it on a c class, i think..... i bet it looks great... sorry to change the subject
Old Apr 12, 2006 | 12:10 AM
fanito's Avatar
02' C230k Sport Coupe
have the same issue, not always I open the panoramic sunroof but yes pops like crazy
Old Apr 12, 2006 | 11:54 PM
moosejaw's Avatar
none
Extended warranty doesn;t cover the moonroof?
Old Apr 13, 2006 | 12:29 AM
alpinweiss's Avatar
2005 C230K Sport Sedan, 6 speed manual
I have never had any moonroof problems on my car......of course, it doesn't have a moonroof.
Seriously, a moonroof (sunroof, etc.) is an option that doesn't age gracefully. Go ahead and grease the mechanism and adjust as much as possible. This may put off the inevitable, which is replacing all the mechanical parts (gears, cables, etc.) in the moonroof. This is by no means cheap, but any other solution will only be a temporary band-aid.
Moonroofs (panoramic or not) are problematic on many cars that are a few years old. It is not normally covered by an extended warranty. Complaints are numerous.
Helpful hint: if you are buying a new car you plan to keep several years, consider buying one without a moonroof.
