SS brake questions???
Old May 10, 2006 | 06:55 PM
e1000's Avatar
a quarter mile at a time
Originally Posted by drexappeal
Anybody have a 2004.5/2005 C320 SS? I'd be curious to see if you have the 4 piston calipers also.
me too!
Old May 10, 2006 | 06:56 PM
rlee02135's Avatar
2004 C32 ///AMG
gaiex, I don't know if the AMG pads will fit on the 2005/2006 calipers. Did you try contacting one of the sponsors to see what they say? It's always a good source to go to when nobody else really has any confirmation.
just go to the dealership and buy pads. alot easier.
Old May 10, 2006 | 06:59 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
I know they aren't the same, I have a 2004.5 with 4 piston calipers and I bougth today pads for it and they don't fit in the brakes I bougth (2005 c230SS brakes)
Old May 10, 2006 | 07:01 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
I know Mick1 and BelletheBenz both have 2005 C320's... I tried looking at the pics of their cars, and they are indeed the same 2-pot calipers as the C230's...
I guess MB changed it up for 06 w/the 350's... I've also noticed the same brakes on the S500 and CLK500, so perhaps it is part of their marketing plan with the new more powerful non-AMG w203...
As for the pads, I know for a fact that the 2004.5 and 2005 do not share the same pads. Porterfield did not have the pads ready when I needed to change them on my 2005 and they told me that the pads were in fact different from the C32 AMG brakes.
Old May 10, 2006 | 07:25 PM
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
I was hoping you'd chime in at some point, dawg. You're the only one that I remembered off the top of my head that had to change the front pads.
BTW, 2004.5 and C32 pads are definitely the same size. My car is evidence. But that means that 2005 pads are definitely "unique".
So I guess this is what's been determined:
2004.5 230K SS/2006 350 - 4 piston Sport brakes
2005 230K SS/2005 320 SS/2006 230 - 2 piston Sport Brakes
Old May 10, 2006 | 08:32 PM
guhvies's Avatar
2017 C43 AMG Saloon
Just looked up a brochure I have for the C class from 2004. The sport sedans had and I quote "Enlarged perforated and internally ventilated front discs with 4-piston fixed-type calipers. Solid rear discs." The C32 had "Enlarged perforated and internally ventilated front discs with 4-piston fixed-type calipers. Ventilated rear discs with dual-piston fixed-type calipers." I didn't find anything on brake size though.
Old May 10, 2006 | 08:38 PM
  #32
drexappeal's Avatar
Yeah, that much had already been established. The debate is more with the size of the 2005 vs. the 2004.5 vs. AMG. nlpamg had said that 2 members on here have a 2005 320 SS and they didn't get 4 piston calipers. They have the 2 piston (just like the 230 K SS).
I have a 2004.5 myself, so I know that I have the 4 piston calipers up front (unlike earlier production 2004 models). The big difference on the C32 is the rear ventilated 2 piston brakes.
The strange part is that it seems the 2006 350 came with the same 4 piston caliper that was offered on the 2004.5 models.
Either way, gaiex is trying to find out if the C32 brake pads will fit on the 2005 C230K. So far, it looks like they won't (based on nlpamg's comments and 2 piston calipers developed for 2005 models).
Old May 10, 2006 | 08:44 PM
  #33
drexappeal's Avatar
Even more strange...
Brakes Dual-circuit power-assisted 4-wheel disc brakes. 13.6" perforated and internally ventilated front discs. 11.4" solid rear discs. Dual-piston fixed front and single-piston floating rear calipers.
^ This quote is from mbusa regarding the 350 SS.
e1000, did you do a swap?
Old May 10, 2006 | 08:45 PM
  #34
jan ken po's Avatar
'05 SS Brillant Silver
Wondered why a brake thread was so long....but I know I wasn't asked.
But to throw a wrench in the debate...'05 230 SS has 4 piston calipers
Old May 10, 2006 | 09:06 PM
  #35
drexappeal's Avatar
It's gotta be production date. Then again, how the heck does e1000 have the 4 piston calipers - unless he upgraded himself?
Old May 10, 2006 | 09:10 PM
  #36
jan ken po's Avatar
That's what I thinking and thought right after I read the thread. So I went out and look in my door pillar. Sadly, enough, first time I done it. Mine was built 04/04. So I thought, maybe they sold me a 4.5 thinking it was a '05. Checked my VIN # and it comes up as '05. So it HAS to be by production date.
Old May 10, 2006 | 09:18 PM
  #37
drexappeal's Avatar
Thing is, you'll know if you have an '05 for sure because you'll have the AMG body kit and no free service. Is that the case for you?
Old May 10, 2006 | 09:20 PM
  #38
jan ken po's Avatar
DAMN, you just HAD to go there didn't you.
Old May 10, 2006 | 09:54 PM
  #39
drexappeal's Avatar
Hey, well look on the bright side, you've got the AMG body kit, upgraded suspension (even from the 2004.5), changed interior, and you have the same brakes as the 2004.5 (4 piston).
That's not too bad a trade off.
Old May 10, 2006 | 10:28 PM
  #40
Mugen711's Avatar
my car was made 04/04 and purchased 06/04 and it has the 4 piston caliper like the 2004.5
I have a 05 C230
Old May 10, 2006 | 10:44 PM
  #41
TNblkc230wz's Avatar
C320 Coupe
The C32/C55/SLK32 all use the 13.6 inch rotors with four piston calipers. The 2004.5 SS sedans use a 12.8 inch rotor with four pistion caliper. The two piston caliper probably use a different pad than the four piston caliper. If you look at the two piston caliper closely, You don't see the slider pins that are in the top of the four piston calipers to keep the pads aligned. The comment about the brakes being limited by tire grip is true. I've tried it many times. The main advantage to the AMG brakes is fade resistance. Even the 11.8 stock brakes worked well. I would think the two piston calipers with 13.6 inch rotors would give a similar performance to the four piston calipers in most US driving situations
Old May 10, 2006 | 11:26 PM
  #42
e1000's Avatar
nope - haven't done a swap. other than the things in my sig, my car is stock
Old May 11, 2006 | 01:14 AM
  #43
patrick_y's Avatar
2006 E55 and 2002 E320
my understanding is that the 2005 C230Kss and 2006 C230 ss have 2 piston brakes in front.
Old May 11, 2006 | 04:16 AM
  #44
gaiex's Avatar
I have told it before, yesterday I bougth brake pads for my 2004.5 4 piston and they wont fit on the 2005 brakes I bougth for my coupe....
I just want to know the pads and rotors part # of the 2005 SS if someone knows, or if anyone want to share with me your VIN number so I can search for pads an rotors it would be wonderfull
PLEASE , someone with a 2005SS say me your VIN # by PM
PS: its beeing very difficult to find pads and rotors without a part # in the pads or the callipers I bougth, they don't have any part # on it, only MB and brembo on it and some other numbers not part #
Old May 11, 2006 | 07:02 AM
  #45
jan ken po's Avatar
Well as stated in this thread, that is not correct. My '05 has 4 piston.
Old May 11, 2006 | 07:20 AM
  #46
gaiex's Avatar
Do you have any pic or they are the same as some above?
If they are 4 pistons that is beacuse your car was produced before 2005 and it could be a 2004.5 model and not a 2005, I'm guessing...
Old May 11, 2006 | 07:29 AM
  #47
jan ken po's Avatar
They are same as the set in your "2nd pic". No I checked, it is branded as a 2005, was sold to me as a 2005, and has VIN that comes up 2005. The logical conclusion is that it is based on actual production date and not. actual model year.
Old May 11, 2006 | 07:41 AM
  #48
gaiex's Avatar
In a certain way, yes
Old May 11, 2006 | 07:46 AM
  #49
gaiex's Avatar
Check here: http://www.mbclub.ru/mb/vin/?lng=eng
Your car is a 2004.5, only cars produced after 6/2004 are 2005 models
Old May 11, 2006 | 08:41 AM
  #50
jan ken po's Avatar
Well put a call 2 dealers, 1 local, 1 in the ATL. Gave them VIN, they both responded it was an '05. I asked to see if it was a 4.5. Both said no, 05. Not sure what else to tell you. CARFAX has the VIN listed as '05.
