c230 2004 Coupe FIREWALL HOLE
Old May 30, 2006 | 11:16 PM
DiscoStatus's Avatar
2004 C-230 Kompressor coupe
I Need to get a hole through the firewall to get to my battery i want to install subs and maybe a cb radio... If people could tell me different ways to get through the firewall or if i have to drill a hole THANK YOU
-Chris
Old May 31, 2006 | 12:09 AM
electromethod's Avatar
Honda Grom
If you search the forum, your answer can be had.... with pics too!
Old May 31, 2006 | 01:30 AM
maybe i did and i couldnt find it so if you could get off your high horse and just throw some personal knowledge would be greatly appreciated.
Old May 31, 2006 | 06:47 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Is that a typo in your first post; cb radio? Did you mean cd radio?
If you tell us what search words you used we might be able to help you narrow it down.
Old May 31, 2006 | 08:22 AM
HoustonC230's Avatar
2010 C300
Come on... it's so much easier just to say STFF!
Anyway, there's a spot below and behind the battery. You can find it by looking under the dash on the passenger side... near the outside corner. For pics.. they've got to be around somewhere.
Old May 31, 2006 | 09:19 AM
MB Nubee's Avatar
2002 C240
I'll jump in on this since I just dealt with it. I did a search and found the first and second pic on a coupe. The third one is my car on the driver's side.
Hope this helps!
Attached Thumbnails c230 2004 Coupe FIREWALL HOLE-battery-area.jpg   c230 2004 Coupe FIREWALL HOLE-firewall-gromett.jpg   c230 2004 Coupe FIREWALL HOLE-firewall.jpg
Old May 31, 2006 | 12:14 PM
Thank you so much for the help makes it so much easier
Old May 31, 2006 | 12:18 PM
lol and yes i want a cb radio in my car i like to have the PA system in there so i can yell at people out of my car.
Old May 31, 2006 | 12:21 PM
MB Nubee's Avatar
2002 C240
Old May 21, 2017 | 10:05 PM
BrianDIY's Avatar
2005 C240, 2006 ML 350 AMG
Hi. I found this firewall access passage discussed above.. However, there seems to be a black rubber stopper that will not come out, blocking the only unused hole. A wire will feed approximately 1 inch in then hits backing... Is this an actual plug/blockage that must be removed or a just a tight fit? THANKS BIG!
