UGHHH...WTF is this leak? (pics inside)
Old Jun 18, 2006 | 10:48 PM
doramon1313's Avatar
Please tell me this is something small....
Old Jun 18, 2006 | 10:49 PM
advans's Avatar
C55 ///AMG, 535xi
thats ur V6 right!? oh man...whats that!? leme check tomorow if I have that!
Old Jun 18, 2006 | 11:00 PM
pookie's Avatar
2013 c300 4matic, 2002 c240
hmmm. Any weird noises/smells?
Old Jun 18, 2006 | 11:01 PM
i would say no and no...
Old Jun 18, 2006 | 11:08 PM
JP@CarLAB's Avatar
So you've got a Kleemann charger too? .
flip
Old Jun 18, 2006 | 11:12 PM
white_w203's Avatar
is SOLD
hopefully, its just a gasket
Old Jun 18, 2006 | 11:58 PM
EV0LVE's Avatar
F10
looks like coolant to me, if anything it should just be a gasket, better yet, you might just have to tighten the flanges.
Old Jun 19, 2006 | 12:24 AM
advans's Avatar
C55 ///AMG, 535xi
flip
lol no i didnt notice it...dam now i want one lol
Old Jun 19, 2006 | 02:33 AM
Tangerine's Avatar
Is @ Home
looks like coolant to me, but i dunno why its in the header area.
Old Jun 19, 2006 | 02:34 AM
Old Jun 19, 2006 | 05:36 AM
Moviela's Avatar
Looks like elephant booger to me. Keep your car away from elephants.
Clean off the smutz, and see if it returns. It is the color of antifreeze, but why would it be there? That tube is the output of a little coolant pump that is part of the Kleemann air to water intercooler. Since coolant is under pressure there, it might leak if a bit of corrosion gets started. Ask Kleeman what they use to seal the flange, and fix it. I have not taken one apart, but it might seal with nothing if it has a machined compression fit, or a sticky-goo gasket material, or a paper gasket, or even an o ring. Looks like an easy repair.
Old Jun 19, 2006 | 05:55 AM
robohopar's Avatar
2016 Mercedes S550
looks like your waterpump housing just get a new gasket and unscrew those screws(with correct tool or you will ruin the screw) and take whatever that needs to be taken off so you can properly clean the area(with a razor or a air grinder) and make it smooth of any objects and throw on a new gasket and tighten everything back up and your done after you put some coolant in there and bleed the system...<---sounds easier than done...but do-able
Old Jun 19, 2006 | 08:05 AM
SUNILP's Avatar
2015 E250D
its coolant. no biggie
Old Jun 19, 2006 | 08:30 AM
Brunelleschi's Avatar
In the market
I had the same problem. Evosport sells an elephant repellant pretty cheap that will take care of the problem in a hurry.
