WaveyKat Mods & questions
Old Nov 18, 2005 | 06:15 PM
  #151
WaveyKat's Avatar
Something Slow
i think my wheels have 32 offset and am 19x8.5 all around 235/35/19 tires
Old Nov 18, 2005 | 06:53 PM
  #152
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Hmmm...you should be fine. What suspension do you have again? If memory serves me right, you have TEIN's right?
Old Nov 18, 2005 | 08:44 PM
  #153
white_w203's Avatar
is SOLD
are you sure the wheel or tires are not rubbing against the strut??? you might be too low depending on the offset of your wheels. you might need a spacer.
Old Nov 18, 2005 | 09:20 PM
  #154
WaveyKat's Avatar
Something Slow
nah its not rubbing against the struts and yes i have tein coilovers ever since i put the wheels on ok so like if i yurn my wheel all the way to the left the the right Front whell will touch this panel and some for the other side is i turn the wheel all the way to the right .. so now when the car is in motions and i turn u will hear the tires rubbing against the panel
picutres of panel that the tires rub on below
Old Nov 18, 2005 | 09:26 PM
  #155
pshek's Avatar
2003 C-Class Sportcoupe
Originally Posted by nlpamg
yeah, well I'm not 100% sure it's rubbing as I don't really know what rubbing is per se. but when I take turns pretty damn fast, the I'll feel like a jerky sensation that is akin to when you go over a pothole, so I thought that that was rub...
thanks for the invite drex, I'm not sure I can make early as possible (esp. in el monte). but if you could let me know, I'm totally interested, and now I'm looking into vogtland springs.
Your car shouldn't be rubbing if you have stock suspension setup, except maybe with hard turning. You'll know when it rubs, especially if you lower your car with springs or coilovers and have an aggressive tire/rim offset. Screeech...
Old Nov 18, 2005 | 09:47 PM
  #156
r3v1ls's Avatar
C 230K Coupé
I remember someone in another post said to put some kind of white powder/paint on the wheels, and if it rubs it whould rub off onto the wheel wells. Then you will know for sure if it's rubbing or not.
Old Nov 18, 2005 | 10:25 PM
  #157
advans's Avatar
C55 ///AMG, 535xi
Mine fronts used to rub on hard corners with the stock 17's! I haven't done anything to my suspension, but the fronts still rub occasionally when I'm cornering hard.
I got the 17" double spoke AMGs, they're CLOSE CLOSE CLOSE enough to rub, i guess with a lil more PSI up front, it'd rub lol
Old Nov 19, 2005 | 07:45 AM
  #158
DC BENZO's Avatar
01 C200K | 02 CLK320 | 11 C250 Coupe (current)
I believe its the other way around...you put white chalk onto the inner-guard where you suspect that you are rubbing, then go for a drive. If the chalk has disappeared form where you put it on then you know it is definately rubbing.
Old Nov 19, 2005 | 10:30 AM
  #159
W0n6_3d4n's Avatar
C200K (w204)
Have u ever removed the inner guard?? Make sure the inner guard are mounted correctly.
Old Nov 19, 2005 | 01:56 PM
  #160
r3v1ls's Avatar
C 230K Coupé
Thx for correcting me Benzo. Least i got the concept right.
Oh and about the hard cornering and rubbing, i don't think that rubbing at all. This car has a lot of understeer so the front wheels are the firt 1s to lose traction. So the noise made during hardcornering is just the front wheels skidding a bit. I don't think the ESP comes on when this happens... dunno why though.
Old Nov 22, 2005 | 12:26 PM
  #161
WaveyKat's Avatar
Something Slow
it mostly rub on the driver side which i think is cause by the windshield water bottle sticks out a little thru the plastic lining showed in the picture
Old Nov 22, 2005 | 12:49 PM
  #162
appleguy's Avatar
2008 BMW 335i Convertible; SOLD*2004.5 C230 Sedan*SOLD
I just got some 18 x 8 and 18 x 9's installed on my C230K SS with no rubbing issues what so ever during sharp turns. I am running 235's in front and 265's in rear and everything is fine even with a full load of people in the car.
Like others said, it's all about the offsets of the rims.
Peace!
Old Nov 22, 2005 | 12:55 PM
  #163
drexappeal's Avatar
Peace!
Waveykat is running 19's, so if the offset is the same on your 18's vs. his 19's, it has to be more than just the offset. It could be the ride height, could be the shock settings, etc...There are so many factors that can contribute to rubbing.
Old Nov 22, 2005 | 12:58 PM
  #164
appleguy's Avatar
Very True... good point.
Old Nov 22, 2005 | 01:19 PM
  #165
ernster's Avatar
2016 E63s AMG
so lets say the offsets are 35 in the front and 37 in the rear running 235/35/19 in the front and 255/30/19 in the rear would there be any rubbing issue. Not to forget stock setup on everything else
Old Nov 22, 2005 | 01:53 PM
  #166
drexappeal's Avatar
I'm pretty sure the stock offset is 32 front, 36 rear. I can't remember exactly, so 35 F / 37 R is 3mm more in the front and 1 mm more in the rear, so the rear is closer to stock offset than the front. I don't know how much a difference the 3 mm's in the front would make.
Old Nov 22, 2005 | 01:59 PM
  #167
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Peace!
pics please!
Old Nov 22, 2005 | 10:02 PM
  #168
appleguy's Avatar
pics please!
Hey nlpamg... I will post some tomorrow... it's nothing great though...
I am too gunshy to post anything seeing all of the nice w203's here!
Old Nov 22, 2005 | 10:05 PM
  #169
nlpamg's Avatar
haha, whatever man. I'm sure it's hott. I love seeing everyone's w203! can't wait for the pics!
Old Nov 23, 2005 | 01:44 PM
  #170
appleguy's Avatar
OK, nlpamg, just for you... enjoy!
Old Nov 23, 2005 | 02:30 PM
  #171
nlpamg's Avatar
nice! I like!
is your suspension stock? it doesn't look like it from the pics...
Old Nov 23, 2005 | 02:46 PM
  #172
appleguy's Avatar
Hey nlpamg, yes the suspension is stock. I only have added the C55 wing and the 18" TSW's to the car. I thought about lowering it, but i have 2 kids that i have to cart around in sometimes and I didn't want to subject them to the rough ride.
Old Nov 23, 2005 | 03:03 PM
  #173
drexappeal's Avatar
Looks nice, appleguy. You've got nothing to be ashamed about at all!
Old Nov 23, 2005 | 03:04 PM
  #174
drexappeal's Avatar
nice! I like!
Phil, you can tell he's got stock suspension because even your car looks lower. My car would've looked exactly like that if I got my rims first.
Old Nov 23, 2005 | 04:18 PM
  #175
nlpamg's Avatar
haha, all good it looks good.
really? I couldn't tell from the pics. It's probably b/c the sidewalls of his tires are bigger... all g
appleguy, I totally understand. you probably don't want your kids sporting this shirt...
