03 Bi-Xenons for MY01 MY02 and MY03 C Class Sedan or Wagons.
i guess i'll post on here too.
1. would i need different connectors if i already have the xenon headlight?
2. will the auto leveling system work after replacement?
3. how does the Bi-xenon actually works? i'm assuming the two different xenon bulbs (high and low) use the same projector lens and the original halegen high beam will came on as well.
if someone can help answering, much appreciated.
Basically, you have one bulb. It is either shining direct and has a prism that shoots light off to the other opening. This prismatic conduit is normally shuttered. Pulling on brights opens the shutter... this is the old way.
New way, has the xenon bulb mounted over a servo that holds a small mirror which simply shines the light at a different angle.
There are typically still halogen bulbs onboard for flash to pass. This is also the reason why hibeam is not done by seperate bulb.. you see, xenon takes the better part of 5-7 seconds to get up to perfect light output and during the first 1 second is completely worthless (but fun to watch flare into life).
Aren't the W203 and CL203 headlights the same?
btw, he responded to the question in another thread:
The malfunction code for a faulty bulb does show but can easily be reprogrammed by the dealership. This faultcode only concerns the low beam because the high beam is still the same 55W bulb as before in combination with a switched over reflector for the Xenon bulb (bi Xenon).
I have shipped out a set to the states today and will ship out 2 other sets the first half of next week, so I presume all other possible questions to 2003 Bi Xenon headlights on pre 2003 W203s will be answered soon...
E_Corleone: The meet is scheduled for 9/21 or 9/22 in Edison, NJ. Feel free to come out!! A bunch of Benzsport and MBworld members are going to meet at a dealer there (where they will hopefully have a bbq, give away some stuff like hats and t-shirts, etc). It's only a 10 hour drive, right?
Quote from MBenzNL "The leftside 5-pin connector is the standard headlight connector, the right top 4-pin is to activate the levelling motors, the bottom 6-pin connector is for additional Xenon purpose (levelling) and is to be found on all Xenon equipped models but the headlights work perfectly without these being hooked up".
this pic is of the new Bi-Xenon assy from MBenzNL as well:
They're MB parts
Plus even if you swap the light assy yourself, they're MB parts - so what can they say ?
I don't see why the dealer wouldn't install them ?
They're MB parts
Also Federal regs require that all HID's have an auto-leveling system. Since the 2001's and 2002's don't have the wiring harness to use the auto-leveling devices built into the headlight assemblies, it is also illegal to install HID's from that standpoint.
