Has anyone replaced std brakelights with LED bulbs on the sedan or coupe?????
Pics ?
any problems ?
I heard the resistance is different and will cause a error message to pop up.
thanks
I had used LEDs before on my Impala and all I had to do to fix the problem was to change a Relay, but I coulnd't find one on the Benz
Since the LED bulbs draw such little current, our exclusive load equalizers are required for proper functioning with turn signal applications, as well as with vehicles equipped with a "Bulb Out" warning system.
Without the Load Equalizer, the "Bulb Out" system senses that a bulb has been burnt out (because of the low current draw), when in fact it has not. Without the Load Equalizer paired the turn signals, the system will flash the turn signal bulbs very rapidly, for the same reasons.
Generally you will need 2 Load Equalizers for your M-Class turn signals whether you are replacing 2 or 4 turn signal bulbs. Brake lights and parking/rear fog lamps do not require Load Equalizers on the ML as there is no "Bulb Out" circuit.
Installation simply involves attaching the load Equalizers with the quick connectors which are supplied, with one wire attaching to the positive and the other to the ground.
They can be found here for $5
I've heard 1157 for the brakelights (that's for the E)
Sylvania lists 7506 for the stoplight (brakelight)
Pocholin, how hard is it to install the LED?
I am wondering if we can also install the LED for the rear light (not the brake light)?
http://www.formymercedes.com/mb_resu...lacement+Bulbs
but I got this email from MYROADSTER:
Had a driver tell me that the brake lamps in the W203 do not face directly to the rear. He has the C230K however. At any rate, if they don't face straight back, they may not work very well, since they are directional by design.
Otherwise if you still want to order:
$38 for pair of 1156-Red
$10 for pair of Load Equalizers
$48
$ 4 Shipping
$52
2 LED Rear Turn Signals- $38.00
2 LED Front Turn Signals- $38.00
2 LED Brake Lights- $38.00
6 Load Equalizers- $30.00
All in all, the LED's will work if you buy the Load Equalizers....
and they look futzin' amazin'! a hell of a lot better than OEM!!!
On en E-class is quite easy, it uses 1157 and 7506, that means you are only going to have one with LED because there is no LED 7506
i have the LED's installed in my C320........All in all, the LED's will work if you buy the Load Equalizers....
i have the LED's installed in my C320, you need the load equalizer. because i asked Jerry if i really needed it, and he said that if i didnt buy the load equalizer, i would have error in my dash.... so i bought the equalizer.... All in all, the LED's will work if you buy the Load Equalizers....
Where did you put all your Load EQ??? He tried to explain to me how the Load EQ works but I didnt get it. Hopefully I'll know when I receive the product. I cant picture how the Load EQ can be connected to the wires/bulbs???
what's the advantage in installing LEDs other than lower power usage?
2. Durability - LEDs never burn out (unless you fry them by overloading, which never happens under normal conditions).
Viktorious...I just ordered a set of LED for brake lights from Jerry this afternoon. He told me the Load EQ will get pretty hot and we have to cover it with tapes. Thats the reason why I only ordered the brake lights (for now), cause I dont know where to put the Load EQ in the front turn signal area so that it wont burn the car!!!
Viktorious --
I ordered brake lites as well on 8-29 - have you looked at the tail lite assy ? I can't see how the load eq will tie in???
we'll see
quote "Brown is ground, Yellow connects to Brake Lamp"
this is the tail light assy removed.....new LED brake light at top.
Bagwell, did you just order the brake lights? Or with turn signals as well? On your first pic, I still cant see how the Load EQ will hook up, I hope I'll understand when I received it.
I ordered LED's for the brake lights only...turn signals might be cool too tho huh ?
don't bother - very disappointed here....!!!!
I'm sending mine back.
