DIY installation of AVIC & other aftermarket HU's for W203 (Warning! lots of images!)
#426
05 CLK500
if he says that he has to bypass the amp, would i need to buy an amp and subwoofer? would i be able to get just an amp or would i need both an amp and sub? sorry but im a newb at this stuff
#428
'04 Mars Red C230K Sport Coupe (not Coup-EH)
Amplifiers are used to amplify the line-level inputs that come from most audio devices to work with speakers and subwoofers. Most head units, such as the one you have, have built-in 200-watt amplifiers used for speakers, and line-level outputs if you want to use your own amplifier (for more kick) and line-level outputs for subwoofers, for which you will need a separate amplifier. To use the subwoofer that you already have (AFAIK the HK comes with a sub) will probably be too weak or not work at all, so I'd get a new one.
So, in summary, what you might need:
1. Nothing. You can use the built-in amp on the speakers and forgo attaching the subwoofer.
2. 1 Amp for the speakers only. The installer runs the line-level outputs to the amplifier, and from there to the speakers.
3. 2 Amps + a Subwoofer. 1 amp for the speakers, 1 amp for the sub, and the sub (plus a box to put it in) as well.
4. 1 amp + subwoofer. Use the amp built-in to the the head unit and have the installer run the subwoofer outputs on the HU to the amplifier, which is hooked up to the subwoofer.
#429
2007 C230/2007 A3 S-Line/2004 20g STi
I was told for my hk all the speakers need to be rewired by two different shops. One said I needed a new amp and new speakers.
I really want to get an avic d3 but i havent found a conclusive answer on what is really needed
#431
Looks like a great job you have done there with the dremel..I'm trying to locate a facia for an 05 and may have to go down your route. Can you take some better daylight pics ?
I want to fit a Z2, do you think it would be the same size as yours ?
Cheers
Adam
Cheers
Adam
#433
'06 C230 Silver (SOLD), '14 Black C250 Coupe, '16 Deep Ocean Blue Silverado
I don't know the exact name of it because I bought it on ebay and it came without a part number. But there are a bunch of different brands floating around out there on ebay and other sites (if you do a google search) that are designed for the 05+ for a single din HU. Right below the single din is a storage pocket (for change, sunglasses etc.). If you are handy with a dremel you can easily make the single din and storage pocket into one double din space. It took me about an hour to Dremel it out to get a perfect fit, and it its is perfect!!
It looks like Scosche makes a kit for a double din application. The part number is mz2347b. The info is on their site and looks like it sells for less than $30. A place in Valencia, Ca. has them in stock. I did a web search for "Scosche mz2347b" and found it.
#434
Hope this helps someone with a D3 install.
#435
Kenwood DNX7100 installed
but not working... I am so mad right now. As you can see, it looks pretty good already. However, during the power testing, the display wouldn't power up and the screen would only go down 1/2 way. Any one with experience on nav unit like this? I am hoping this unit isn't defective since it's just so painful to exchange anything online. Thanks ~
#439
u guys know of an audio place for bench testing? i need to get some paperwork from an audio place in order for me to get the unit exchanged. I am heading down to NYC and was pretty excited to have this in my ride. it's all over now... bad luck
#441
My single din premier had the same issue when I first installed it. There is a reset button hidden on it that I pushed and it fixed the issue. I found out about it after I called the manufacturer and they told me to reset it. Might want to google the model # and see if there is a reset for it. Good luck
#442
My single din premier had the same issue when I first installed it. There is a reset button hidden on it that I pushed and it fixed the issue. I found out about it after I called the manufacturer and they told me to reset it. Might want to google the model # and see if there is a reset for it. Good luck ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
#444
just talked to kenwood. "if it's not from us, we can't help you. contact your onilne store"
that's great. hopefully the online seller will exchange this fast
#447
so..I shipped the unit back and a new one should be coming my way by next week. It has to go through some testing by the store..waiting sux. so with nothing to do, I threw on a sub from my w202. it took me a good 3 hours (2.5 hours to run and hide wires) to work on the w203 because of it's front battery and no folding rear seats. it's all good though, it came out pretty nice.
#448
Finally. my system is up and running. this unit is just GOOD, i can run my nav (hdd based), watch dvd/vcd and listen to my mp3 through the usb port all at the same time.
![](http://x9b.xanga.com/343d8b1751533145968651/b108207021.jpg)
![](http://xa4.xanga.com/15ac32e250c35145968649/b108207020.jpg)
![](http://x94.xanga.com/931c351067d34145968658/b108207028.jpg)
![](http://x01.xanga.com/04bc311047d35145968657/b108207027.jpg)
#449
2003 Silver C320
Looks nice, did you have Bose D2b in your car before?
I want to put one of those in my car except I heard many stories about aftermarket HU will not work with D2B systems. so.....
