DIY installation of AVIC & other aftermarket HU's for W203 (Warning! lots of images!)
Seller does "but it now" auctions only and is from Portugal so I guess it's the same person most people buy from?
The SWC was $130 and shipping was $10.
The seller's username is worldwide-sounds.
Hahaha...
I'll keep you updated if I find out first, if not let me know if you find out.
am going to be replacing my doors speakers and adding a 4 channel amp to power them. i will be loosing the Bose sub that is in the Rear deck and my center Speaker.
i will have to get 3 pairs of RCA wires that will connect from the D3 that runs to the rear of the car. 2 of the RCA wires will be for the Front & Rear Door Speakers and the third will be for my JL audio Subwoofer & Amp the 2 rca for the front & rear doors will be plug into a 4 channel amp then the wires from the amp will tap into the wires from the bose amp for the doors and tweeters see attach pictures for the wires from the bose amp!
this a picture of the Wires from the bose AMP taken with my crappy MDA phone these should be the wires that runs to each speaker in the car
this is where the installer tap the wires to too hook up my JL audio sub he add a 2 Line convert here then run the wires to JL audio 250/1 Amp that powers the sub.
I've bypassed the system, connected the Metra harness to the AVIC harness, and that's pretty much it for now. Just waiting for everything else to come in, then I'll figure out what to do with the remaining factory plug, one of the silver connectors, and the VSS wire along with the reverse gear signal.
Im in the same boat. My D3 should be here today, and I have the harness already, just waiting on the mbk100c kit. I dont think i'll worry about my vss and reverse untill I purchase the Carpi wheel interphase, xm reciever, and backup camera.
Also does anyone know if the Pioneer CDX-P680 Can Fit into the factory Glove Box?
The CDX-P680 is 2 5/8" tall, so get out the measuring tape and see how much height your glovebox upper compartment allows.
So i Tap into the cigarette lighter found the 12V in my car it was the yellow wire with a black strip so that Avic D3 will be able to get power and also turn off automatically when u remove the key from the ignition.. my question::.... IS there away to have power to the Avic D3 even if the Key is not in the ignition like my factory comand works with or without the keys in the ignition does anyone know?
i will also ask this question here
