Pulleyed W203, what spark plug to run
Old Nov 13, 2006 | 02:22 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Ok, I'm running Champion Cooper that is a colder plug than stock, and I am looking to get a longer life plug.
What do you guys like?
E
Old Nov 13, 2006 | 06:42 PM
CarLAB's Avatar
E
Have you tried NGK Iridium.
Regards
Darwin W
Old Nov 13, 2006 | 07:33 PM
WaveyKat's Avatar
Something Slow
Denso Plugs & Magnecor Wires
Old Nov 13, 2006 | 07:46 PM
Tony Berry's Avatar
2009 Corvette Z06
I thought a pullied W203 got you nothing? Something about the car's ECU compensating for the extra boost as a "safety" measure?
Does a pullied 1.8 give a noticeable increase? If so, maybe I'll look into it again.
Thanks.
Old Nov 13, 2006 | 08:02 PM
SeaCoupe's Avatar
Thanks.
Tony, you need to notice that I have the 2.3L engine that came in 2002.
For the plugs, what is the model number of the plug. Any problems with pre-ignition, or pinging?
Darwin, thanks for the input. I'm sure you have seen quite a few pullied cars.
E
Old Nov 13, 2006 | 08:10 PM
mig888's Avatar
EVE
Thanks.
I can give you a solid YES on that one. For those who jumped into my car, they say night and day feel . I used IK20s...I believe.
flip
Old Nov 13, 2006 | 09:31 PM
advans's Avatar
C55 ///AMG, 535xi
are the Bosch Fusion ones good?
Old Nov 13, 2006 | 10:08 PM
SeaCoupe's Avatar
Regards
Darwin W
Darwin;
Do you know what number I should ask for. After searching on different forums it seems that a 5 or 7 would work. The IX plug gapped to say .035.
I think this is the 7EIX plug right?
So, would these get me say 40-50k miles?
I'm hoping to source these tomorrow and install. I'm getting an odd hesistation under constant load of about 2,300 rpms. Seems like the car is pulling timing. I hope it is not the MAS.
E
Old Nov 13, 2006 | 10:59 PM
advans's Avatar
C55 ///AMG, 535xi
Thinking about it, my car has about 36k miles. its about time to change my sparks. this thread might be helpful to me also!
Old Nov 13, 2006 | 11:05 PM
OJwerks's Avatar
not stock.
Cool
I believe your car is a 320??? If it is, than go the same route I went.....
Magnecor 8.5mm racing wires & Iridium IK16s spark plugs, the car will run 10x smoother and have a more punchy feel to it, which you will get used to after a while.... Im not sure how long this setup will last though since ive only put about 4K miles into it.
Old Nov 13, 2006 | 11:38 PM
CarLAB's Avatar
Darwin;
E
E,
5EIX for your car (M111). You dont gap an iridium plug. You should be able to get it at a local autoshop. They are very easy to find.
Regards
Darwin W
Old Nov 14, 2006 | 12:53 PM
SeaCoupe's Avatar
Man, the plug is not the easiest to actually find. At least not at the Ghetto Kragen and Autozones in Gardena.
Guess I'll keep looking.
E
Old Nov 14, 2006 | 05:48 PM
OJwerks's Avatar
not stock.
Cool
try online...performance websites, etc, I had the same problem you did, or you have to go to a local performance shop.
Old Feb 26, 2007 | 02:18 PM
Totalfixation's Avatar
ask advans was asking did anyone try this yet? was thinking of getting them for my E430
Old Feb 26, 2007 | 03:15 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
BCPR7EIX-11
NGK Iridium.
2 steps colder for pullied M111.
You can order them or buy them online for about 5 bucks a piece.
.04 gap.
I got mine at Winchester Auto. And yeh, they'll last 40-50K at least.
Old Feb 26, 2007 | 07:11 PM
sdsilverm3's Avatar
If boost has increased over stock then go with an NGK "7" heat range or the Denso equivalent of IK22. Better safe than sorry. Iridiums worked great for me in the past on my two turbo Integra's so I would definitely recommend them.
The downside of running too cold of a plug is a less smooth running motor at idle and part throttle conditions which is minor considering the downside of running too hot of a plug may cost you your motor.
If you need to gap iridiums do not use the standard gapper that you jam into the opening. You'll need a gapper that bends the arm open or closed. Mac tools sells one for < $15.
Old Feb 27, 2007 | 12:15 AM
Moviela's Avatar
Gapping tips for space age iridium plugs:
http://www.densoiridium.com/installationguide.php
