Brakes skip/studder when I'm breaking hard...
Old 11-20-2006, 07:41 PM
doramon1313's Avatar
Ok, so lately if I'm boning out and need to stop quick and I step on the pedal kinda hard I can feel the pads "skip" on the rotor. I actually don't really know how to describe it, but any of you guys have this problem?
Old 11-20-2006, 07:44 PM
rlee02135's Avatar
2004 C32 ///AMG
this will solve your problem
Old 11-20-2006, 07:47 PM
yes, yes they would, but it'll make my rear brakes look puny....
Old 11-20-2006, 09:53 PM
Moviela's Avatar
Are your tires worn to less than 3/32"? Your "groove" might be about to loose traction and the anti-lock system is kicking in to minimize braking distance.
Old 11-20-2006, 10:03 PM
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Sounds like the ABS.
Old 11-20-2006, 10:21 PM
Buellwinkle's Avatar
ABS and also Brake Assist both feel weird when they activate. Just letting the computer do the job it feels you are not able to handle on your own, haha...
Old 11-21-2006, 12:03 AM
white_w203's Avatar
is SOLD
unless you feel it at regular driving then your rotors could be warped.
Old 11-21-2006, 01:47 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
I agree.
Old 11-21-2006, 12:37 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
is it the brakes or front end? Like when you hit the brakes, does the front end shudder? Feel it through the brake pedal? If so, your front rotors may be warped. Have them checked out.
If your brake pedal is pulsating, then its ABS.
Old 11-21-2006, 12:40 PM
awww, what I've feared, i think the rotors are warped...
Old 11-21-2006, 12:44 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
still under warranty? dealer might cover it if it is. if not, might as well upgrade the rotors if they're getting replaced
Old 11-21-2006, 12:46 PM
SFoRZA's Avatar
C32 AMG 2002
make sure your lugs are torqued correctly...probably not it, but worth a check.
I thought i had a warped rotor and found 3 lugs almost falling out!
Old 11-21-2006, 02:15 PM
mleskovar's Avatar
'17 Jaguar XF
How are your pads and rotors wearing? Does it give you feedback through the pedal or steering wheel? You should limit your 'boning out' to the bedroom.
Old 11-21-2006, 03:09 PM
i got brembo cross drilled with my c32 kit....
Old 11-21-2006, 03:11 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
very nice...then time to get those rotors checked out
Quick Reply: Brakes skip/studder when I'm breaking hard...
