Check Engine! Grrrrrrrrrr
Old Dec 13, 2006 | 01:36 AM
fanito's Avatar
02' C230k Sport Coupe
Angry Check Engine! Grrrrrrrrrr
Like if I haven't had enough already...
So I was accelerating, actually quite strong from a stop position (0) to what I can think was somewhere around 65~70mph. Of course it was quite hard (I mean, still within the revs) and after I hit that mark I let go of the gas and the check engine lit up
Methinks it could be a sensor only but I really don't know jack about cars. There are no malfunctions though. Is that normal? I've accelerated the car like that before and everything is good.
FYI: I have a C230 2002 Coupe Automatic.
Old Dec 13, 2006 | 01:37 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
is it check engine or the esp??
Old Dec 13, 2006 | 01:41 AM
fanito's Avatar
Check Engine only.... I'm sooooo upset
Is not giving any other errors....
Old Dec 13, 2006 | 01:47 PM
14cue's Avatar
05 C55
why are you so upset? cool down and bring it in. it happens to everyone. there isnt much else you can do. like you said, you dont know "jack about cars".
Old Dec 13, 2006 | 01:54 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Either take it to Autozone for a free reading or get a code reader for $80-120. Since it's a Mercedes, it might be worth it to go ahead and buy one - it'll get enough use.
Then get the code, so at least you'll know what the problem is. And your dealer wouldn't be able to tell you differently. Also, if you clear it, there's always the chance that it'll not come back, and it was a one-time blip.
Old Dec 13, 2006 | 02:15 PM
mleskovar's Avatar
'17 Jaguar XF
X2
Old Dec 13, 2006 | 04:54 PM
SHOCKTRUPPEN's Avatar
03-C230 KOMPRESSOR-96-E-320 (DA WIFE)
Talking Check Engine Light
BEEN IN THE PAST WHEN HARD STOPPING THE FLUID SENSORS THINK THEY ARE DRY FROM HARD DECELERATION. IE: POWER STEERING RESEVOIR' BRAKE FLUID RESOVOIR<----FRENCH FOR HOLDER , ENGINE OIL LEVEL, WIPER FLUID SLOSHING, ANTIFREEZE SLOSHING ETC. BTW, MY KID HAD CHECK ENGINE LIGHT COME ON, TAKEN TO DEALERSHIP. UNDER WARRANTY THEY CLEANED THE INJECTORS, CHANGED THE SPARK PLUGS, CHANGED THE OIL AND OIL FILTER, CHANGED COMPUTER CHIP, CHANGED O'2 SENSOR, CHANGED ELECTRONIC CHIP THIS AND THAT $1000. LATER OF UNDER WARRANTY TROUBLE SHOOTING.... TURNS OUT MY KID HAD A SUBWOOFER SUPER DOOPER THING INSTALLED IN THE REAR OF HIS 2003 KOMPRSSOR BY BEST BUYS AND THEY RAN A SCREW THROUGH THE GAS TANK. I.E. CHECK ENGINE LIGHT. NEW GAS TANK THANK YOU BEST BUYS AND THANK YOU FOR ALL NEW PARTS NAD SUPER DUPER TUNE UP FOR FREE!!!!! TEE HEE HEEE TEE HEE HEEE
Old Dec 13, 2006 | 04:59 PM
sirenebekim's Avatar
when my check engine light went on with no malfunctions, it was the mass air meter.. clean that and see if it goes away
Old Dec 13, 2006 | 07:08 PM
valdes's Avatar
05 C55, 01 C240, 00 Discovery
That works sometimes it was an issue on mine
Old Dec 13, 2006 | 07:51 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
I tend to enjoy this part of the forum. helping each other out. However, in order to help you, we need some info. The mileage on the car, do you feel any symptons, Say a stagger, tough starting, or reduction in gas mileage?
Get back to us with some data. Truly the best way is by giving us the OBD II code that you can get with the scanner mentioned above.
Help us out to Help yourself. The Closed Loop operation of MBZ is quite safe, so I don't think you'll do severe damage by driving it a bit.
SCHOK, do you think that as an adult you can present your input in a mature way?
E
Old Dec 13, 2006 | 07:53 PM
SeaCoupe's Avatar
SCHOK, do you think that as an adult, you can present your input in a mature way? Lay off the caps.
E
Old Dec 13, 2006 | 09:18 PM
fanito's Avatar
Thanks!
True, I was very angry and I should've put more info.
Ok, so I can't really feel anything different from before and after, although I haven't drove the damn thing too fast because I'm afraid something worst may happen. I do admit it was uncalled for how I suddenly accelerate but c'mon is a Benz . My car is a c230k auto with roughly 63k miles on it. I can't really anything different, no stagger, tough starting (more than what already is) or any other indication... Weird thing is that I checked the oil for giggles with the hu display yesterday and it was fine. This morning, in the same spot, before I crank my car up said that it needed 1.5qts... after I came to work checked it again and it was fine... granted I never checked the oil that way I'm not sure which is a good way to do it.
I'll drive by autozone tomorrow to get the message check... I'll keep you guys posted.
Thanks!
Old Dec 14, 2006 | 12:58 PM
I Dont Know Wehre You Live But If It Is Getting Cooler At Night Your Oil May Simply Be Condensing From Being Cold In The Morning. Sensors Are Just Stupid Chips That Read Literally Not Actually.
Old Dec 14, 2006 | 01:37 PM
get a code checker and scanner
30 bucks or something cheap like that
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
Old Dec 14, 2006 | 02:40 PM
c230mb05's Avatar
2005 C230 SS
Smile
I worked at Merecedes for 2 years and this happens all the time. One thing you might check is your gas cap. Make sure it is tightened all the way. If it was loose it will take 150-200 miles for the engine to go threw a complete cycle and turn the check engine lamp off.
Old Dec 14, 2006 | 08:12 PM
fanito's Avatar
Well, I thought it was going to be worst (like replacing the MAF or something expensive). I went to Advance Autoparts and I used their reader. Got the following message:
DTC (Codes)
P0130
O2 Sensor
Circuit Malfunction
(Bank 1 Sensor 1)
What stuff could happen as a result of having a bad o2 sensor? (Besides the environment but that's a different story - I don't live in CA )
Old Dec 14, 2006 | 09:18 PM
ctC230K's Avatar
excites your girlfriend
lollercopter!
Old Dec 14, 2006 | 11:47 PM
mleskovar's Avatar
'17 Jaguar XF
Engine runs too rich....wastes gas, increases carbon buildup, fouls plugs, ruins catalytic converters, performance is degraded. Did you try clearing the code and turn off the CEL?
Old Dec 15, 2006 | 01:04 AM
iriefreek's Avatar
'06 C230 Capri Blue
Not to thread hijack but I agree with you that this CEL is irritating. This happened to me about 2 weeks ago... I have been very busy and haven't had time to go to the dealer yet but haven't noiced any difference in performance... it is annoying as I only have 9K miles on the odo. I'm hoping it's the gas cap and will go away eventually like c230mb05 posted above.
Old Dec 15, 2006 | 12:25 PM
SeaCoupe's Avatar
Yep, did you clear the code? If it comes back you are going to have to change that O2 sensor. At least if you take it in to the dealer to have the work done, they can't jerk you around with what is going on.
E
Old Dec 16, 2006 | 11:34 PM
fanito's Avatar
So I finally cleared the code and ran fine for about 15 miles. Them the CEL came back. I guess my O2 sensor is really messed up.
Is it expensive? anyone care to adventure a part number? (c230k coupe, 2002 -auto)
THanks
Old Dec 17, 2006 | 07:21 PM
SeaCoupe's Avatar
THanks
I don't know the part number, but if you go to a MB parts counter, they will get it for you. I don't know what the access point looks like, but a wrench should get that baby off. Then undo the wiring harness to it.
Only problem would be if the Unit is frozen into the bung. PB Blaster can help get the old one out. Whatever you do, DONT ROUND THE Nut part.
E
Old Dec 17, 2006 | 11:10 PM
mleskovar's Avatar
'17 Jaguar XF
Don't guess....did it throw the same code?...Front OxSens = $168 on line and make sure you have a wrench that fits correctly (22mm?). A special tool is made for it but not really needed if you are careful. You can get an equivalent sensor MUCH cheaper but you need to splice in a new lead/connector.
Old Dec 20, 2006 | 10:23 AM
STi_JL's Avatar
02 W163
thats wat i have noowwww FUKKKKKK
Old Dec 29, 2006 | 04:52 AM
fanito's Avatar
ok, so I did clear the code and came back again, same code so I assume it is indeed the O2 sensor (P0130, bank 1 sensor 1), so I call my stealership and cordially asked him to quote me the price for the O2 sensor, gave him my VIN and he said "which one? the front or the back?" I was like whaaaaaa? I didn't know the sucker had two, which is not a big deal if the price wasn't twice as much!!!!!!!! the front one is $139, the back one is $390!!! Any of you experts know is p0130 is the front or the back one (I am just hoping is the front one!, wherever that is)
