H&R Springs Installed
Subscribe
Jan 11, 2007 | 12:05 PM
Hey all,
I don't post on here frequently but do keep tabs on what's going on fairly regularly. Here's pics of the H&R's w/stock #2 pads:
Do you guys think i should do a #3 pad? The rear lower euro look is sort of growing on me lol. Otherwise i picked up an AMG Med F1 steering wheel i got from RLEE that will be installed Monday. Pics to follow...
Reply 0
Jan 11, 2007 | 12:14 PM
That's probably a big difference from the ride height of your car before lowering since you have an '03. Now it looks more like the ride height '04.5+ sport sedans. I say leave the spring pads alone unless the slightly lower rear bothers you.
Reply 0
Jan 11, 2007 | 12:56 PM
Quote: That's probably a big difference from the ride height of your car before lowering since you have an '03. Now it looks more like the ride height '04.5+ sport sedans. I say leave the spring pads alone unless the slightly lower rear bothers you.
Huge difference man!
I actually had the 04.5+ sull suspension installed initally (shocks, springs, sways), it ran 1" higher on all four corners compared to the H&R's. The dampning worked well with the OEM shocks.
The H&R's sports actually feel too aggresive for the stock shocks. Lesson for anyone to change the shocks to Bilstein/Koni at the same time.
I think i'll leave the rear pads... i'm sure i'll do shocks at some point so i'll probably cut 1/2 up front.
Reply 0
Jan 11, 2007 | 04:59 PM
lookin good!
Reply 0
Jan 11, 2007 | 07:24 PM
i think cutting half a coil won't hurt in the front to even things out.
Reply 0
Jan 11, 2007 | 07:28 PM
Quote: i think cutting half a coil won't hurt in the front to even things out.
I say cut a full coil in front and change to #1 spring pad in the rear!
Reply 0
Jan 11, 2007 | 08:26 PM
Is the only way to lower the front equal to the back to cut the front spring one coil? if you use h&r springs could you just drop the front and level the cars evenly since stock the rear is lower?
Reply 0
Jan 11, 2007 | 08:29 PM
Quote: Is the only way to lower the front equal to the back to cut the front spring one coil? if you use h&r springs could you just drop the front and level the cars evenly since stock the rear is lower?
or you could raise the rear to match the front with a thicker spring pad
Reply 0
Explore
Jan 11, 2007 | 08:33 PM
im getting a c230 dont have one yet but im doing all of the planning now so when i get it, i can strat doing mods right away, but also coilovers would work cause you can adjust them. and should the springs be brought to a shop to be cut or do it your self
Reply 0
Jan 11, 2007 | 08:35 PM
Quote: im getting a c230 dont have one yet but im doing all of the planning now so when i get it, i can strat doing mods right away, but also coilovers would work cause you can adjust them. and should the springs be brought to a shop to be cut or do it your self
bring them to a shop...
Reply 0
Jan 12, 2007 | 02:00 AM
Coilovers would be your best bet, but cheapo's have been known to cut corners AND coils! I should know...I cut a half coil on the front springs of my H&R cup kit back in the days.
Reply 0
Jan 12, 2007 | 02:46 AM
so if i put h&r springs on a 05 c230 1.4"front and 1.3" back if i cut half a coil on the front would that even the front with a back? do you know anybody who has done this? or a full coil, dont want to have to cut it twice, and have the shop go through all the work twice
Reply 0
Jan 12, 2007 | 04:24 AM
i had Darwin at carlab cut half a coil on the front of my HR's, my sig pics dont do justice..but the front 17s are almost tucked..i can squeeze a finger in ther..looks real nice and aggressive tho.
Reply 0
Jan 12, 2007 | 08:55 AM
Well....just to look at the other option for a second, how hard is it to replace the pads in the back? I'm like 4 days away from ordering HR springs for the 02 coupe..
Anyone know the stock pad #'s for the coupe...(I haven't stff yet, but I thought since we're talking about it..hehe) so anyone know off hand?
Reply 0
Jan 13, 2007 | 12:59 AM
ok so where can i buy spring pads to raise the back up a little so the tire isnt tucked and matches the front after lowering with h&r's. also what is the different pads and mm's for the pads.
Reply 0
Jan 13, 2007 | 03:22 AM
how do you like the springs?
Reply 0
Jan 13, 2007 | 01:52 PM
Keep it like that bro, it looks hot
Reply 0
Jan 13, 2007 | 06:53 PM
Reply 0
Jan 13, 2007 | 07:09 PM
Quote: ok so where can i buy spring pads to raise the back up a little so the tire isnt tucked and matches the front after lowering with h&r's. also what is the different pads and mm's for the pads.
Dealer, I had #2 and went to #4. It's pretrty even now, a little more space in the front but the car is even. Just installed H&R sways yesterday and it handles nice. Now deciding on struts AMG or Bilstien
Reply 0
Jan 13, 2007 | 08:50 PM
Russell Stevens ...where in oregon do you live? also you just changed the rear pads to number 4 and kept the fronts at number 2 correct? can you change the front pad to make it a liltte lower in the front? if so what pad number thanks for the help
Reply 0
Jan 14, 2007 | 01:39 AM
Quote: Russell Stevens ...where in oregon do you live? also you just changed the rear pads to number 4 and kept the fronts at number 2 correct? can you change the front pad to make it a liltte lower in the front? if so what pad number thanks for the help
Fronts have no spring pads...only the rear.
Reply 0
Jan 14, 2007 | 01:01 PM
Salem, correct there are no pads in the front. And making the front lower changes the handling negatively IMO.
Reply 0
Jan 14, 2007 | 02:51 PM
When I installed #52732 H&Rs in my W203, the front came down ~1.5", but the back dropped more than 2 inches. The rear was too low, with very little wheel travel. Add a passenger or two, and it was riding on the jounce snubbers. Ditched the original #2 pads and installed #4, but they only raised it ~1/4 inch. Trust you installed #52792, but seem to have suffered the same result!
Spoke with Josh Scott, (888) 827-8881, http://www.hrsprings.com. He was very helpful and accommodating. He provided a pair of their #52792-2 rear springs, gratis. Now, the rear is down ~1" from its original height and feels/looks "proper."
Was pleased with H&R's support, so I've subsequently installed their #70392(2) and #71392 anti-roll bars. Combined, the springs and bars resulted in a substantial improvement in cornering speed and overall handling dynamics.
Reply 0
Jan 14, 2007 | 03:27 PM
Quote: 155 -
When I installed #52732 H&Rs in my W203, the front came down ~1.5", but the back dropped more than 2 inches. The rear was too low, with very little wheel travel. Add a passenger or two, and it was riding on the jounce snubbers. Ditched the original #2 pads and installed #4, but they only raised it ~1/4" Trust you installed #52792, but seem to have suffered the same result!
Spoke with Josh Scott, (888) 827-8881, http://www.hrsprings.com. He was very helpful and accommadating. He provided a pair of their #52792-2 rear springs, gratis. Now, the rear is down ~1" from its original height and feels/looks "proper."
I didn't have the problem with the rear it rides pretty nice with two adults in the back. With the 265's in the rear and 35ET wheel I had to trim the plastic on the rear bumper trim, no rubbing now at all. I just installed the same sways yesturday and so far I like the hadling, need to do some back roads to test some more. Now I'm just looking to replace struts. I think I might skip the coilover idea because i am happy with the set up now.
Reply 0
Jan 14, 2007 | 09:09 PM
would moven bm6 rims fit on an 05'c230 lowered with h&r's
Wheel Brand: MB6
Wheel Size: 19x8.5 F / 19x9.5 R
Bolt Pattern: 5x112
Wheel Offset: 32MM F / 38MM R
Wheel Finish: Polish Silver
Tire Sizes: 235/35/19 245/35/19 F/ 265/30/19 275/30/19 R
would there be spacers needed or any rubbing issues? thanks
Reply 0
