Engine ticking.....
Old Feb 18, 2007 | 07:52 PM
dorikin_86's Avatar
2005 Renntech C class
Engine ticking.....
Has any of you experienced this???
I just got an oil change and the engine started ticking after a few hundred miles. I drove it for a little bit more and the sound went away....
Worried,
John
Old Feb 19, 2007 | 12:40 PM
jhartmac's Avatar
C320
Normally ticking occurs from either low octane gas, poor oil circulation-oil pump issues, or sludge build up, but most are self adjusting valves, in your case not sure why it took a few hundred miles, I would advise checking your old oil if possible for any flakes in direct sunlight, that would indicate some sort of premature wear, if the oil looks good and the tick has went away I think your ok.
Old Feb 19, 2007 | 01:00 PM
levelr123g's Avatar
The noise you are hearing is most likely the air pulse valva that sounds like a bad knocking / ticking noise. It is also possible that you are hearing the injectors "snapping". Ticking does not occur using low octane gas, that would be pre-ignition and that would only happen if the engine was under load with the wrong gas. An oil pump also would not cause a ticking noise, you most likely wouldnt even hear the oil pump. Checking your oil also wont diagnose anything unless you had a complete failure. Anyway most likely you are hearing the air pulse valve ticking.
Old Feb 19, 2007 | 01:17 PM
C24owner's Avatar
'08 E550 4Matic
Is there any way to get rid of the noise caused by that?
Old Feb 19, 2007 | 03:06 PM
WaveyKat's Avatar
Something Slow
yea you have to get the """"New Improve valve"""" it have some rubber stuff on it to reduce the ticking sound.. i had mines replace last year
Old Feb 19, 2007 | 03:14 PM
C24owner's Avatar
'08 E550 4Matic
thanks mike. how much did that run you?
Old Feb 19, 2007 | 03:54 PM
WaveyKat's Avatar
Something Slow
can really remember like 100-150 for the new valve installed
Old Feb 19, 2007 | 03:58 PM
C24owner's Avatar
'08 E550 4Matic
Oh okay, not to bad. thanks
Old Feb 19, 2007 | 09:25 PM
dnasty8305's Avatar
2003 c240
does the new valve get rid of the ticking completely
Old Feb 19, 2007 | 10:34 PM
jhartmac's Avatar
C320
NOV---- you must be joking dude..........or you must not be a mechanic............low octane does not cause valve tapping? I've been a mechanic most of my life.........and yes IT CAN CAUSE KNOCKING/TAPPING, and NO I DID NOT SAY THE OIL PUMP can cause TICKING itself.............if the pump is clogged or not operating 100% or not operating at all it doenst pump the oil properly which then causes valve tap..............please know what your talking about before trying to I guess be intelligent.
Old Feb 20, 2007 | 10:20 AM
tee_tz's Avatar
ML63 AMG
Hmmm, okay, not sure who to listen to... but I think since WaveyKat had the problem and replaced something and it stopped, I'll take that advice.
Dude, holla at me I'm not trying to get that done at Mercedes-Manhattan.
Tee_Tz.
Old Feb 20, 2007 | 11:03 AM
dorikin_86's Avatar
good to know it's nothing too serious....
I'll take it to the dealer and find out what happened.....
keep u guys posted
Old Feb 20, 2007 | 11:56 AM
WaveyKat's Avatar
Something Slow
PURGE Valve
