Any one have Hawk brake pads?
Stage 2 C7 A6, QX60
heard they are pretty good, but quite expensive if you compare to oem, if you are happy with oem, then just stick with it, since it's pretty cheap as well
you can get both front and rear pads for around 100
Cobra/E55
I've used Hawk HPS and HP+ race pads combined with Brembo rotors.. They're an excellent pad and will provide much more stopping power over stock. Keep in mind they squeek a little bit when you tap the brakes and don't get on them. This is due to their compound. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
-Aaron
-Aaron
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
I'm close to needing to replace the rotors and pads, so I'm probably gonna do an upgrade (Keep that in mind for those of you that would be interested in 2004.5 4 piston calipers).
2005 1.8 B/B
2004.5 4 pistion calipers are nice, how much are they gonna cost?
i think its time for me to start saving my money for them.
LOl, BTW where i can buy Porterfields brake pad? and price?
Thanks for the info.
'08 E550 4Matic
You can get them from Formymercedes.com
I also got mine from Jerry at Formymercedes.com, and the customer service was 1st class.
'05 C230Kss
the 2004.5 4 piston calipers are the same as the c32 ones no? so they use the same pads as the c32s. thats the 4 piston. otherwise i think its a toss-up for what kind of brakes the 2004.5 get. some are lucky and get the 4 piston, others got the newer 2005 brakes, 2 piston (?).
porterfields are quite expensive. um...was it razrfish or someone who was testing them out for the 2005's. price is around 200 or was it higher for porterfields? and he didn't recommend them. that threads somewhere...
i looked into hawks and they are around 80ish for the ceramics. and a few dollars less for the non-ceramics.
searched and found this post: https://mbworld.org/forums/c-class-w203/173299-ceramic-brake-pads-05-c230ss.html
Not sure how much I'll sell them for, but when I get my brake upgrade, I'll post them up in the classifieds.
AMG GTS
