Attention ASP Pulleys ESPECIALLY BUELLWINKLe
Old Oct 1, 2002 | 12:48 AM
Xeon's Avatar
buell...when i get my car...the mpg is only around 10 ?!!!!! whats yours?
Old Oct 1, 2002 | 01:56 AM
20FHK02's Avatar
2002 C230 Coupe
Maybe the ECU for automatic is different than the 6 speed?
Old Oct 1, 2002 | 10:35 AM
Buellwinkle's Avatar
I have Stage 2 and no other ECU options, I just drove this weekend from Laguna Niguel, CA to San Luis Obispo and back, that's about 550 miles roundtrip with some traffic and long stretches at 85 mph and I got 29 mpg. The best I've gotten was 32 mpg of steady 72 mph cruise control on relatively flat road. Day to day driving to work I get about 22 on the low end and 26 on the high end with an average in between. Worst case, aggressive driving I average 19 mpg per tankful. These are numbers from the computer and I haven't verified if they are correct but they aren't far off if at all.
Old Oct 1, 2002 | 07:31 PM
trench's Avatar
2002 C230 K
I had noticed that driving at night with the air conditioning off I was getting much better highway mileage. I then experimented by driving to work with different climate control options set. Using the AC compressor usually cost me about 1 mpg (for a trip of the same time, mph and ambient temperature).
YMMV (literally).
- BT
Old Oct 1, 2002 | 08:26 PM
DCX Engineer's Avatar
My fuel mileage has not changed much since the pulley install. The car is set at Stage II and base timing. I can easily get 28MPG on my daily commute (45 miles, mostly HWY at 80MPH). This is around 1/2 to 1MPG less than before the pulley upgrade.
Old Oct 2, 2002 | 12:24 AM
GTIDAN's Avatar
2002 C230K, Auto, etc.
Mileage
I have a 2002 C230K, auto, with 1500 miles on it. Last Monday I took a 220 mile drive. Mostly freeway driving 85 when able and rarely under 70. Ended up with an average mpg of 27.4. Not bad for a new car using the A/C on auto set at 74 degrees.
The car is totally stock.
Old Oct 2, 2002 | 12:41 AM
Re: Mileage
That's OK Dan, we won't hold that against you
Old Oct 2, 2002 | 12:45 AM
GTIDAN's Avatar
Mileage
Thanks Buellwinkle.
Enjoyed our visit and the ride in your very nice 'benz'.
