cigarette lighter stuck
Old Apr 23, 2007 | 07:17 PM
Untouchable08's Avatar
2005 C230
I don't smoke nor do I ever use it but my friend loves to play with things and decided to press it in and know it will not come out, does anyone know how to pop it out?
Old Apr 23, 2007 | 07:37 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Correct me if I'm wrong, but heat normally pops it. Therefore it stands to reason that you should be able to pull it out without damaging it.
Old Apr 23, 2007 | 07:41 PM
Lamb0BenZ's Avatar
2003 C240
yooo same thing happen to me and the lighter didnt get hot or anythinng and one day i just noticed that it was popped back out lol
Old Apr 23, 2007 | 07:42 PM
2005 C230
I tried but it wont budge, im gonna try to pop it out with a screw driver, just wanted to see if there was another way.
Old Apr 23, 2007 | 08:51 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Are you saying the plug stays "popped in" even if you pull the entire lighter out, or that the lighter is stuck to your car?
If a), it's just a clip, you just hafta push on a tab if I remember correctly. b) reef on it, it will still come out.
Old Apr 23, 2007 | 08:59 PM
2005 C230
The lighter wont pop out, it is pressed in there and wont pop back out.
Old Apr 23, 2007 | 09:36 PM
ai388's Avatar
10 C350
that happened to me twice actually. the first time, i played with it. the second time, my frd played with it. but i noticed that once i turn on the car (with engine on), it'll pop back out itself. oh well..somehow it just pops back out.
Old Apr 24, 2007 | 12:25 AM
2005 C230
yea it has been like that for over a week now.
Old Apr 24, 2007 | 02:21 AM
crazyfox's Avatar
Which move point A to point B.
same to me about 2 weeks now.
Old Apr 24, 2007 | 02:45 AM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
well i left a can of unopen pepsi on my cup holder and i off went to class with my car sitting in the parking lot expose to sun light.
2 hours later after class.... the pepsi can blows up, spill some to my cigarette lighter, now my whole car is sticky as *****
Old Apr 24, 2007 | 11:18 AM
911_03KCoupe's Avatar
2009 C300 4Matic
It happened to me... due to the proximity of the cup holder on the sports coupe, some java had gotten into the socket and shorted the thing out... check your fuse first, if not turn on the parking lamps and see if the ring around the cigarette lighter illuminates... if it dosen't you need a new unit... I ended up needing a new one, comes with the socket and the pop out element, it was work 50$ CDN.
cheers
Old Apr 24, 2007 | 02:02 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
have you guys changed the fuse?
on a c320 the fuse number is 47... under the hood fuse box loacted in the front right.... it uses a #15 (blue) extra fuses should be located with your spare tire....
hopefully this helps you all
-carino
Old Apr 24, 2007 | 08:28 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Anybody remember the paint can thread?
Old Apr 24, 2007 | 08:31 PM
rlee02135's Avatar
2004 C32 ///AMG
actually, on my c230, i was playing with the lighter, and it got stuck.
took it to the dealer and they replaced it. guess i broke something inside
Old Apr 24, 2007 | 08:33 PM
KIRA's Avatar
yup i remembered!!!
Old Nov 19, 2019 | 01:14 AM
Jaws1er's Avatar
E350
fix the fuse pop it back out and fixed my rear Camara at the same time
Old Jul 4, 2022 | 02:05 AM
Anand.karan6's Avatar
C450
I had same issue. I used gorilla tape to pull it out. Easily worked !!
