yeuchau's C320 mod thread (New Mod 9/4/09 post #387)
#351
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
#353
01' C32o
nice michael!
is that the HU tat had loading lag back then? how does it run now.. i saw the coupon you posted and i really really wanted to get it, but i heard the f/w sucks.
frank, thinks that's a celly holder?
#354
Stage 2 C7 A6, QX60
if you refer to that blue thing, I use to run the gps charger around that.
Time it take it off
#355
Stage 2 C7 A6, QX60
it's not the best, but for the price, I have nothing to complain about.
if it's f90bt, then i wouldn't get it.
#356
MBworld Guru
white and whiter
takes about 40 seconds to boot up(i am kinda guessing, but if you want I can go time it), music will come on first and then the navi will be on, then the phone will be connected..
how's the sound?
#357
'02 CL203 M111
Looking nice!
The boot time is longer on all HU with a hard drive but it's not too bad.
Pioneer FTW. Hope you enjoy it. The use of the menu is easier than the factory nav IMO.
Have a fun drive!
Have a fun drive!
#359
Stage 2 C7 A6, QX60
#360
Stage 2 C7 A6, QX60
#361
Super Moderator
How is your car now? Has it given any more problem since last time?
#362
Stage 2 C7 A6, QX60
Only happened that once, I even took the car to vegas couple weeks ago which is about ~600 miles and no problem at all.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
thanks for following up.
#365
Stage 2 C7 A6, QX60
#366
Super Moderator
I must say I often wonder how well the Benz aerial matches up with RF gain stages in aftermarket units????
#368
Where did you get the double-din opening for your stereo? I also had one installed but the bezel that goes around the radio didn't fit properly, so it somewhat sticks out. Yours looks a little thinner than mine, which may be the answer.
#370
Stage 2 C7 A6, QX60
Hi All,
My warranty is about to expire in 1 months, and I have about 78k miles on the car now.
Is there any thing I should have it checked before it expires, I am have the visual vehicle inspection done now, but i don't know if that's enough.
Any recommendations?
#371
Super Moderator
Have them check the front castor arm (thrust arm/torque arm) bushes for cracks & silicone fluid leaks. Look for oil leaks such as weeping from the diff pinion seal, gearbox seals & TCU connector. Also check crankcase ventilation covers for leaks on the rocker boxes of the engine. Most other things you would know from driving the car. I presume everything works. No funny noises squeaks or knocks.
#373
Stage 2 C7 A6, QX60
I just go the car back from dealer, they said front control arms needs to be replaced and it's covered under warranty.
they did not mention anything else other than that.
#374
Stage 2 C7 A6, QX60
#375
Stage 2 C7 A6, QX60
oh yah, I also ask if I can get extended warranty on the car.
They offer me the followings from Fidelity Warranty.
Powertrain Coverage: 1 year ($1796), 2 years(2346), 3 years(3100), 4 years(3598)
Silver Coverage: 1 year ($2218), 2 years(2850), 3 years(3548)
Gold Coverage: 1 year ($2598), 2 years(3666)
Powertrain coverage: includes Engine block and cylinder heads and all internally lubricated parts, transmission/transzlecase and all internally lubricated parts, and differential/axle housing and all internally lubricated parts.
Silver coverage: Inlcudes powertrain plus steering gear hosuing and all internal parts, brakes, air conditonning(condensor, compressor, evaporator..etc), front suspension and some electrical parts
Gold voerage: includes powertrain, silver coverage plus additional coverages on all catergories mentioned above.
do you guys think it's worth it to get the warranty??
