Warning! bad valve stems.
Old Jun 20, 2007 | 12:29 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Exclamation Warning! bad valve stems.
I had two valve stems fail in one day. They leak at the base, not the core. I was told there is a recall on some of the valve stems out there. so be aware if you have had any tire installed in the last few months. I am so glad I had Sunman program TPS, I was able to get pulled over and stoped before any damage to my tires.
Old Jun 20, 2007 | 03:14 PM
Blake P's Avatar
'09 A4 S Line
Thanks for the warning. I've never had a valve stem fail (*knocks on wood), but I too am glad to have the TPMS activated by MBenzNL because it notified me of low tire pressure on two different occasions when I had nails in my tires causing slow leaks.
Old Jun 20, 2007 | 03:32 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Dont you have to have something inside of the rims to recognize the TPMS?
E
Old Jun 20, 2007 | 03:35 PM
Blake P's Avatar
'09 A4 S Line
E
Nope. I think the car can tell when a tire is low based on the number of roations as compared to others and gives a low pressure warning in the steering cluster.
Old Jun 20, 2007 | 03:43 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
there's a difference between PASSIVE TPMS and ACTIVE TPMS.
The one that is simply programed with STARDIAG is the PASSIVE mode, as referred to above.
The ACTIVE mode requires a whole lot more "stuff". See Dr. Sunil's (Sunman) threads on ACTIVE TPMS.
Carlos
Saprissa@aol.com
Old Jun 20, 2007 | 04:04 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
rubber valve stems FTMFL!
I hate rubber valve stems. The SSR's have stainless steel valve stems and they keep tire pressure even and constant for months on end. No problems at all. Love em.
Old Jun 20, 2007 | 05:05 PM
Blake P's Avatar
'09 A4 S Line
curbed SSR's FTMFL!
Old Jun 20, 2007 | 05:10 PM
nlpamg's Avatar
Originally Posted by Blake P
curbed SSR's FTMFL!
Old Jun 20, 2007 | 07:14 PM
WaveyKat's Avatar
Something Slow
Can TPMS be activated on a 2001 C320? does anyone know?
Old Jun 20, 2007 | 07:44 PM
RES's Avatar
RES
You would have to upgrade your front SAM, I don't know if thats all you would need. Check with Sunman. I have a front SAM that is TPMS programable.
Old Jun 20, 2007 | 07:57 PM
WaveyKat's Avatar
Something Slow
yea i need to purchase a 2005+ Front SAM so i can do the TPMS and auto folding mirror when locked.
Old Jun 20, 2007 | 08:01 PM
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
That's weird, cuz my car was able to have the passive TPMS and I have a 2004.5.
Old Jun 20, 2007 | 08:50 PM
Blake P's Avatar
'09 A4 S Line
Early build '04 here with no problems!
Old Jun 20, 2007 | 09:58 PM
hawaiian's Avatar
2003 C230K SS (6 spd)
So if 04's have it, I should have it on an 03 as well........... right??
Old Jun 21, 2007 | 02:25 AM
Saprissa's Avatar
Nope. It works on my wife's 2004.5 but not on my 2003.
You need a 2004+ Front SAM.
