I am sick and tired of the W203 C350 M272 model being left out of all the fun. Ok, so there aren't many on the street but they always seem to be left out of the mods party! Just look at the title of this forum! Where the C350?!? Forgotten (or excluded)! Here's what got me started on my ranting. I checked out the Remus Exhaust website today and they had a part number for an axle-back exhaust system for the C350 so I wrote them about it. Turns out it's for the W204 which you can't even buy over here yet! There are zero on the roads yet they have a decent exhaust system out for them. And none for the W203 of course which has been on the roads for over 2 years now. So I was hoping W203 C350 owners who have done performance mods will list them here. What fits. I'd like to see them fall into the following categories. If you have any first hand knowledge about parts that fit in these catagories I'd love to hear about them.
Mufflers or silencers -
Axle-back or cat back exhaust -
Air boxes /cold air intakes -
Headers -
High-flow cat pipes -
Shifter / linkage -
ECU reprogrammers (93 octane) -
Turbos / superchargers -
Fuel injectors -
Throttle bodies (?) -
Transmission reprogrammers -
Wheels (18"/19") -
Lowering springs -
Performance shocks -
Sway bars / bushings -
Brakes (calipers/rotors/pads) -
Headers -
Kleeman said the SLK350 headers can fit with HEAVY modification
Shifter / linkage -
Schatz Prestige shifters fit, nice chrome trim ring for the boot
High-flow resonator pipes -Resonator delete works fine, $100 and 1 hour, use stainless 2 1/2" pipe
Cams -ECU reprogrammers (93 octane) -
MKB ($3000, most expensive)
Kleeman ($1500)
Carlsson (305hp, most HP, not cheap)
Powerchips (best price)
Speed Innovations (21hp and 29ft-lbs for $700, most hp/tq/$)
Manifolds -Kleeman ($1500)
Fuel injectors -
Wheels (18"/19") -
TSW Bremmas 19" double spokes fit over the 4-piston calipers with no spacers and no fender mods, EuroTeck Motorsports has then for $1850 shipped with Nitto NT555 Extreme 235/35 and 265/30 tires mounted (here's the link)
Tirerack shows nothing
Looks like C32 wheels will clear the C350 4-piston calipers
Air filters -Tirerack shows nothing
K&N (website has a part number now, I'm using them, work great)
K&N Part Number is 33-2859 (here's the link)
Lowering springs -
Most W203 parts from other models will fit the C350....
same car, different engine.
Quote:
Oh, sorry. I thought the M272 E25 is in the C230, the M272 E30 is the C280's 3.0L and the M272 E35 engine was what I had under the hood, the 3.5L 24-valve DOHC SFI 90 degree V6 with the aluminum block and silicon/aluminum lined cylinders.Originally Posted by rlee02135
M272 is the 2006-2007 C230's engine.
PS: That is the second time I have tried to wipe your bug off my laptop screen.
Quote:
LOL Originally Posted by Drop-a-Daimler
Drop-a-Daimler
-Jeff
MBUSA specs quote the front calipers as dual-piston. Typo on your part or did you upgrade your brakes?TSW Bremmas 19" double spokes fit over the 4-piston calipers with no spacers and no fender mods,
-Jeff
-Jeff
MBUSA website isn't always correct.Originally Posted by Jeffy
Drop-a-DaimlerMBUSA specs quote the front calipers as dual-piston. Typo on your part or did you upgrade your brakes?
-Jeff
Seems like all the C350 SS's got the 4 piston calipers from the C32/C55.
Super Moderator Alumni
drexappeal
close
-Jeff
Some 350's (I think in '07) ended up having 4 piston, just like the 2004.5 and early build '05!Originally Posted by Jeffy
-Jeff
ExploreSuper Member
Quote:
seriously.. that bug is getting to me as well. lolOriginally Posted by rlee02135
LOL
07 c230 brakes were 4piston too. if they arent, then they are surely some BEEFY 2 pistons
Quote:
2007 C230's do NOT have 4 piston calipers, they have 2-piston calipers.Originally Posted by BadAssC230k
-Jeff
No, it's correct, the 2006 and 2007 C350 Sport Sedan models (W203 M272 E35 to be exact) get 4-piston calipers up front with the cross drilled, vented rotors all the Sport models got. So in most wheel catalogs you will find almost no wheels for that specific model (without crazy spacers). And if you do see a part number, then I would ask specifically about the fitment because some suppliers I have talked to will sell you a general W203 wheel and it will not fit. That's one reason why I avoid the "most W203 parts will fit". As it turns out, when you dig a little, mufflers are a toss up, wheels don't, headers don't, and cams don't. So buyer beware.Originally Posted by Jeffy
-Jeff
Quote:
easy thing for wheel fitmet is just lookup wheels for the C32 or C55.Originally Posted by Drop-a-Daimler
drexappeal
close
Quote:
Well, I'm not sure I agree on why the 350 is not listed in most catalogs. My theory is that it is an engine that is 2 years old and realistically, to get wheels, all a w203 owner with 4 piston calipers would need to do is check for the C32 setup. No reason for wheel companies to re-do all of their catalogs, just to indicate the 350's, which have the same brakes as the 2004.5.Originally Posted by Drop-a-Daimler
Believe me, that's how I had to approach buying wheels. Every single set-up I saw, I had to look at the C32 setup and nothing less in order make sure that I was getting a setup that would clear the front brakes.
Quote:
your right. my bad. just beefy dual piston with cross drilled. Originally Posted by e1000
Quote:
me too Damn you Robert!Originally Posted by sanf
Quote:
It's a valid point and I tend to agree. It's how I started my search after seeing NO C350 part numbers. But I am always still wary. The AMG calipers are 4-piston but look slimmer so I still try to verify.Originally Posted by drexappeal
Well, I'm not sure I agree on why the 350 is not listed in most catalogs. My theory is that it is an engine that is 2 years old and realistically, to get wheels, all a w203 owner with 4 piston calipers would need to do is check for the C32 setup. ..
drexappeal
close
Quote:
I have the same exact 4 piston setup. So, if you need verification, my setup clears without ANY problems (although, I do have 3 piece wheels). Anyways, when I was initially ordering, I told the shop to base the setup on the C32 setup.Originally Posted by Drop-a-Daimler
Quote:
Cool. Good tip. I've added it to the Wheels section at the top.Originally Posted by drexappeal
... I told the shop to base the setup on the C32 setup.
Quote:
I think both the sport 350's ('06 and '07) came with 4 pistons, last time I checked was in my garage Originally Posted by drexappeal
We just got confirmation from Remus Austria that our C320 exhaust system will fit the C350 W203.
http://www.remusexhaustshop.com/merc...548-p-854.html
10% off for all members + 7% if you refer another member.
Saprissa
close
- Join DateJun 2003
- LocationSan Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Liked:4 Times in 4 Posts
good deal Mathieu !
Man, you guys are fast. I just got your email confirming this fitment and came here to update my thread and ... it's already posted! Originally Posted by REMUS
We just got confirmation from Remus Austria that our C320 exhaust system will fit the C350 W203.http://www.remusexhaustshop.com/merc...548-p-854.html
Any thoughts about improvements since the C320 makes considerably less horsepower than the C350 (215 vs. 268), is there a risk that the C320 system will be restrictive when applied to a C350? The pipe diameters appear to be the same.
Saprissa
close
- Join DateJun 2003
if the pipe diameters are the same, then it wouldn't be restrictive.
Email has been sent to answer your question.
Basically, all our Sports Label exhaust systems are straight through, since the diameter of the piping is the same, performance will thus not be affected
