stock fog headlights turning yellow after HID any solution?
Old Jul 17, 2007 | 04:14 PM
joyofcola's Avatar
E320, C230 Coupe, SLK350
Hey guys just wondering if anyone has the same situation. I have installed hids into the non-clear headlights for about 2 yrs and i sort of notice the headlight lens is turning a little yellow. Are there any solutions to getting rid of this yellow stain other than replacing it with clear headlights or bixenons?
Thx
Old Jul 17, 2007 | 04:18 PM
sanf's Avatar
E53
if the yellow color isnt caused by your hid.
maybe you can try this
Old Jul 17, 2007 | 04:32 PM
Blake P's Avatar
'09 A4 S Line
Originally Posted by joyofcola
...or bixenons?
kevblah's Avatar
E90 M3
some people have replaced the housing unit...i know someone even painted the inside silver with a high-temperature withstanding paint
Old Jul 17, 2007 | 04:57 PM
powa's Avatar
C320 Coupe
my inside (foglight housing, where the white is) turned yellow/brownish, think probably the HID fog is too hot.
Old Jul 17, 2007 | 05:47 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
nail polish remover. Did it for my old MX-6 headlights and it worked like a charm.
Old Jul 17, 2007 | 05:51 PM
infected's Avatar
2007 ML500
Try wetsanding.
Old Jul 17, 2007 | 05:54 PM
joyofcola's Avatar
thank u for the quick replies...
sanf the link doesnt work?
and for the nail polish remover wouldnt it be too strong and cause the lens to have minor cracks....cuz some of my friends used tht to remove tail light tint and it caused lil cracks on the lens
Old Jul 17, 2007 | 05:56 PM
joyofcola's Avatar
so if the the yellow/brownish tint is caused by the heat of the hid then i cant do anything about it right?
Old Jul 17, 2007 | 05:59 PM
drexappeal's Avatar
I never had any problems.
Old Jul 17, 2007 | 06:21 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
Thx
I have a pair of the "Frosted" headlights that I can sell to you. Make me an offer if interested.
Old Jul 17, 2007 | 08:54 PM
joyofcola's Avatar
its okie...mines a coupe so dun think i can fit ur lights but thanks for the offer....if i were to buy lights im gonna update to bix but just need to save up or raise some money haha
Old Jul 17, 2007 | 09:03 PM
Tangerine's Avatar
Is @ Home
Is the yellowing from the inside or outside? If from the outside try Eagle One Never Dull. If its from the inside did you use the rear covers when installing the HIDS? Moisture might have developed from the inside.
Old Jul 18, 2007 | 12:01 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
I've got stock pre-2005 C-Coupe headlights for sale if interested.
PM me.
Old Jul 18, 2007 | 12:35 AM
joyofcola's Avatar
then i think its the moisture...soo if its caused by the moisture what can i do?
Old Jul 18, 2007 | 01:11 AM
sanf's Avatar
E53
the link takes you to an ebay auction. just go to ebay and search for "HEADLIGHT RESTORE"
if its moisture.. get new ones or reseal it.
Old Jul 18, 2007 | 12:06 PM
Tangerine's Avatar
Is @ Home
You can get new ones or you can clean them. Do you have any pics just so I can be sure? But to clean them your gonna have to take out the headlamp and pour some cleaning solution inside the lens. Check the rubber seals to see that its in good condition and there are no leaks. If there are, you can add a layer of silicon or you can heat up the headlamp and take out the old and put in a new seal. And don't forget the rear covers.
Old Jul 18, 2007 | 01:49 PM
Josh K's Avatar
Tesla Model S
It has nothing to do with the temperature output of HID's, which actually run much cooler than traditional headlights.
Do you park your car outside? Headlight yellowing is a result of too much UV exposure (as well as airborne pollutants). You can get a lot of it off by wet sanding the headlight with 2000 grit sandpaper and then using a headlight restore polish.
Old Jul 18, 2007 | 02:23 PM
Midnight Koop's Avatar
CL203
if its because of external exposure, then maybe a preventative measure could be headlight film from 3M. i put it on my bixenons to be safe from chips, so i'd like to think that its also going to keep it from "yellow-ing"
Old Jul 19, 2007 | 02:00 AM
Josh K's Avatar
Tesla Model S
Yep! I have a set of them on my HID's. They look as beautiful as the day I bought them.
Old Jul 19, 2007 | 02:08 AM
Saprissa's Avatar
3M headlight film has always been highly recommended.
Can't go wrong. If exterior exposure is the cause of the yellowing, then yes, that might work.
However, if it is internal, Tangerine's advice might be the solution.
Carlos
Saprissa@aol.com
