2006 C230 AUX input
Old Aug 1, 2007 | 09:41 PM
sp_06_c230's Avatar
2006 C230 AUX input
Does anyone know the part number for the Cable harness that can be used to add an AUX input to a 2006 C230 with CD changer.
If I press and hold the CDC button it shows "Aux active" and I believe there is cable that can be connected to the radio back that will allow an AUX input.
I have seen the cable for the 2005 c230 but am unable to get much info on the 2006 cable which I believe is different.
Any help will be appreciated.
thx
Old Aug 1, 2007 | 09:54 PM
e1000's Avatar
a quarter mile at a time
it's the same as the 2005's. there's a huge thread
Old Aug 2, 2007 | 02:38 AM
sp_06_c230's Avatar
2006 C230 AUX connector
I spoke to a dealer today and they said that the 2006 had a differnt cable harness. I looked at the discussion forum and downloaded a pdf that had instructions and the part no for the 2005 c230 harness
The dealer had the part A2035406107 but said that the white connector at the end would not fit the 2006 model.
Also the 2005 instructions had the connector cable at the base of the passenger door but in the 2006 it is behind the radio.
Has anyone successfully connected an AUX cable in a 2006 c230 and made it work? Any details would be appreciated
thx
Old Aug 2, 2007 | 02:56 AM
e1000's Avatar
https://mbworld.org/forums/showthrea...06#post2345104
Old Aug 2, 2007 | 03:03 AM
coin's Avatar
'06 CLK500
thx
I just finished doing AUX for my friend's 2006 C280. We used the same cable (white connector) as the 2005 instructions posted here.
But we connected the AUX from the base of passenger door instead of behind the radio.
Old Aug 2, 2007 | 02:13 PM
sp_06_c230's Avatar
Hi Coin
Thx for your note
Would u by any chance have the part number for the cable harness you used in the 2006 c280
Seems like the dealers have no clue which is disappointing and I am sure they will say that the 230 and 280 are different
Old Aug 2, 2007 | 06:44 PM
coin's Avatar
'06 CLK500
The part# is the same as the instructions posted here.
210-440-50-05
Old Aug 2, 2007 | 06:48 PM
Kingotch's Avatar
Does that also apply to a 2007?
Nt
Old Oct 6, 2008 | 04:20 PM
detachability's Avatar
2006 C230 Sport
I just successfully installed the aux cable for my 2006 c230 sport. I used the same part number mentioned above and followed the instructions posted in the forum.
Old Oct 6, 2008 | 05:03 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
now that's a for the noob.
update ur location btw.
Old Jan 2, 2009 | 07:47 PM
Cha0s121's Avatar
2005 C230K Sedan
I currently have a 05 C230 Sport W/ a CD Changer ... and about a year ago I did this Aux Ipod Mod ... But my crazy *** didnt like the idea of it being in the glove box so I cut and spliced the harness ... and cut and spliced a 5" male to male 3.5mm cable, Just twist and taped Red & Brown, White & Yellow and Black & Black, ran the the cable around the dash into the top part of the center compartment. There's also an aluminum Black cable of the harness, Just tape off cause I didn't find any use on it. and best of all when I pause it, you dont hear that static noise. Good luck
Old Jan 5, 2009 | 04:12 PM
ekimpay's Avatar
'06 C230WZ
here's the link for the aux cable i'm selling which i've used on my 2006 C230.
FS: Aux Cable A 210 440 50 05
