Rain sensing wipers SUCK! Need help from a MB tech!
This is mainly a problem with light rain, where the setting just past the rain-sensing setting is too much (constant wiping motion). How many wipes/per/second do the standard non-rain sensing intermitent wipers wipe? Is there just one intermitent setting on non-C2 optioned C240's (and C230's too, I assume)? Is there a way to bypass the rain-sensing function? Can it be done via the computer at the dealer? My '98 Crown Vic has about 5 intermitent settings! Please help me before I go crazy!
Jim
Good news - you can probably greatly enhance the performance with either cleaning or replacing the passenger blade (the one that wipes the sensor). If part of the passenger blade that cleans the sensor has a bit of dirt or wear just over the sensor, the sensor will not "see" clearly after a wipe and call for another one.
Keep your blades clean and you will like the sensor more. I advise cleaning the blade with rubbing alcohol on a rag.
What controls the wipers? Perhaps there is some relay somewhere I can replace?
my c230 is only a month old and the wipers squeak pretty loud. Is that normal?? and yes the rain sensing is annoying about half the time. Where is the sensor guys. Thanks.
how hard is it to turn on your wipers when it rains
The rain sensing wiper's function isn't to turn on the wipers when it starts raining. It's function is to control the speed of the wipers as conditions change. You still have to turn them on yourself.
Actually, it's not the "speed" of the wipers. They always move at the low speed during intermittent operation. It's the wipe "frequency" that is controlled by the rain sensor.
I'd like about a 3 second delay between each wipe.
I thought that MB would still include an adjustable intermittent wiper function on top of the rain-sensing wiper. From What I can tell all u get is OFF/rain-sensing/medium/fast. Usually cars have the first slow with adjustable interval that u can fine-tune about 10 different settings.
Jim, in the past, people have asked how much trouble it would be to add the rain sensor, not remove it. I think the rain sensor "plugs" into the circuit instead of the regular timer module. Seems like you could disconnect the sensor and insert the timer... Or, maybe you will get used to it. I think it's great, despite the inability to adjust the sensitivity. Aren't you always fiddling with the timer setting for the regular type of intermittent wipers? And when the rain (or your speed) picks up, it goes right into full low speed operation (no pauses). I hardly every turn the switch from rain sense to full low.
Cheers, BT
If anyone has info on disconnecting the rain-sensor and connecting a timing unit, I would be forever in your debt
... or making me go blind by letting water build up. I have had to switch to the low setting because I was starting to lose visibility and was afraid the rain sensing function woudn't kick in. .
Now waiting until I find a sensibly priced spare.
Wayne
