HELP~ with my Automatic Key- Door release
2002 C230 Kompressor, Capri Blue
Hello all,
I have a feeling this has happened before and I have searched, but just cannot find a good answer for my situation. I purchased this 2002 C230K used with 18k miles about 2 months ago. I have both keys, but neither will unlock the doors. I put new batteries in this, the key lights up red, but nothing happens. Is there a fuse I could check and where is it located? I see the fusebox under the hood, but have no diagraphm to show the fuse placements. I am thinking its either the fuse or some synchronization issue. Thanks for any help you can give me.
1 Post
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
Does the car start? Open the car with the manual key, and see if you can get it running. If not, check the car's battery...or jump start it.
My battery died a week out of warranty, and the symptoms were exactly what you're experiencing. 18k miles on a 2002 car means it's been sitting - not running.
Rick,
Thanks. Okay,the car starts and runs fine. Its just getting the automatic key fob to work. I have to manually take the key out of the holder each time to lock and unlock the car.
2002 C230 KOMPRESSOR
As for he IR port on the door handle... that is for the auto window feature.... the lock still use radio frequency........ <---- AT least that is what I was told by MB dealer...
'02 CL203 M111
I point the key in the direction of the receptor, the door lock and unlock as usual.
Now, do the same thing at the same place, but with the palm of your hand blocking the infrared light from the key, like you would do when you were kid on the TV remote control, so your brother can't change the channel.
If your key can lock and unlock, then it is radio.
On my 02 it cannot.
and my IR key works only when I am standing next to the door on the rear side of the car (the level of the back seat).
2002 C230 coupe , NOt THE AVATAR!!
Well one way to find out... little test.
On my 02 it cannot.
On my 02 it cannot.
On my 02 it cannot.
On my 02 it cannot.
However I have noticed that my ir only works on the passenger side.. when i try the driver side it never works{taking about auto windows here
}.. i need take door apart and check that out... maybe a wire is diconetced or something...
I will also say that i have only owned car for 1 month and it is my first mb so i know hardly anything.....
'02 CL203 M111
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
Well time to get it fixed at the stealer
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I have 02 c230K and i can unlock my doors from inside the house...I only need to be right there for the auto windows...
![action](https://mbworld.org/forums/images/smilies/action1.gif)
I tried to look inside my door everything is well connected. I unplug and replug them on that module (at the level of the inside door opener).
With all these input I guess jagsy might have the radio anthena issue then ... u guys agree?
I actually do have a radio frequency issue. In fact, I do not get any AM radio. This is my first MB as well, and it takes some getting used to.
Now, what do you fellas recommend for a new antenna, and how is it replaced?
Thanks everyone.
Thanks everyone.
