First Snowfall with 2003 C230K
I was able to make the back of the car fishtail substantially (much to my surprise coming off the highway... been a while since driving RWD), I thought the ESP and anti-slip control (ASR) would prevent this... my mistake I guess.
I did notice that turning into my work that when the rear end did swing around, the front brake was applied and the car sorta gittered, really weird, guess the ASR and ESP aren't that smart, I might disable it for winter driving if its behavious is going to be this unpredictable.
Of course, if you were trying to make the car fishtail, as the saying goes, all the safety features still won't overcome the laws of physics.
You must've been going pretty fast for the ESP not to be able to regain control of your car! I was playing around in a huge parking lot on the first sight of snow, and I was going around 50-60km/h (way too fast for taking turns in snow on the streets) and the car still wouldn't completely fishtail; you'd feel the car start to slip, then the ESP warnign would flash like there's no tomorrow and I'm going straight again, even if I'm on the throttle the whole time. Tried it again without ESP and I just spun around by about 90 degrees. Pretty scary. Well, I guess it depends on what you call "substanially" whipping the tail around
I'm sure someone will correct me if I'm wrong. The arctic alpin tire is meant more for ice than snow. It has no tread "bite" that is readily noticeable. It probably has some siping but overall it looks as if it's a slick with some straight grooves cut into it. That might explain the poor traction.
Snow, that is sooo great, wish we had the stuff. We might get our first real rainfall of the year this weekend, woohooo, wonder if the wipers work.
Interesting. With ESP on I was only able to fishtail the car very little before the power was cut and certain brakes applied. That kooky triangle would blink like crazy but, the car continued in a straight line.
I'm off to an empy lot to practice, but I can spin the tires and fish tail the car (only a few feet) with minimal effort with ESP on, and I don't mean I am flooring it, at like 3-4K revs in 1st gear I can fish tail a snow covered corner.
If it happened right when you downshifted and you didn't match revs, then you probably locked the rear wheels for a moment and it took ESP longer to get it back under control. If your rear wheels are locked, applying the brakes won't really do anything as the wheel is not spinning. So ESP probably didn't have anything it could do until the wheels started rolling again.
The car did seem to straighten out fairly quickly and easily, so maybe I just have to get used to the car a little more, it was the first real bad winter day I've driven it in.
As for the other comment, the weight in the trunk sounds like a good idea, this car seems to be light in the rear.
You might want to put the other hand on the wheel, too. Especially in snow.
I wonder if there's an aftermarket instrument cluster out there with a different placement for the tach, I'd like to have the fuel and tach gauges swapped locations.... hmmm do right-hand drive cars have the same set of gauges?
Come on, how many of actually drive with 2 hands on the wheel? especially those that drive stick?
In an earlier thread, some months ago, it was mentioned that keeping your hand on the shifter was not good as it was placing unnecessary weight on the mechanism for a prolonged period of time.
Perhaps someone more mechanically inclined than myself can verify or trash this statement.
Actually, I do. At the nine and three positions, not the ten and two spots.
It should cause more wear on the transmission, have you ever been driving and just pushed the stick into gear a little more, you'll feel the difference, and its probably not good for the transmission, so there probably is technical merit to what you say.
