C30 Clear Lenses
They wont fit without modification to the body, hood and bumper.
If the coupe lenses does not fit the sedan. Will the new 2003 sedans (eg. c32) have the clear lenses? Or is it still the same ones from last year?
The previous version of the xenon lights require the "hazed" lens to properly focus the halogen high beam.
- BT
hey CitronC230K_03
I presently have the xenon from 2002, I just want to replace the outside lense. Is that possible? If so how do I do it?
thanks
Francis
https://mbworld.org/forums/showthrea...ighlight=xenon
this thread is someone who swapped halogen for bi-xenon with no problems with wiring. they did have to make a trip to the dealer to change the xenon present setting in the ECU. i would imagine if a non-xenon halogen W203 can do it, then a 01-02 xenon equipped W203 would have no problems. ill keep looking for the other thread but someone who had the older xenon and swapped for bi-xenons did it with no problem.
Is it possible just to change the lense cover. I am not looking to change my current xenon lights. I am quite happy with the current xenon and its too expensive to buy the new bi-xenon unit. Can I just take the existing hazed lense cover and replace it with the new clear one?
thanks
francis
CitronC230K_03
thanks
francis
Solar....do you have FACTORY Xenon? Take it to the dealer and have them replace it under warranty. It sounds like you have moisture or condesation inside the assembly.
If this was an aftermarket mod....then you're screwed.
