Help needed with AMG sway bar.
Old Nov 7, 2002 | 06:25 PM
Buellwinkle's Avatar
I unbolted the rear sway bar and removed the four screw holding the clamps and bushings. Is there a trick to snaking that sway bar out? I got it about 80% out but it keeps hanging on the exhaust pipe.
Old Nov 7, 2002 | 06:33 PM
KWiK's Avatar
2002 C230 : 2007 C230
take some pictures so we can see where exactly it's getting stuck
Old Nov 7, 2002 | 06:47 PM
Mach430's Avatar
If it's anything like my CLK was, you're in for trouble! I had to lower the entire rear subframe from the differential to install my sway bars.
Old Nov 7, 2002 | 06:59 PM
KWiK's Avatar
MB was nice to us with the C230K, they rear sway is no longer above the sub-frame.
Old Nov 7, 2002 | 07:01 PM
gab's Avatar
gab
hey buellwinkle
hows that intercooler coming along, can you post some reviews?
Old Nov 7, 2002 | 07:07 PM
The intercooler is doing fine. I was not the easiest to install. I can feel the difference. The biggest difference is that I get the power consistently on a warm day or cool day and after just starting the car or running it hard.
Back to more important things. I can pull the bar out to towards the passenger side but it gets hung up by the exhaust. It might be easier if I either remove the rear wheel to give me a little straighter path or drop the muffler.
Old Nov 7, 2002 | 07:17 PM
KWiK's Avatar
Removing the wheel is a big help.
Old Nov 7, 2002 | 09:49 PM
eason's Avatar
W212 E63
The easiest way is to take off the rear tires. If not, you can pull out the sway bar from the passanger side, there is a spot where you can slip it out. Just keep trying.. Putting the AMG sway bar in is a bit more difficult, since it's 3mm thicker. Just keep trying.
Old Nov 8, 2002 | 02:15 AM
rrf's Avatar
rrf
Jack both rear sides letting the wheels hang.
I think I did remove both wheels too.
No sweat.
Old Nov 8, 2002 | 06:55 AM
kw230's Avatar
2002 Mercedes c230k 6 speed
It requires some force to take it out if it stuck...
Be more aggresive Buellwinkle!!!
Once you take off your rear wheel, it shoud be fine.
Old Nov 8, 2002 | 06:42 PM
KWiK's Avatar
Beull,
Did you ever finish!
Old Nov 8, 2002 | 06:54 PM
Believe it or not, it's actually raining (first time in at least 6 months). The car is too wet to get under. I'm hoping it dries up by Sunday so I can do it.
Old Nov 9, 2002 | 01:00 PM
JeT's Avatar
JeT
Damn...looks like I'm gonna need a professional install if I get the eibachs.
Old Nov 9, 2002 | 01:33 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
You Must Raise the rear of the Coupe Set on Jack stands or on a Hoist,and remove BOTH rear wheels to remove the Rear sway bar...Its a 20min Job!(With Air Tools) Evo Sport Is Making Larger Sway Bars. Larger Than The AMG Bars..
Old Nov 9, 2002 | 03:35 PM
Got the AMG sway bar installed. I removed the passenger wheel, gave me better access to remove the bar. Took about an hour from start to cleanup (no air tools). Can't tell you if the car handles better because of the rain.
Old Nov 9, 2002 | 07:06 PM
eason's Avatar
W212 E63
With the rain, my car oversteer a lot more than the OEM sway bar. Now the ESP just flashes everytime I corner hard.
Old Nov 15, 2002 | 12:27 PM
totita's Avatar
C230 K
How does the car handle with the new sway bar? Can you please post the part number for the AMG sway bar. I know you had problems getting the right one. Also the part numbers for bushings.
Old Nov 15, 2002 | 12:37 PM
patronus's Avatar
2001 C240 / 6-speed
I have posted these part numbers a lot. Is there a better place to put them that are more visible?
AMG Sway Bars for W203 (for C32's, but fit all models)
FRONT ASSEMBLY:
203-323-31-65 - Bar-front - $70.30
203-323-16-85 - Rubber mount (bushing) - $4.40 (2)
203-323-11-40 - Bracket - $11.50
203-323-12-40 - Bracket - $11.50
203-323-21-89 - Rod - $47.18 (2)
913023-012002 - Nut - $2.40 (4)
002-990-39-22 - Screw - $1.25 (4)
REAR ASSEMBLY:
203-326-00-81 - Rubber mount (bushing) - $7.60 (2)
203-326-15-65 - Bar-rear - $74.93
Old Nov 15, 2002 | 12:49 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
No, you need to start practicing tough love. Post "STFF" instead of posting the part #s every single time; people will wise up.
FYI to those waiting on Eibach sways: should be shipping from Tirerack on the 26th; delay is due to a strike in the Fatherland.
Old Jan 15, 2003 | 12:45 PM
jscavo's Avatar
w203
which ones
looking to put on new front/rear sway bars on the c230 coupe. which are the best (less body roll) for the money? AMG seems to be the less $$ way, but will there be a noticable ride differance?
Old Jan 15, 2003 | 12:57 PM
KWiK's Avatar
go with the Eibach or Evosport bars if you want flat. Go with the AMG bars if you want a little flatter than what you have.
