Check Engine Problem
Old Jan 18, 2010 | 01:18 PM
  #76
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Thanks Glyn. Definitely don't see the cost or potential headaches as worth it for a "few" HP. I'd need 11hp to even reach 200.. that's a sobering thought and reality check for the C230.
Old Jan 23, 2010 | 08:53 PM
  #77
ivan209's Avatar
2005 c230 ss
i have the same problem....it threw code p0171b bank 1 too lean...does anybody know what this means? help .....
Old Jan 24, 2010 | 04:56 AM
  #78
Glyn M Ruck's Avatar
Super Moderator
You have a vacuum hose leak or dirty or failing MAF most likely.
Old Jan 24, 2010 | 10:04 PM
  #79
ivan209's Avatar
2005 c230 ss
thanks Glyn M Ruck....ima look into that this week....
Old Dec 14, 2011 | 08:59 PM
  #80
Rikaz's Avatar
mercedes C180 Sport
Hi, I have a W204, 2010, c180, 1.6L AMG Sport, and the check engine light came on a few weeks ago, the dealer checked and the error code was "Boost Pressure not in range". the car has clocked 40,000 Kms. They dismanttled the entire supercharger hoses and checked the intercooler and all connections for air leaks, non found, then they replaced the pressure sensor. few miles down the road check engine light on again, then they replaced the MAF (Air Flow Sensor) well few miles down the road again check engine on, car does not move the way it is suppose to when the light comes on.but if you re start the car it moves for awhile and then again it slows down. Air Cleaner was also changed. I have been to the dealer so far on 6 occations and the problem still persists.can anyone help or share your thoughts on this
Old Dec 15, 2011 | 02:53 AM
  #81
Rikaz's Avatar
mercedes C180 Sport
The followings were the error codes: P3539, P2263 & P2188 this morning, now the dealer changed the gas cap and an O Ring that comes for the attachment of the Inter-cooler
hose.
Old Dec 1, 2015 | 04:58 AM
  #82
l.d.r's Avatar
C-Class W204 200k
Codes 3539, 2188, 2263
Hi there,
Newbie on this forum here. Sorry to resurrect this old thread! i have exactly the same fault codes.
I have a 2008 C-Class 200k (1.8 kompressor). The engine management light recently came on and the car is now underpowered and struggles to go above 60 on the motorway.
I took it to my local dealer and they found the fault codes:3539 - the boost pressure deviates from one the specified value, and 2188 - the mixture (cylinder bank 1) is too rich at idle speed. My handheld scanner also picked up 2263 but this was not recognised on the dealers machine.
They have not yet diagnosed the problem and want to charge for a further 1 hour of diagnostics to further investigate. My local specialist seems to think it may be a MAF issue, but is unsure if this would throw the 3539 code and wants to spend some time investigating this.
Any help on what the problem may be would be much appreciated.
Thanks,
Lee
Old Jul 14, 2016 | 07:10 PM
  #83
mahnek's Avatar
2009 c180 merc
I seem to have the same problem. Theres oil on my engine as im over 200k.
I will study it over the weekend. Codes i get are 2193 3539 2263.
Power loss
Old Jun 10, 2019 | 08:48 PM
  #84
Tarek Anis Daou's Avatar
C180 K Model 2010
Hi. Were you able to solve it? What was the issue?
