DIY:W203 radiator R&R
Old Jun 11, 2010 | 08:50 PM
  #101
KingKenny04's Avatar
2002 Mercedes-Benz C230 Sport Coupe, 1986 BMW 325e
Will Splinter's write up work on a manual Sport Coupe rad?
Old Jun 11, 2010 | 11:30 PM
  #102
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Originally Posted by KingKenny04
Will splinter's write up work on a manual Sport Coupe rad?
The procedure will likely be quite similar.
Of course your radiator PN will differ owing to its manual transmission,
and the fact MB chose to specify many unique Coupé parts.
Upside is you’ll not have to fuss with those pesky ATF cooling tubes -
more than halving the effort required for installation.
Old Jun 12, 2010 | 01:18 AM
  #103
so i dont need to replace any seals or anything?
Old Jun 13, 2010 | 11:55 AM
  #104
SPIKES's Avatar
2019 S63 COUPE
i have a new in box behr radiator for sale..
http://miami.craigslist.org/brw/pts/1789635550.html
Old Jul 28, 2010 | 07:20 PM
  #105
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Hey guys....need some help identifying if this is a Valeo or a BEHR radiator. Ive tried looking for the label but cant seem to find it. I do some wavy crimping, so its most probably a BEHR but it would be awesome if someone who knows what to look for can confirm.
Pictures are here -->
https://mbworld.org/forums/4178041-post54.html
Thanks.
Old Jul 29, 2010 | 05:19 PM
  #106
jcnash's Avatar
*bump*
anybody??
Old Jul 31, 2010 | 01:57 AM
  #107
victorb623's Avatar
c240
I ordered my radiator from www.autohausaz.com. It is also BEHR brand. To my surprise, it is made in Germany.
What do you guys think? Am I just lucky?
Old Feb 25, 2011 | 07:53 PM
  #108
timmieng's Avatar
c230 2002 Kompressor
Originally Posted by saetneta
Hello all - I have a question that I hope has a simple answer. I noticed today that I have a pretty steady leak of the red automatic transmission fluid leaking from the connection where the transmission cooling lines join with the radiator.
The metal hose goes into the radiator and there's a plastic housing that has a metal clip that seems to hold the hose in place. I've taken the clip apart and moved things around, but can't seem to find how to tighten the connection between the metal hose and the radiator.
Here's a pic. The connections are on the back side of the radiator on the left hand side of the car when you're facing the engine from the front. You can't see the metal tube, but it connects to the metal joint and runs back to the transmission.
Has anyone ever had this issue? Any ideas on how to tighten the connection to stop the leak?
Thanks!
Hello, I have the same issue where ATF is leaking out of the radiator cooler lines. Can you tell me how you fixed this issue. Do I have to replace the radiator or simply an o ring?
Thanks.
Old Feb 26, 2011 | 10:20 AM
  #109
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
behind that metal clip, there is an o-ring. At minimum, you will need to replace that o-ring. We can't tell with confidence whether the replacement of that o-ring fixes the leak. You will have to replace that o-ring to find out.
If the leak continues even after the o-ring replacement, then you may need to replace the radiator. If I were you, I'd start with the o-ring. It's only a couple of dollars (and some trans fluid).
Old Feb 28, 2011 | 08:59 PM
  #110
pejaife's Avatar
2014 E350 4Matic
The O-ring does not fix the problem.I had the same problem last spring and was lucky i caught it on time on this forum.Replace the radiator with the BEHR brand and replace your transmission fluid, filter and gasket.There is a DIY radiator R&R on this forum done by Splinter and transmission fluid,gasket and filter replacement at Installuniversity.com.It's all pretty straight forward.Do it before you blow out your tranny as the antifreeze is already contaminating your transmission fluid.Good luck!
Old Mar 2, 2011 | 06:26 PM
  #111
OneOfaKindTrini's Avatar
Nike Turbo Shox
I love how our cars have a 3 piece rad support.. That RAD!
Old Mar 10, 2011 | 10:36 PM
  #112
Apox's Avatar
'03 C32 AMG
Saw in the carfax that my '03 C32 had it's radiator replaced at 40.000 miles or so. Just went outside to check it, and it has a Valeo manufactured 07/07/04
Any thoughts on this? Could this be to a previous contamination, and with the newer Valeo could this still be an issue?
Old Mar 11, 2011 | 08:36 AM
  #113
Glyn M Ruck's Avatar
Super Moderator
Not all Valeo radiators leak. Your new one is probably OK. Old one was found faulty. Only way to check is to take a transmission fluid sample & have it analysed for glycol.
Most move to the Behr radiator because it never gives trouble.
Old Mar 11, 2011 | 06:41 PM
  #114
NOCSUCOW's Avatar
C230
I just finished working on my 2004.0 C230 and took the cover off from the bottom to check the radiator manufacturer.
I couldn't find any label except a sticker
Daimler Chrysler
A 203 500 0000
0101 087 0000
U32 - 3140
ZGS 008
I know Behr was the other brand to Valeo, is this another?
Old Mar 11, 2011 | 07:28 PM
  #115
pcy's Avatar
pcy
Originally Posted by NOCSUCOW
A 203 500 0000
EPC says the above listed part is "CHARGE AIR COOLER".
To find out the manufacturer for the radiator, look on the top of the radiator (immediately below the cross-member on top of the radiator).
Old Mar 11, 2011 | 10:37 PM
  #116
splinter's Avatar
Super Moderator
+1
A test for glycol contamination is advisable before preemptively ditching a Valeo.
Mr. Ruck is correct to recommend retrofitting a trouble-free Behr should replacement be deemed necessary.
Purely coincidental that they’re manufactured in South Africa. ;)
Old Mar 12, 2011 | 10:19 AM
  #117
Super Moderator
To "Deutsche Normen" ya!
Old Mar 17, 2011 | 09:30 AM
  #118
NOCSUCOW's Avatar
C230
I looked under my cross memeber and couldn't find a sticker designating the manufacturer. However, the air ducts were blocking me from seeing what was underneath those.
Anyways, my end tanks are crimped just like the above picture. Is it safe to say that my radiator is NOT valeo? Where would the sticker for the Behr brand be?
Old Mar 17, 2011 | 03:28 PM
  #119
samaritrey's Avatar
Super Moderator
THE C350
BTW this is on the driver side
Old Mar 18, 2011 | 08:08 AM
  #120
NOCSUCOW's Avatar
C230
^ awesome, I saw my sticker, says BEHR
Old Mar 18, 2011 | 10:26 AM
  #121
Super Moderator
Old Mar 18, 2011 | 12:53 PM
  #122
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
+1
I'd ditch it anyway. $150 for the piece of mind of a properly sorted radiator that won't kill your car. Priceless.
Here's a pic of what the Behr logo may also look like if it wasn't made in Glyn's garage.
Just a "B".
Old Dec 6, 2011 | 12:47 PM
  #123
lclarkc32's Avatar
2002 C32 AMG
More difficult than Splinter's instructions indicate
Splinter's step-by-step instructions make it sound a lot easier than it really is. At one point his instructions say "Pull the radiator/cooling fan assembly up and out." What a joke. At that point it took me about 2-3 more hours of futzing, grunting and groaning, pushing and shoving, scratching my head and pulling my hair out to get the radiator removed. Maybe splinter's old radiator wasn't attached properly, because he didn't make any mention of the other four places in which the radiator is attached to the A/C "radiator" and other smaller "radiator" in front of the A/C "radiator". If I didn't already have the new Behr replacement radiator to look at I don't know if I would ever have figured out what was preventing me from "Pull[ing] the radiator/cooling fan assembly up and out." On each side of the coolant/ATF radiator there are two more sets of interlocking tabs/hooks that attach the radiator to the A/C "radiator" and the small "radiator" in front of the A/C "radiator". The first tab/hook on each side is about half-way between the top and bottom of the radiator. The bottom tab on each side has to be pushed UP to disengage it from the radiator. This isn't easy. Once I was able to figure out how it all connected together -- by looking at the new radiator because you can't see it from above or below -- I was able to disconnect the bottom tabs with a screwdriver pushing up from below while simultaneously pushing/pulling the radiator toward the engine. In addition, the fan wiring harness is attached to the fan assembly at three points with tie wraps that have to be cut in order to free the fan wiring harness from it. If you don't do that, it won't come out. Even when you do finally get all the tabs/hooks/tie wraps disengaged/cut, it still takes a lot of grunting and groaning and pushing and shoving to get the radiator out. Getting the new radiator back in isn't much easier because in addition to getting all the side tabs/hooks re-engaged, there is also a "tab A into slot A" at the top and bottom of the radiator and fan housing that need to be engaged. That makes eight separate things that have to be fully engaged more-or-less simultaneously to make sure everything all goes back together correctly. Reassembly is made easier if you remove the screen/grill that is just below and behind where your front license plate is installed so you can get one hand on the small "radiator" in front of the A/C "radiator" so you can keep it from sliding forward while you're trying to get all the tabs/hooks to reconnect. Removing that screen/grill is fairly easy. There are four "slide-in" connectors that the screen/grill slides into. You'll need a small screwdriver that you can poke through the screen/grill and depress small tabs that lock the screen/grill into the attachment clips while you pull the screen/grill out (forward) with a pair of needle-nose pliers. When you're all done, just push the screen/grill back into the four connectors until the tabs click into place.
Reattaching the hoses to the new radiator is a beyotch unless you moisten the o-rings with a bit of antifreeze or ATF fluid (depending on which hose it is). By the time you're ready to attach the hoses, there isn't enough room left to enable you to get enough leverage to fully insert the hoses into the radiator unless you lube them up a bit.
It is a good idea to remove the screw directly in front of the windshield washer fluid reservoir cap. That will enable you to pull the hood lock cable out with the radiator support assembly/bracket. If you don't do this, the radiator cable will pull out of the radiator support bracket when you "lay the radiator support assembly aside". Splinter doesn't mention this.
Also, regarding finding the Valeo label on the radiator. It is at the top-center (left-to-right) of the radiator. It'll be easiest to see if you remove the top radiator support bracket AND use a moistened cotton ball or Q-tip to clean the dust/dirt that accumulates on it. Once you do that it'll be easy to see the word "Valeo" on the label.
I ordered the new Behr radiator from autopartswarehouse.com. It took three weeks to receive it from them. They apparently had to order it from Germany and then shipped it overnight to me once they received it. Unfortunately, they didn't provide any indication that this was the case, so I ended up calling them about a week after they charged my credit card to see what the status was. The customer service rep told me it had shipped that day, but didn't tell me that it (apparently) shipped to THEM that day (I really think he was just blowing smoke up my a**). A couple weeks later I was going to call them and cancel the order on the same day that I finally got a tracking number from them via email. So, if you order a replacement radiator from them or anywhere else on the internet, be prepared for a bit of a wait before you receive it.
I also installed new radiator hoses. I was able to buy the upper hose online (from rmeuropean.com, IIRC) for about $40, but I was unable to find the lower one online anywhere. So I ended up buying it from the local MB stealership: Mercedes Benz of Westminster (Denver, CO). That validated something I already knew. Never, never, never do business with them. Two reasons: 1) The parts guy, Bob, told me they would have the hose for me in two days. Two days later (Friday) I called them, no hose. Monday for sure, he says. Monday, no call from them. No hose. Tuesday, I called MB Denver (formerly Murray Motors Imports) to see if they might have one in stock. They didn't have the hose either, but they told me where in the U.S. there were six of the lower hoses, including one at MB Westminster. So, I had to call MB Denver to find out that my hose had arrived at MB Westminster. MB Westminster never did call me to let me know they had it. Reason #2 to never, never, never do business with MB Westminster is because their price ($120) for the lower radiator hose is $40 more than the price at MB Denver. So, if you have multiple MB stealerships in your area it pays to call around before you place an order with an MB dealer.
Old Jan 19, 2012 | 12:08 AM
  #124
hahaitzmickey's Avatar
C230K Sedan
I'm glad you posted this. I'm stuck on m271 right now. I'm at the very last step where you grunt and moan . I have the instructions from MERCEDES STAR website. You got to take the fan out first and then pull the radiator out. It is a B*tch pulling this thing out. I quit for tonight, I'm going to attempt it agian in the morning. I will use a long flat head to push up on those botton tabs tommorrow to push it up . Everyone was pretty much easy taking things out up until this part. Where the hidden tabs are down below on both sides.
I hope someone has figure out a easier way to do this. Needs to post it.
Old Jan 19, 2012 | 06:53 AM
  #125
phoenix_iii's Avatar
2007 ML350
I agree. We need a step by step with pictures.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
