Help needed with installation of Audio 10 CD!!!
Old Nov 22, 2002 | 08:38 AM
uk_c200k's Avatar
MB C200K '2001
Lightbulb Help needed with installation of Audio 10 CD!!!
Hi all,
I have just brought an MB Audio 10 CD player from eBay. It is from a MB dealer in Germany, and he has told me it needs to be fitted by a MB dealer as it needs a code....
I thought it would be a stright swap for my old cassette player for the cd unit?
Does anyone know anything about this...
Many Thanks
here is a picture of the uni!
Old Nov 22, 2002 | 08:49 AM
DtS's Avatar
DtS
C200 Kompressor
MBworld member session put up an excellent installation guide with pics and everything. Check it out:
Audio 10 installation guide
Old Nov 22, 2002 | 10:30 AM
peet's Avatar
09 C63
But to answer your original question... no there is no code. Just make sure you do NOT power up your car with stuff disconnected. Members have reported that this required their fiber loop to need resetting - then you do have to go in.
Otherwise, see post above and follow instructions.
Have fun!
Old Nov 22, 2002 | 11:04 AM
amiras's Avatar
11' E-350 BlueTec
As Peet mentioned no code is required. Just plug and play !!!
I did it myself and work perfect. No dealear involved at all.
Good luck!
Old Nov 22, 2002 | 11:12 AM
uk_c200k's Avatar
MB C200K '2001
Thanks for the quick replies, that guide is very detailed!
I asked about a code, as the dealer I brought it from in Germany said it would require a code? I did not know what he met by that!
I thought it would be plug and play! ... thanks I will keep you posted on any developments..
Do you guys have any tips on installations not mentioned in the guide?
Old Nov 22, 2002 | 11:38 AM
jlm's Avatar
jlm
Actually, what many members have posted, and what I experienced as well, is that you STILL need to go in to the dealer to have the communication loop re-set in many cases. My Audio 10 won't play (no sound to the speakers) unless I fiddle with turning it on, or turning on the car, or back-and-forth, until I hit the magic combo for that particular time. Since my car is currently in the body shop, I haven't gone in to have the loop reset, but I will, and from others' experience that will fix the issue.
jlm
Old Nov 22, 2002 | 01:32 PM
Buellwinkle's Avatar
If for any reason it says PROD on the display, they tried to install it in a non W203 car and the radio is locked out. Return it or pay Becker to reset it. I did it on my Audio because I was playing with it, took 3 months to get it back from Becker.
Old Nov 22, 2002 | 06:54 PM
Lynn's Avatar
And it still says PROD. Oh,well.
Old Nov 22, 2002 | 07:38 PM
uk_c200k's Avatar
MB C200K '2001
I hope my unit does not say 'PROD' !!!
I guess I will have to wait and see.....
Does anyone know about the 'communication loop re-set '???
thanks
Old Nov 23, 2002 | 03:36 PM
antonio's Avatar
2002 C240 Classic
is there a security code for the standard am/fm/cassette player. i believe there is, but i don't have any card in my owners book. do you all have a card that says the code?
Old Nov 23, 2002 | 04:22 PM
Lynn's Avatar
There is no code for the cassette player, either.
Old Nov 23, 2002 | 06:18 PM
uk_c200k's Avatar
MB C200K '2001
antonio: I dont have my unit yet, so sorry i can't help!
