?? about DIY C230K oil change
The filter only came with one o-ring, the one for the filter cap. Do I need more o-rings?
Any other tips from those who have done it?
It also show only 6 quarts of oil. You might want to put in 6 wait a few minutes and check the dip stick.
* I read somewhere that the topsider actually gets more oil out than draining does. I am skeptical about that, but we'll see.
Why are you skeptical, that is how your dealer does an oil change.
That is why you should be even more skeptical.
I'm sure it might be capable of removing more oil, but you have to get the tube in the right spot to collect all the oil. I heard that MB's oil pans now have a low spot right where the dipstick comes down and the tube will go straight to that low spot and collect almost all the oil. I don't know how true that is. But, yes, the dealer does it this way for speed, not effectiveness.
We got over 7 qts out.
Which is about what you would expect if you were to drain it for 2 or 3 hours.
Also when the oil filter was removed, we were able to suck up the remaining oil in the housing using the topsider.
Total time to change oil was about 30min because it was the first time we used it and we didn't know you were supposed to keep pumping.
as an experiment we opened the drain bolt to see if any more oil came out and in about 10min we got 1/5th of an oz at best.
But YMMV
I'm pleased with the results.... a very easy DIY project.
I got my Topsider ($44.99) at Overtons, a boat supply place. It works really well.
http://www.overtons.com/cgi-bin/over...il.cgi?21664++
I also used this web page as a guide.
http://www.leonoff.net/pages/slkpages/oilchange.html
On the Coupe, the cover that conceals the oil filter is held on by spring clips, and just "pops" off. Most cap-style filter wrenches can get the cap off - my size #7 was a little too big.
It's a fun project for we "tinkerers".
If from the dipstick tube, can you measure your topsider's clear vacuum hose and tell us what outside diameter it is? That Dipstick tube is not very big in diameter.
I siphoned from the dipstick tube. It's skiinny, but the Topsider's probe is only about 6mm (roughly 1/4") in diameter. (outside diameter)
It takes a good 10-15 minutes for it to suck all of the oil out, but the hose is clear, so you can see what's going on.
glad to be of help,
Josh
Hand Pump:
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
Compressor:
http://www.griotsgarage.com/catalog.jsp?SKUupsell=10186
These seem really nice - especially the pneumatic one.
Also - any leads on dipsticks costing less than a wheel?
