Has anyone droped their car with Bi-xenons
I am about to drop my car with H&R cup kit. Someone told be that after i drop my ride I would have to level my Bi-xenons, cause after the drop they will be aiming to the floor and not the road in front. Anyone had this experience. Please help.
Does yr car have Xenons now? If yes, your auto leveling will do the job for you. If not, you can adjust it manually.
The question is now "what happens when the suspension is changed and one end is changed more than the other?" Or more precisely, does the auto-leveling system recognize the change and re-aim the headlights or does it only respond to changes in attitude cause by changes in weight? The system could be designed either way. Until an MB tech tells us that the system will respond to the suspension change, it is safer for you and other drivers to assume it does not. Another consideration is, if it does respond to the suspension change, will it still have enough range left to respond to weight changes?
You can aim the headlights youself. There are instructions on the internet and I think I posted a link on this forum once.
The lights are set with a downward angle. Lower your car and that angle would need to be adjusted to achieve the same throw (forward end point).
If you think you still want to adjust your head lights, because you thin k they should be lower or higher, you got a black screw near the top of your headlight. You'll be able to adjust it with a screwdriver. Just do it at night, or in a dark garage or room, and you'll be able to do it easily.
Most drops done on this forum drop the tail too far & this would require lights to be recalibrated.
Cheap option is to do it manually by trial & error.
These cars are supposed to be nose down for correct aerodynamics & minimum air going under the car. Look at a side on pic of FrankW's car. That car is perfectly set up. Most cars here are over dropped in the tail for good handling.
With H&R springs I suggest you check everything after a year of use. They are inclined to settle.
When lowering a car the front & rear autoleveling sensors should be recentered & the BiX recalibrated. Otherwise they can read greater deflection on rebound than on compression.
maybe theyre not DEAD on but what i mean, is my lights to me, dont shine high or low after lowering, they still light up the road perfectly and i didnt notice a difference
