Tein coilover owners please come in!
Old Mar 5, 2008 | 01:23 PM
dblock2151's Avatar
Hey everyone, my rims from DPE should be here soon, which means I'll need my coilovers even sooner. For those of you with the Tein Basic and Tein SS, if you can tell me what you think of your coilovers, I would greatly appreciate it.
The main reason for making this thread is because I've heard from a few Tein owners (on this forum) that their coilovers squeak, and it's pretty annoying. I wanted to get the KW's, but I hear they may not clear my wheels because their springs are longer, which will cause them to rub against the tires.
Any help and input regarding the Tein Basics and SS would really help me out a lot.
Thanks in advance!
-Amar
Old Mar 5, 2008 | 01:35 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
even my BIlstein PSS9 squeak, i think is the bushing not the coilover
Old Mar 5, 2008 | 01:37 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
My CO's do not squeak.
What else do want to know?
Old Mar 5, 2008 | 01:54 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
no sweaks on mine...
Old Mar 5, 2008 | 02:10 PM
dblock2151's Avatar
Main issue was the squeaking, how low can you guys go? Enough to tuck?
Thanks again!
Old Mar 5, 2008 | 02:18 PM
SeanSBA's Avatar
2001 c240
do you have the basics or superstreet? also, how long have you had them on the car?
Old Mar 5, 2008 | 02:46 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I installed my teins, then after a few months of driving, I started to have squeaking sounds coming from the rear. I took apart the rear suspension and reinstalled it making sure everything was clearing all other suspension. The squeak persisted. I figured it couldn't be the coilovers and sprayed some silicone lubricant on my rear sway bar bushings and the noise went away. I had to replace the bushings. So I bought a new Eibach rear sway bar that came with bushings and now I'm squeak free!
I think that changing the suspension will inevitably create more stresses on other parts of our "older" cars which will cause noises and faster wear, thus other suspension bushings/parts should be investigated in addition to the basic coilover clearances/rubbing.
Old Mar 5, 2008 | 09:36 PM
dblock2151's Avatar
Ahh, sounds good!
And hey, from you're sig your car looks pretty low, is that the lowest the basics go?
Thanks again.
Old Mar 5, 2008 | 10:05 PM
romz's Avatar
2001 C240
https://mbworld.org/forums/showthrea...345&highlight= check that thread I dont think you can take it any lower than that.
Old Mar 5, 2008 | 11:28 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
basic and SS has no difference in height adjustability.
personally I like the SS more because you have the damper adjustability. just ask those who have sat in my car when sometimes I had it adjusted soft and sometimes hard.
currently I have my front set softer than the rear..the only reason is my rear sway bar murders my endlinks way too fast because of the stiffness and the way I drive.
Old Mar 5, 2008 | 11:55 PM
dblock2151's Avatar
Awesome, thanks for the feedback everyone. I'll be buying the SS right after I get my rims. Anyone know a sponsor with the best price on the SS?
Old Mar 6, 2008 | 12:58 AM
lancemb's Avatar
03 c240
+1
Old Mar 6, 2008 | 02:07 AM
outaurleague's Avatar
w211 e500
going good. Drastic drop!
Old Mar 6, 2008 | 02:34 AM
TruTaing's Avatar
Moderator Alumni
w203 m112
Ahh, sounds good!
Thanks again.
No, I could be lower IF I had gotten better tires w/ rounded side walls... The front could probably go down about another inch while the rear could probably go down about half another quarter or half inch.
Old Mar 6, 2008 | 10:29 AM
jay_mark_paul's Avatar
Mercedes C230 SS Komp
No squeaking here either. Had some clicking noises coming from the front after the install. Just had to retighten the front sway bars.
Old Mar 6, 2008 | 12:19 PM
dblock2151's Avatar
Now that I'm thinking of it, I'll probably never change the dampening on the ride, how is the ride with the Basics?
All I really want is less body roll, and a firmer ride than the stock 230SS suspension. This summer I'll be getting sway bars, so it should take care of most of the body roll.
Thanks again!
Old Mar 6, 2008 | 12:54 PM
Blake P's Avatar
'09 A4 S Line
It's been 2 years and 40k miles... no squeaks so far!
Old Mar 6, 2008 | 01:15 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Its pretty darn firm... I live w/ it. Heck, I think it could be firmer :x There is plenty less roll, but sway bars in addition to the basics reduce roll by ALOT.
Old Mar 6, 2008 | 01:20 PM
D_Star's Avatar
05 CLK55
are you getting the GT7? good choice
Old Mar 6, 2008 | 01:22 PM
WaveyKat's Avatar
Something Slow
GET KW-V2 the ride is sweet!
Old Mar 6, 2008 | 06:16 PM
dblock2151's Avatar
Yep, actually doing something most people on here would frown upon.
I went with a 20" DPE GT7's (20x8 fronts, and 20x9.5 rears), stepped lip, brushed aluminum, rivetless. The main reason I asked whether or not the Tein squeaked was because I heard they fit better than the KW's, and I need all the clearance I can get with the 20's.
I promise the car won't look ghetto!
Old Mar 6, 2008 | 07:43 PM
Read sig
About 1 year or so.
Old Mar 7, 2008 | 01:47 AM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
Mine is fine
