C24Owner's cracked out 4MATIC thread
#177
autolumination.com
scroll down until **NEW High Powered 9 Led SMT Festoon
They are $9.99 each
If you only install the license plate light, they will give you an error and will flicker. But if you attach the other bulbs you'll be fine. You can buy the tail light bulbs at autozone for $16
Yes, the 4matics have the calipers mounted on the leading edge of the rotor. Looks a bit strange on an MB but if you look at other makes, a lot of them are in the same spot. Not 100% sure why, but I think it deals with cooling.
Thank man.
They are $9.99 each
Thank man.
#181
#190
Thanks guys.
Now I am torn between doing a black suede headliner or dark gray.
I can get the black alcantara for fairly cheap, which is causing me to lean toward that direction
#191
#192
Some better pics of the seats.
I wasn't sure what to do with the doors. I know I didn't want to dye the leather black, so I painstakingly dyed the threads in the center.
I am probably going to remove the CF vinyl and leave the wood the way it was (piano black) and dye the lower portion of the door.
Option 1
Option 2
Option 3
I am leaning toward option 3
Option 1
Option 2
Option 3
#197
not so sure about doing the storage part of the door. it's the same material as the roof liner. imo you should suede it out instead because paint that type of material is pretty easy to get F-ed up.
#198
#199
As for painting it, I would use an airbrush and the leather dye. The leather dye is water based so once it is applied the water will evaporate and will leave the dye embedded into the fabric. Its holding up pretty well on the leather, so it should be fine on an area that doesn't get a lot of abuse.
