Non-metallic tint and still have problems
Old Mar 20, 2008 | 10:22 AM
Liqued12's Avatar
2002 C230 Coupe
Ok so I just got my windows tinted a couple weeks ago. I read up and found out not to get metallic tint. So I went and got them tinted. I still have the issue of my Remote and radio stations not working, everything was fine before the tint. Anyone have any tips. The place I got them tinted has never had the problem before, and said they can pull it off and re-do it with a diffrent type and see if it helps,but I wanted to find out if there is anything more I should know before I do this, like something else to check.
Thanks for the info in advance.
Old Mar 20, 2008 | 11:01 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
which tint did u get exactly?
Old Mar 20, 2008 | 12:11 PM
itswindee's Avatar
that red one
DID or DIDN'T you get the metallic tint??
Old Mar 20, 2008 | 01:43 PM
esemes's Avatar
2007 c230
did you get ceramic tint? (are you sure?)
i have reg. lumar (ti metallic, i believe) tint and have no radio issues at all
Old Mar 20, 2008 | 02:11 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
they wouldnt have damaged the amp in the rear headliner would they?
Old Mar 20, 2008 | 02:13 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Bingo
Old Mar 20, 2008 | 02:18 PM
jfabes's Avatar
'07 GTI & '04 M3
I have metallic and no problems...20% rear window, 30% on the sides.
Old Mar 20, 2008 | 05:01 PM
06c230hwd's Avatar
06' C230SS
assuming it is truly non-metallic tint - if you have any luck at all.. the module that is probably soaked with their solution will most likely dry in a few days and your functions will return to normal
Old Mar 21, 2008 | 08:43 AM
deloreandriven
Guest
Posts: n/a
Originally Posted by johnand
Bingo
we see this all the time on a coupe.......the water runs down to the top of the hatch when open and they are tinting, the water cooks the antenna at the top of the hatch.......
get to a dealer right away and get them to get a quote to replace the antenna and go after the tint guys..... the shop in our area came good for the ones the killed.
i think the antenna is like 600 dollars and its a pian in the @$$ to replace because there is very little room between the glass and the hatch to actually get in there and work but it can be done.... i've replace about 5 from bad tint shops.
Old Mar 24, 2008 | 09:55 PM
Liqued12's Avatar
2002 C230 Coupe
Oh gezz not what I wanted to hear. Should I even bother with having them replace the tint? Wonder if I can actually get them to replace it. Is there a way to install a hidden aftermarket one? And to answer the question about the tint, it is NON Metallic tint, as said in the title of the thread.
Old Mar 29, 2008 | 02:02 PM
deloreandriven
Guest
Posts: n/a
no you cant do an aftermarket one ... the factory one has contact points to the rear glass because the actual antenna is in the glass. the part that cooks is more of an amplifier / converter. It runs the whole length of the glass along the top with many different plugs in it. all the contacts / plugs are actually on the left side of the hatch. if you pull off the plastic covers you will see them and the said antenna along top of hatch.
the tint being non metalic will only help for your radio reception. but since its cooked the antenna im guessing that you door lock's work like crap unless you point you key @ the IR sensor in the door handle and your radio recepion is basicaly gone?
Old Apr 8, 2008 | 12:26 AM
Liqued12's Avatar
2002 C230 Coupe
Exactly.... Looks like I have to go in and talk with them about this. Thank you all for the info.
Jason
Old Apr 8, 2008 | 04:23 AM
spyderpig's Avatar
'02 CL203 M111
Still haven't replace mine, stealer quoted $1300 total.
Seems like I couldn't pop out the plastic cover without breaking something...
Any suggestion?
Old Apr 8, 2008 | 04:27 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Any suggestion?
I waited years to find a tint shop that had a clue about tinting a C Coupe.
Old Apr 8, 2008 | 07:29 AM
Midnight Koop's Avatar
CL203
I had this problem when I got my car tinted, but thank god I was able to trick the stealership to fix it under warranty.
The total cost would have been around 1300-1400 because they claimed they had to also replace the entire rear glass along with the antenna.
I ended up getting a discounted upgrade on my tint after I complained to the tint place.
The problem wasn't metallic tint... it was the fried antenna like they said above.
Although, I think it shouldn't be that hard to install yourself. I was up late last night installing a reverse camera and ended up taking off all the back panels and moldings on the hatch for the first time. It wasn't so bad actually and I happened to pass the antenna while tracing the wire back through the hatch.
Order the part from OEMpartsdirect.com and install it yourself.
Old Apr 8, 2008 | 11:05 AM
spyderpig's Avatar
'02 CL203 M111
So how do you take out the plastic covers of the hatch?
and does anyone know the part# for that amp/antenna???
Old Apr 8, 2008 | 12:57 PM
CL203
in a jist... with the hatch open:
-removed the black "push-pins" & torx screws on the outside edge of the hatch (furthest from the car)
-removed the small plastic panel on the top/inner hatch (closet to the car) to reveal two more torx screws (and removed them)
-then snapped out the center panel at the top of the hatch (closet to the car)
-then the side panels snapped out in the direction towards the center of the rear hatch glass
-then removed the molding furthest away from the car at the bottom of the hatch.
*after the initial pushpins and torx screws are removed, all the panels are able to be snapped out... but as a caveat, work slowly and make sure you use a plastic wedge to go slowly and check frequently that you are pulling out in the correct direction so as not to break any of the plastic tabs holding it in place. or you might break a few like i did last night but they're fixable
goodluck!
Old Apr 8, 2008 | 03:05 PM
spyderpig's Avatar
'02 CL203 M111
goodluck!
Many thanks, I'll try this.
Now I'll need the part# anyone can help?
Old Apr 8, 2008 | 03:39 PM
fresh240's Avatar
c240
i got my windows tinted and they should of told you it would interfere with signals 3m does not interfere and will not fade to purple
Old Apr 8, 2008 | 05:21 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Non-metallic tints fade over time.
I have metallic tint on mine and NO problems at all.
Old Apr 9, 2008 | 02:54 PM
Liqued12's Avatar
2002 C230 Coupe
This would be good
Old Jun 14, 2008 | 03:51 PM
Liqued12's Avatar
2002 C230 Coupe
Thought I would give an update on the situation. Problem still isn't fixed yet but getting closer. The tint company was very kind and sent the claim to insurance. I went to the dealer and got a quote to fix it. I now have a check from safeco for $1024.72 in my hand. I think I am going to fix it myself though. Where is the best place to get this part? Any places to get a discount. The part number is 203-820-28-89 $521.40 from dealer. Doesn't look to bad to install either. Just pull it out and get that double sided tape off then unplug the wires and put the new one back in with sound double sided tape.
Anyone parting out a coupe and still has this in the rear hatch?
Old Dec 28, 2009 | 10:24 AM
cinnamonx72's Avatar
2004 C230K coupe
son of a *****, i think i found my problem...
horrible reception & the smartkey being suddenly "stupid" all after getting the windows tinted. initially, i thought it was the degree of tint (5%) and type (titanium), but after reading this and applying the logic, that the tint shop fried my antenna makes perfect sense.
i know i'm more than a year late in this, however:
liqued12, did you ever get this resolved?
midnight kompre, do tell of your stealership trickery?
