Radio removal in an '06 203
The ash tray, radio, hvac control panel, hazard light control panel, and vents are all separate pieces of course!
https://mbworld.org/forums/c-class-w203/197530-diy-head-unit-install-w203-05-center-console-removal-instructions.html
Thank you for your reply.
There is no one-piece surround. Can you explain what you mean by that?
There are no torx screws at the top of the vents! There are clips up there, after unclipping them you can get to the torx screws which are on the BOTTOM!
I think you should very carefully re-read the thread because you seem to be confused.
However, it was all to no avail. What I was attempting to do was install an FM converter in the antenna line so my wife could use her Ipod in this car. Not elegant, but simple. Upon removing the radio, I found out that Mercedes does not use a "traditional" antenna plug.
I found this FM modulator on another thread in this site and ordered it from Installer.com. I hope they have an adapter, or will take it back.
Anyway, thanks for the great help!
shout out to nlpamg <3 for sending me his broken one! you can't beat free!
I pulled up the step plate, dug around and found the white plug (I hope the black one was not plugged into anything, as it is not now!)
Today, I ordered the harness from my dealer ($35.00) and was assured that it would be in tomorrow. I'll give it a try, and hopefully this will be the end of this project.
Since I have already removed much of the console, I think I'll try to run the plug to the ashtray. The IPod will be more convenient there since the on-wheel controls will not work with this setup.
Thanks again to all who have been so helpful
When I contacted Installer.com about a return, I was told that they only exchange, and do not refund. Since I had purchased the AUX cable from Mercedes, I had no need for the converter, or any other parts for that matter.
Additionally, on an exchange, Installer.com deducts 15% as a "restocking fee" and of course, you get to pay the retun postage.
Well, I guess there's always e-bay!
Better KNOW what you need for sure before ordering from Installer.com...once you do, it's yours.
