lb-ft to kW conversion
Old Dec 3, 2002 | 03:00 PM
Harris's Avatar
According to MB, the C230Kompressor has 200lb-ft of torque, what does it convert to kW? Anyone has the formula handy? Thanks!!
Old Dec 3, 2002 | 03:06 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
its actually 207ft/lb and also i think u can only convert hp to kw....not sure.
Old Dec 3, 2002 | 03:09 PM
Clownburner's Avatar
2002 C230K Sportcoupe
Yes, your units are confused a bit.. HP converts to kW.
Torque can be converted to Nm, which is the usual metric unit. 207 lb-ft converts to 280.692 Nm.
See this for a nice conversion table.
Old Dec 3, 2002 | 03:39 PM
Harris's Avatar
Ooops, sorry, I was reading several lines at the same time. My mistake, I meant lb-ft to Nm...
Now I understand, thank you very much!!:p
Old Dec 3, 2002 | 03:40 PM
MacPhisto's Avatar
From MBUSA's current website:
Engine and Drivetrain
Engine 1,796-cc intercooled supercharged DOHC 16-valve inline-4 with dual balance shafts. High-pressure die-cast alloy cylinder block, alloy heads.
Net power 189 hp @ 5,800 rpm
Net torque 192 lb-ft @ 3,500 - 4,000 rpm
(The old 2.3 had 200 lb-ft of torque)
Old Dec 3, 2002 | 04:47 PM
AndrewK's Avatar
Audi S4
Kilowatts (kw) translates into horsepower, and every kilowatt is about 1.36 horsepower (so multiply the kw figure by 1.36 to get the hp)
Newton-meters (nm) are the standard measure of torque, and the each nm equals roughly .74 lb-ft. Neither of these numbers are scientific, but they will get you in the area.
Old Dec 3, 2002 | 04:58 PM
CANTOEVO's Avatar
Porsche Cayenne Turbo, 360 C.S.
207 LB-FT is the figure in the manual.
Old Dec 3, 2002 | 07:53 PM
err0neous's Avatar
02 CLK 430 Coupe
Also the JSUC:
http://malamas.com/jsuc/jsuc.html
Old Dec 3, 2002 | 10:23 PM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
torque
Actually, 280 Nm, which is....a tick under 207 lbs.ft
(See above)
The 2.3 manual has the correct figure; M-B 2002 sales literature, etc was unduly pessimistic.
Old Dec 4, 2002 | 06:11 PM
mdp c230k's Avatar
2002 c230k
Try this site to convert anything to anything:http://www.efunda.com/formulae/formula_index.cfm
You'll love it!
Old Dec 4, 2002 | 07:03 PM
I find it amusing that something as simple as a fixed conversion, agreed upon by scientific authorities around the world, can spark a debate like this.
Perhaps we should rename it to the 'MBDebateWorld Forums'
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
