DIY differential (diff) oil
Rating: Thread Rating: 4 votes, 5.00 average.
Old Apr 15, 2008 | 09:36 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Well, there's not too much to say that isn't covered here.
I finally found a shop that sold the 14mm hex socket,
Proto brand, for 22 + tax.
Oil was $12. I used Castrol GL-5 Hypoid
Just regular gear oil of the correct variety.
Considering the maint. interval is 100K miles, it's unlikely
any real benefit would be gained in the diff from synth.
My oil was black black black!
The guy who was considering doing it at 60K is probably wise.
I did put my car on ramps, and likely I didn't get every drop of the old oil.
But wtf. It's done. I used some teflon tape on the threads...plumbers tape.
Also a bit of a kluge, but again. wtf. Not likely it'll make any difference.
Didn't see any thread sealant on there in the 1st place.
All total, didn't take long. Just the setup and clean up.
Soak the bottles in a bucket of hot water, 1st making sure they're sealed real good. It makes it easier to pump.
1 tip though, as someone suggested loosen the fill plug 1st so you know it will come out. And leave it out when you drain or the oil coming out will
glug glug glug and make a mess....minor lesson learned.
Also, if you are smart, you will get bottles the oil pump can screw right into, rather than having to use a knife to cut the tops off the long style bottles.
Capacity is 1.2 quarts, which is 38.4 oz.
I think I measured closer to 40 oz to account for the oil that doesn't get sucked out of the container.
I used a plastic cup to measure out the extra 8 oz, using a measuring cup
of water, and marking the spot on the plastic cup so I wouldn't have to dirty up my kitchen stuff and toss the cup. Wiped it out real good to get rid of the water.
Then poured it into the container i'd already cut.
Not rocket science, but maybe it'll help someone.
Old Apr 15, 2008 | 10:10 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Nice work.
Mine came out smelling something awful. Know that sperm whale oil was eliminated years ago as an extreme pressure/anti-wear additive, but its replacement is NASTY.
It's best to wear old clothes (you'll never wear again!) while doing the task.
Old Apr 16, 2008 | 08:00 AM
bumpnzx3's Avatar
W203 C230SS
out of all of the smells i have encountered repairing cars- i do believe the smell of used gear oil is my least favorite.
Old Apr 16, 2008 | 02:12 PM
Well, ya know..
"It smells like Victory"
hehe yeh, and when I failed to completely remove the fill plug (loosened)
and it was glug glugging everywhere, it got in my hair, and was splashing all over, as I desperately grabbed for the fill plug, which loose, but which meant getting in close to reach it...
he he...
Really it was no biggie. Such an easy job. Using shorter bottles would make it even easier. My biggest concern was not having the full bottle fall over and make a mess, and making sure the tube stayed in the fill hole on the diff, which since my pump is about 20 years old, the tube is stiff as hell.
Here's a list of the approved diff lubes, though the specific Castrol isn't listed...I was told by the dealer, any GL5 Hypoid is fine, and Castrol makes good stuff.
I'm not sure if this list is also for the manual transmission.
Actually the only oil on that list thats sold in the US is Valvoline.
Reading the spec on the Catrol is appears to be the same stuff sold overseas, states high pressure etc.
File Type: pdf
Old Apr 17, 2008 | 05:47 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
What does used gear oil smell like? (and I was thinking of DIYing this one )
Old Apr 17, 2008 | 08:42 AM
ohlord's Avatar
Tip
on pump in the diy section
diff diy
http://www.benzworld.org/forums/w210...il-change.html
pretty much the same procedure on most models.This diy has pictures to help.
http://www.benzworld.org/forums/w210...fluid-tip.html
ohlord
note the correction to 50nm for both plugs
any good thread sealent will do.I would not use tape since you will not get an accurate torque reading.
Old Apr 17, 2008 | 09:52 AM
bumpnzx3's Avatar
W203 C230SS
don't really know how to describe it. it's not going to make you pass out or anything bad like that. it just smells foul to me. i'm just wierd- kinda like how i used to like calamari (*sp?), until someone told me what it was...
Old Apr 17, 2008 | 10:08 AM
ohlord's Avatar
I
know what you mean.However you can't batter and deep fry diff fluid
Old Apr 17, 2008 | 11:48 AM
TruTaing's Avatar
Moderator Alumni
w203 m112
Subscribed! great post
Old Apr 17, 2008 | 10:50 PM
slammer111's Avatar
What did you think it was before you knew? Sooooo good.
On that note, you definitely don't wanna food from SE Asia. Or hot dogs for that matter.
Old Apr 18, 2008 | 09:59 AM
bumpnzx3's Avatar
W203 C230SS
I didn't know what it was- and I never really wanted to ask. I used to love Clam Chowder too- until I figured out there was clam in it, not chicken i'll still eat it now, but I don't like it near as much as I used to.
All of that- yet one of my favorite foods is sushi. Go figure....
Old Apr 22, 2008 | 02:44 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Okay, im paranoid now. Gonna try and do this - this weekend.
Old Apr 22, 2008 | 09:18 PM
splinter's Avatar
Super Moderator
No worries, jOhn. It's a simple DIY.
btw, I'm still thinking about your intake project.
Old May 11, 2010 | 12:55 PM
govertime's Avatar
Did this over the past weekend. Easy job. I used Permatex High Temperature Thread Sealant on both (drain & fill) plugs. I'd recommend giving the drain plug a bit of time to cure before filling which I'd forgotten. Permatex says it cures in 24hrs but 1 or 2 should be just fine.
I used Redline 75w90 Synthetic.
I just hit 100k and the oil was nasty.
Old May 11, 2010 | 02:39 PM
skittles's Avatar
Moped
i forgot all about this... i'm almost gonna hit 100k miles and never did this...
the link on the OP doesn't work.. anyone wanna repost it?
thanks!
Old May 11, 2010 | 03:53 PM
govertime's Avatar
thanks!
Honestly you really dont need to know more than is on this page. The plugs are stupid obvious and you only need a 14mm hex bit (not socket). I'd also recommend a fluid pump. I got this one cause it was cheap and I didnt care about tossing it when i was done.
Old Aug 8, 2011 | 09:15 PM
kvidal661's Avatar
2005 c230 Sedan Sport
Does anyone have a picture of a front differential on a 2005 c230 sedan? I have no clue what i am looking for under there.
Old Nov 11, 2011 | 01:35 AM
Jerkin's Avatar
C230 Coupe Silver
id post a pic but i'm going to be crawling under a lowered car haha... does the redline 75/90 work for manual transmissions? because id love me some redline and can i just get some thread sealant at home depot? also i saw another diy like this that said to use a torque wrench to close it at 50nm... true?
Old Nov 11, 2011 | 03:40 AM
Mister Mehoff,
Call Redline before you pour the wrong crap in.;
They have a tech dept. and they will tell you what is the right stuff for your car or not.
Saved my butt a couple times.
Old Nov 11, 2011 | 05:38 AM
Glyn M Ruck's Avatar
Super Moderator
Do not use GL5 product in the MT. I would use a Merc approved product I'm afraid!
Old Nov 11, 2011 | 12:59 PM
Jerkin's Avatar
C230 Coupe Silver
The guy at redline was very nice. 70w80 MTL for manual transmission and 75w90 gear oil for differential.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
