DIY: MOLESKIN tint protection installation
Most professional window tinters out there will highly recommend this from the get-go.
Those that don't know what moleskin is, are probably not the best tinters in the profession, and I would steer clear !
Carlos
Saprissa@aol.com
no, u have to remove the door panel...
What you need:
a. Soft wedge or prybar, or a screwdriver with a semi-thick rag wrapped around it
b. T25, T27 torx screwdrivers (long and skinny to fit the holes...$6.48 at Advance Auto for a set of 6 - must have for a MB owner)
c. Clean Rag
d. Rubbing alcohol
e. Moleskin felt with high-temperature adhesive ($30 tintprotector.com)
(These instructions are for the driver door. The rest will be pretty much the same, but when I say 'lowe-left' it helps to know what door I'm talking about)
1 - Roll down the windows
2 - Unscrew the door pins
3 - Pop off the outer door handle piece: There is a small tab where you can insert the screwdriver (covered with the rag). Stick it in there and gently pop out the bottom, then use the screwdriver in the crack and work your way up. Gently pull the piece off without bending it upward.
4 - Unscrew the four screws. There is one that holds the door latch protector plate on the outer left side (where the door latch is). That one is the T25 and is silver/chrome in color. The other two screws are at the top and bottom of the door handle and under the SRS badge. These are T27 and black in color. Use the screwdriver (always with the rag, I'll stop saying that now) to pop the SRS badge off and carefully back out the screw. It's not a huge deal if you drop it, but be careful anyway. The other two are at the top and bottom of the door handle. The one on the top doesn't come out of the door panel. Just back that one off. The lower one will fall out when it's loose.
5 - Remove the tweeter cover: use the screwdriver to gently lift the tab in the lower right corner and pull the cover off. The tweeter will be attached as the cover comes loose. Use the screwdriver to undo the three tabs that hold the tweeter in place.
6 - Pop out the panel: the panel is anchored by plastic clips that pop out directly. Start in the lower left corner and use the screwdriver to pop the tabs off. Work your way counter-clockwise around and they will pop and you've got it loose except for the top edge.
7 - Lift/Pry off the panel from the top: Use the screwdriver from the outside-the-door side to gently lift the door panel out of the channel. There is some adhesive that holds it in there, so be gentle and work it out.
8 - Remove the window guard: Use the screwdriver to gently leverage (from the inside-the-door side) the window guard off of its track.
9 - Clean the window guard with alcohol, score it with light sandpaper or a blade, clean with more alcohol, let sit to dry, cut the moleskins to just a bit longer than the window guard, carefully stick the moleskin on so that it doesn't hang off of the top or bottom edge, cut with a razor blade to trim the ends off.
10 - put the window guard back in
11 - stick the door panel back in from the top (make sure you don't lock the tweeter inside the panel and line up the door-lock bar with its hole)
12 - stick the tweeter back in its mount
13 - put the tweeter cover back in place
14 - bang the clips back in
15 - screw the T25/T27's back in
16 - put the door pin back in
17 - put the outer door handle piece back on
That's it. Roll the windows up and leave them up for 12 hours (tintprotector remcommendation). After you do the driver door, you'll spend no more than 5 minutes removing any of the others. So if you're going to tint, spend the $30 for the moleskin and ~1 hour to do this yourself because most tint shops around here don't know what this is, don't understand why it is necessary, and don't want to take apart your door b/c they're afraid of messing up your MB.
thx for the link kev...
