View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Mar 1, 2008 | 10:07 PM
  #4626
06c230hwd's Avatar
06' C230SS
love them ken! ive been looking at the same wheels but in the gloss black. what size are yours? ive been looking at the 19's they got a nice lip, after seeing them on your car i need no more motivation im buying a set :-D
PM me as to where you got them!! 1100 seems the cheapest (WITH TIRES) that i have seen yet!
*EDIT* i can see yours definitly look like 19's
Old Mar 1, 2008 | 10:08 PM
  #4627
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
wow 05 stock suspension gave me the same look of Tein S-Tech spring look...
Old Mar 2, 2008 | 01:29 AM
  #4628
yeuchau's Avatar
Stage 2 C7 A6, QX60
agree, I like stock wheel better
here is pic
Old Mar 2, 2008 | 02:07 AM
  #4629
JonathanMax's Avatar
W203 Kompressor 6spd SS, Audi B5 S4
you get what you pay for
Old Mar 2, 2008 | 02:41 AM
  #4630
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
Great price! Looks good.
Old Mar 2, 2008 | 02:55 AM
  #4631
spyderpig's Avatar
'02 CL203 M111
They look good and it is a better alternative than the carlsson 1/16 BE...way more expensive! so I might not go for the carlsson...
however, Brabus_x2's moven look as cool though!
Old Mar 2, 2008 | 02:57 AM
  #4632
e1000's Avatar
a quarter mile at a time
Originally Posted by RedKen06C230
yup... i guess it was a good 1100 for everything.. thats right all brandnew w/ tires too totalled 1100
great deal on a fantastic set of wheels
Old Mar 2, 2008 | 06:14 PM
  #4633
c3232c's Avatar
02 c32 99 superduty
Nice!
I have a set of the Mandrus Stuttgard's on order. Can't wait to see how they look!
Old Mar 2, 2008 | 07:42 PM
  #4634
Endless230's Avatar
'07 C230 SS
wheel fitment question
hey i was looking at some rims that are 18x8 offset: 35 and 18x9 with the same offset in the back. Now what i was wondering is would i need to run spacers with these if so by how much? and i don't believe i would run into any other problems running this set up right?
also i know this isn't that much bigger then stock but i don't wanna have to worry about rubbing or camber kits or anything so i figured these can get the job done... oh and besides they dont carry them in 19's haha
Old Mar 2, 2008 | 09:27 PM
  #4635
RedKen06C230's Avatar
c230 06
I work for a company called Tire Kingdom... We also own NTB and Merchants Tire and TireRack... So ive got the hook up...
Old Mar 3, 2008 | 01:57 AM
  #4636
vietthug1904's Avatar
2002 Mercedes C240
http://www.mbworld.org/forums/images/smilies/nixweiss.gif
HI I got a 2002 Mercedes C240 and I just got some new Privat Reserve Wheels for it. Front 19x8 and Rear 19x9.5. offset 40.. I need help on picking out some wheel spacer for it ,How many MM should I get for the Front and how many MM for the Rear, to make it look good with out making it Rub and what kind of TIRE SIZE should I get also.. if any one know Please HELP ME!!!
Old Mar 3, 2008 | 04:03 AM
  #4637
andy_meng1024's Avatar
2003 SL55, 2010 C63
You should be fine with the size and the offset, but I'm not 100% sure tho. Others may confirm this.
Old Mar 3, 2008 | 06:36 AM
  #4638
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
once again by only mention the width and offset does not help anything. you'll need to show us the wheel you want to buy.
and LMAO at your topic...wheel filament!!!
Old Mar 3, 2008 | 11:25 AM
  #4639
Endless230's Avatar
'07 C230 SS
well i just saw them at this local shop i went to i don't exactly have a pic or know what they are called.. but i mean any general idea what is the usual range of working offset without having a problem? i'm am new to these car since i come from a world of lowered down low offset drift cars haha
and sorry meant fitment but in my defense i hadn't sleep in over 24hrs when i wrote that haha
but if i had to say they look like the ones all the way to the right but the center piece is also black
W203/CL203 Aftermarket Wheel Thread - All you want to know-modular01.jpg
Old Mar 3, 2008 | 01:22 PM
  #4640
Blake P's Avatar
'09 A4 S Line
Frank's right... wheel size and offset are important, but so are lip size and spoke design/thickness. Without that information, you're SOL.
Old Mar 3, 2008 | 01:56 PM
  #4641
itswindee's Avatar
that red one
that was mean ....although it made a point.
Old Mar 3, 2008 | 02:58 PM
  #4642
jfabes's Avatar
'07 GTI & '04 M3
on a C240, i don't think you need spacers (i'll let others chime in)....the place you bought the wheels from should be able to tell you. However, if you "want" spacers, that depends on what look you like. I'm guessing that 10mm on the front and 5mm on the back would do the trick. However, if your car isn't lowered, than rubbing is of no concern. If it is lowered, then running a 10mm in the rear with a 265 tire, you will probably rub. Regardless, if you go with spacers, I would recommend hubcentric spacers (at least for the 10mm spacer)....and be sure to get the right longer lug bolts.
As for tire sizes, it seems 235/265 is the preferred set-up, but I just posted a thread asking what advantages/disadvantages there are running 225/265.
Old Mar 3, 2008 | 03:21 PM
  #4643
Endless230's Avatar
'07 C230 SS
yeah i get what your saying just figured since the rims is the same width regardless of where the lip sits that it was enough to know with knowing the measurement of the offset since the hub mounting face is 35mm from the center line of the wheel towards the roadside (which is the +35 offset) so if the center line of the rear would be 4.5 inches in and then just add 35mm is that not a correct way to get the lip size..?
Old Mar 3, 2008 | 03:30 PM
  #4644
Blake P's Avatar
'09 A4 S Line
Nope, hub mounting surface is the back of the face... not the front. There is no way to assume how thick the face of the wheel is.
Old Mar 3, 2008 | 04:02 PM
  #4645
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by vietthug1904
HI I got a 2002 Mercedes C240 and I just got some new Privat Reserve Wheels for it. Front 19x8 and Rear 19x9.5. offset 40.. I need help on picking out some wheel spacer for it ,How many MM should I get for the Front and how many MM for the Rear, to make it look good with out making it Rub and what kind of TIRE SIZE should I get also.. if any one know Please HELP ME!!! you can also Email me at (www.Vietthug2000@yahoo.com)
for the 240 you can just get 8mm spacer from H&R all around. The rear will rub if you run 265 after the spacer. Idealy for 9.5 you want a ET35 setup, but there's no 5mm hub centric spacer. you can run 255/30/19 if you are worried about rubbing.
Old Mar 3, 2008 | 04:39 PM
  #4646
2002 Mercedes C240
Front 19x8 Rear 19x9.5 Offset40
Thank you to all of you so much , that are Help me ...
yes my car is lower with TEIN suspension. front 2.3" Rear 1.0"
and I got My RIM from E-Bay..LOL..
http://cgi.ebay.com/ebaymotors/New-P...3286.m20.l1116
when I try to put on my back Rim (19x9.5) the inner wheel lip touch the inner body.. that is why I'm asking if anyone know how many MM wheel spacer will I need to make it fit.I was thinking of 15mm Rear and 10mm Front... i don't care about what brand is. as long as it fit and i can ride on it.. and what is a good size tire in front 245/35or30 R19?? and and rear 275/35or30R19??? what do you guy think???
Old Mar 3, 2008 | 05:10 PM
  #4647
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
did you bother to read my last post? or anyone's post for that matter.
Old Mar 3, 2008 | 07:47 PM
  #4648
benzboi3's Avatar
05 C230K SS 6MT, 00 Audi TT 180Q 5MT
Originally Posted by RLPIII
They kind of look like those on your sig. pic. . . .
haha, hardly
Old Mar 4, 2008 | 05:14 AM
  #4649
cantblockme's Avatar
2007 C230 silver/black
wheels/tires questions
I drive 2007 C230 ss now with stock suspension and not planning to change that at all. My plan right now as far as wheels I'm gonna start saving up and wait until my stock tires need to be replaced then buy some new wheels with tires by then. 18" sounds like the best way to go for me since my stock ones are already 17" and 19" just too expensive for me (both wheels and tires).
Q1. What is the expected mileage for my stock tires? They are:
Pzero 7.5Jx17H2 offset 1.42(36mm) 225/45R17 91W =Front
Pzero 8.5Jx17H2 offset 1.18(30mm) 245/40R17 91W =Rear
these were info i found both on my tires and my car's manual, I hope they are the correct information.
I've driven about 15k on them so far and I want to know in you guys' opinion, at roughly what mileage I will need to replace them, so hopefully I will have enough money by then.
I visited both tirerack and discount tires websites and found two set of rims I really like. Those were meant to fit my car I supose.
ASA AR9 with carbon spoke insert
TSW Bremma 18x8 5-112 32SML
Q2: Both of these websites suggest 18x8 with bolt pattern of 5-112 for all 4 wheels. I understand my stock wheels are staggered. I need to find the staggered sets if I want to buy these wheels right? If so, what combination of front/rear width I should be looking for? and between what offsets they will fit in my car without doing anything else?
Thanks for reading, cheers!
Joe
Old Mar 4, 2008 | 06:01 AM
  #4650
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
look on your side wall for treadwear. depends on which Pzero it is it's usually 220 treadwear which means 22k miles if you drive like a grandma. they tend to last around 18k miles if you are lucky.
i like the ASA's new wheel. those free inserts are a plus so you can change the look. tireracks are idiots, period. they sell wheel fitment only to protect themselves. They don't suggest all possible fitment. If ASA does have wider width for that design in MB bolt pattern and hub find more info on it through your local tuner shops or find more info from ASA.
but NO, you don't have to run staggered setup when you change out the wheels. you can run staggered tires on non-staggered wheels, or run non-staggered tires on non-staggered wheels. all depends on how you want it to look. non-staggered setup may require spacer if you want to have that flush to the fender look since the non-staggered offset are usually setup for the front which the rear will not be aggressive enough.
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
