View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Mar 25, 2008 | 06:08 PM
  #4726
jfabes's Avatar
'07 GTI & '04 M3
Originally Posted by Benz05
Im not sure if my rims are hubcentric, i will look today.....
Will i need longer studs??
for our lug bolt thread, 12 x 1.5, you need at least 6.5 turns (at least according to H&R). in most cases with 3-5mm spacers, you can get that or more with a standard lug that the rims come with. for anything over 5mm, you will def need longer bolts. that being said, if you don't know if your bolts are long enough, get new ones, its not worth the risk.
Old Mar 25, 2008 | 08:25 PM
  #4727
Blake P's Avatar
'09 A4 S Line
Let's see pics of the wheels so we can determine if lip size, spoke design/thickness, or all of the above are what's causing the problem.
Old Mar 25, 2008 | 09:02 PM
  #4728
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by tommy
Gaiex, couple of pics, though sorry - not great ones. Mine are 18x8, powdercoated charcoal. Currently, they have either silver or black.
And one of the silver before I had it powdercoated:
HTH
OZ FTW!
Tommy, have you seen how the Ultraleggera's look on glassjaw's w210! They look amazing.
Old Mar 25, 2008 | 09:08 PM
  #4729
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by drexappeal
OZ FTW!
or this
anyway, the Ultraleggera for MB doesn't come in 18x9. you'll have to settle for 18x8 like everyone else. run a 10-15mm spacer in the rear and you are set.
Old Mar 25, 2008 | 09:11 PM
  #4730
Benz05's Avatar
Jfabes so my rims center bore is 66.6 . The front are 32 offset and rear 35
Old Mar 25, 2008 | 09:15 PM
  #4731
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Originally Posted by FrankW
or this
I was trying to keep as similar as possible than stock ET and wide to conserve the stock staggered look.
The ultraleggera are availabel in which ET? (for the 18x8) and with which tire size they have to be used? (I'm stuck with the 225x40F and 245x35 or 255x35R, other sizes are illegal here in my car)
Any pics in silver finish?
  #4732
gaiex's Avatar
By the way, any noticeable differences in performance with these ultra light wheels!?
Old Mar 25, 2008 | 09:24 PM
  #4733
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the ultraleggera's ET35 18x8. typically people run 225/40/18 on the front and 255/35/18. The C55 however has 245/35/18, so either one works. in this case the 245 would be better for the 8" width.
you can run 235 and 265 with smaller profile sidewall., but i wouldn't run 265 on the 8".
haven't seen anyone with these in silver. most are in black.
there is a dramatic difference in shedding weight from the rims. you get better turn in response, less weight at each corner of the car means better handling, better acceleration because you are spinning less weight, and better braking. all of this may be small change, but you will definitely be able to tell.
Old Mar 25, 2008 | 09:33 PM
  #4734
gaiex's Avatar
Originally Posted by c_brabus
brand: BBS
style: RA
color: silver
offset: ???
tires: Toyo T1 proxes
suspension: H&R coilover
https://mbworld.org/forums/attachmen...7&d=1142585858
https://mbworld.org/forums/attachmen...8&d=1142586072
OK, these I like
Why using 18 and 19"???
How much do they weight?
I can't find the sizes and ETs available on BBS website, any where to see it?
My choice for now: OZ ultraleggera, BBS RA, BBS CV
Old Mar 26, 2008 | 02:24 AM
  #4735
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
OK, these I like
that's a typo...lol it's 18x8.5 and 18x9.5.
the RA is discontinued btw. some ppl may sell them used from Audi guys tho. Vadim had it, but only one front and one rear are still good. c_brabus also got hit and run on the freeway and spun his car into the wall which left the whole front end destroyed, so only two rear ones are good on his car still. lol
those were ET30 front and ET32 rear i think. i went to pick it up with him.
Old Mar 26, 2008 | 01:15 PM
  #4736
anthuny85's Avatar
06 c230 v6 SS
so frank those ultraleggeras 18x8 cleared the front brakes without a spacer?
Old Mar 26, 2008 | 01:38 PM
  #4737
Blake P's Avatar
'09 A4 S Line
done some search, and only looking on models, the prices not yet!
BBS ->CV or other....
My 18x8/9" BBS RG-R's are just under 20 pounds each.
Old Mar 26, 2008 | 05:47 PM
  #4738
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yup they clear without spacer
Old Mar 26, 2008 | 05:56 PM
  #4739
gaiex's Avatar
Is there more pics of those cars members here?! I never noticed them before
Old Mar 27, 2008 | 04:52 PM
  #4740
tozfeekum's Avatar
Hey guys so i just bought amg rims:
SPECS:
FRONT: 18"x8.5" ET30 offset
REARS: 18"x9.5" ET33 offset
i read on here that it should be fine, do i need any spacers?
Thanks for all the help!
Old Mar 27, 2008 | 05:00 PM
  #4741
Blake P's Avatar
'09 A4 S Line
SPECS:
Those should work just fine. Let's revisit if you decide to get coilovers and drop it extremely low.
Old Mar 27, 2008 | 05:17 PM
  #4742
tozfeekum's Avatar
Thanks for the quick reply blake, one more question on tirerack the tire sizes are: Front: 255/40-18 Rear: 285/35-18. Will that fit?
Old Mar 27, 2008 | 05:19 PM
  #4743
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
225/40/18 front and 255/35/18 rear.
Old Mar 27, 2008 | 05:22 PM
  #4744
Blake P's Avatar
'09 A4 S Line
Though I had some rubbing with wide 255 Pirelli's and had to switch to 245's, but that's just because of how low my car is and how wide/square the Pirelli's are cut.
Old Mar 27, 2008 | 05:36 PM
  #4745
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
New Wheels!
I finally got my wheels in. Sorry for the bad quality pictures it was off my camera fone and it is snowing out here so I just layed them next to my car to see how they would look in my garage. I'm pretty happy I bought the bright satin finish on these wheels because it totally sets my car off. Ill update with new pics off a better camera when I put these on next week or as soon as it gets warmer out. Tell me what you guys think!
Attached Thumbnails W203/CL203 Aftermarket Wheel Thread - All you want to know-0327081711.jpg
Old Mar 27, 2008 | 06:01 PM
  #4746
tozfeekum's Avatar
Thanks, which do you recommend Falken Fk452 or Toyo Proxes T1r?
I guess falken it is
Old Mar 27, 2008 | 06:02 PM
  #4747
Blake P's Avatar
'09 A4 S Line
Both are great tires, but I'd go with the 452's because their treadwear rating is slightly higher (300 vs 280). All comes down to preference though.
Old Mar 27, 2008 | 06:25 PM
  #4748
kevblah's Avatar
E90 M3
i like em! whered u get them from?
Old Mar 27, 2008 | 06:31 PM
  #4749
rlee02135's Avatar
2004 C32 ///AMG
looks good! ASA ST4?
Old Mar 27, 2008 | 06:32 PM
  #4750
JRAMGV8's Avatar
1999 C280 Previous / 2008 E350
Looks good
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
