View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#5001
'09 A4 S Line
#5002
1 Post
E320, C230 Coupe, SLK350
Thanks Blake...![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Your best bet is contacting a vendor who sells them. Neal @ Euroteck should know, as he's sold a ton of them over the years to guys on these forums. info@euroteckmotorsports.com
#5003
'05 C230K SS Granite Grey Metallic
#5004
'09 A4 S Line
It varies by wheel, based on lip size, spoke thickness and design. ET32 on an 8" wheel is much different than ET32 on an 8.5" wheel. Also, VS-XX have fairly straight spokes, which reduces caliper clearance.
#5005
Thanks Blake, that's why I'll never be comfortable buying new wheels with all the x-factors. Waiting for the right used set that were run on a Sport Sedan so all of the leg work for clearance has been done.
#5006
Now: '04 C320 Evolution Coupe Previous: VW GTI 1.8T
the superleggera was sold...well wondering about bremmas....will bremmas on a w211 with et32 and et35 work with my coupe....will the lugs be the same length.....
also where can is a good place or site to get spacers and longer lugs if i have to...well i kno ill need 5mm spacers in the front....i need 5mm hubcentric spacers
Those superleg you look'd at has the Audi hub ... I was looking at them too :P
so you didn't miss anything
#5007
2012 CLS63
#5008
I don't have coilovers, im actually running on stock suspension.
I thought with a +32 i would be good too, I really didn't want to use spacers, but these wheels were a biotch to fit. the VS-XX have 3 different center disks, the A, O & R disc, R being for cars with a BBK. I talked to WORK Japan and WORK USA before purchasing and both didnt know exact offsets as to make it fit perfectly. I even tried on a set of these wheels with the regular center disc and a +27 offset, it not only stuck out about an inch, it didnt even clear the brake. These wheels are custom made in Japan and they told me they fit them to a 2005 C230K SS out there, but they said the brakes are a little smaller, thats why i had to use a spacer... I don't know if thats true or not. Im not too fond of spacers, but i haven't had any problems so far....
Roland
#5009
'09 A4 S Line
Hey Erin,
Roland
Roland
#5010
'09 A4 S Line
If you lowered your car, the negative camber would make the wheels look more flush with your fenders. ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
FYI - My coupe has 35 offset with 12mm spacers in front (8" wide wheels), which means I'm running 23 offset and the wheels sit perfect with the fenders.
#5013
'09 A4 S Line
#5016
I just asked about the vs-xx wheels i tried on before, i was mistaken, they were a +24 and we had to use a 10mm spacer just to get it to sit right around the bbk, brought it down to a +14, thats why they stuck out so much. I guess it all has to do with the center disc of this wheel....
anyways i attached one last pic with a ps'd drop...
enjoy and thanks for all the good info in this thread...
#5017
'02 Tacoma, '08 GT3 RS
255/35/18 rear fitment on C230 Sport sedan?
Anyone have any info on the 255/35/18 rear fitment on a 2005 C230 sport sedan? Also will this tire work on an 8" wide wheel?
Thanks!
Thanks!
#5018
05 C230SS
hey guys,
got 19x9.5 for rear and 19x8.5 for front
got 235/35 front and 265/30 for rear (not lowered).As dirty as this will sound but I'm rubbing with three passengers in the car when I go over small bumps etc just want to know is this normal and can be avoided if I get smaller size tires and or COs?
#5019
01' C32o
hey guys,
#5020
C300. FJ Cruiser, 370Z
#5023
#5024
2006 S203 C280 T
Anyone got the BBS CV on his W203 and can show some pictures please?
I'm talking about these rims:
http://www.vivaperformance.com/catal...es/bbs_cv5.jpg
I want to get them on my 2006 C280 station wagon, but I'd like to see "real life" pictures first...:-)
Thanks so far!
Thanks so far!
#5025
'09 A4 S Line
Thanks so far!
Thanks so far!
