View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Aug 13, 2009 | 06:40 PM
  #6451
Giorgiojustini's Avatar
2002 c32
Originally Posted by FrankW
BBS has engraves of their part # and spec on the front.
that's a steal for a set of RS-GT. what car did it came off from?
I believe they came off a c230
Old Aug 13, 2009 | 06:42 PM
  #6452
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
cool
in any case they don't clear the caliper you can contact BBS USA and ask them for the 5mm PFS which is a spacer kit with bolts.
hope the seller give you the bolts too. they should have the BBS-RAD bolts.
Old Aug 13, 2009 | 06:51 PM
  #6453
2002 c32
cool
Thanks for the info. Seller did not provide any bolts. Can I use stock bolts if no spacer is needed?
Old Aug 13, 2009 | 06:52 PM
  #6454
Glocker's Avatar
04 Mercedes Benz C230K
Thanks for chiming in Frank. Good deal it's not the BBS LMs then. That's a dam steal! BBS RSGT
Old Aug 13, 2009 | 06:57 PM
  #6455
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
you can't use stock bolts. the bolts needed are much shorter. I would suggest contact BBS for the bolts then. or search for RAD bolts.
i have the normal length RAD bolts for my RE set. I'll measure it and let you know the length.
Old Aug 13, 2009 | 07:10 PM
  #6456
2002 c32
Your one hell of a dude, thanks!
Old Aug 14, 2009 | 04:31 AM
  #6457
joyofcola's Avatar
E320, C230 Coupe, SLK350
Hey giorgiojustini where did u find such a great deal on those bbs??? and do the linea corse LM even come in a mercedes application???
Old Aug 14, 2009 | 10:17 AM
  #6458
2002 c32
I found them on craigslist. Im not sure about the linea corse LM's.
Old Aug 15, 2009 | 01:30 AM
  #6459
roland w203's Avatar
Linea Corse Lemans comes in the MB application. I actually have a brand new set that I'm thinking about selling 19x8.5 all around with 35 offset.
Old Aug 16, 2009 | 12:00 PM
  #6460
LightDragon's Avatar
w203 M111 E20 ML EVO
17 vs 19
225/45/R17 + 245/40/R17 Vs 225/35/R19 + 245/30/R19
I think 17 has a smoother ride and more cornering handling but 19 looks hotter and sits lower with eibach springs, any opinions ? and shall i use 255 instead of 245 on the 19 ?
Old Aug 16, 2009 | 12:41 PM
  #6461
AnimC32's Avatar
C32 AMG
I am planning on upgrading my stock 17" 03' C32 wheels to 18" (would be the C55 stock wheels(most likely) or CLK 500 18" Style III's). I want to lower it with these Vogtland Springs: http://tinyurl.com/p3xej6 . As for shocks and struts I want to upgrade to Bilstein Sport Shocks/Struts - http://tinyurl.com/pm5av6 and http://tinyurl.com/pfa6kn
Any extra parts I need to get? Fitment issues? Can I install springs and shocks/struts with the stock 17" wheels while I hunt for wheels? Thanks in advance!
Old Aug 16, 2009 | 04:31 PM
  #6462
XsuperbeeX's Avatar
C320 coupe
dont create another thread... should have post on the wheel thread... wait for frank to reply...
Old Aug 16, 2009 | 04:47 PM
  #6463
Midnight Koop's Avatar
CL203
+1... where is frank when you need him
Old Aug 16, 2009 | 05:05 PM
  #6464
frank is the master of suspension ? ;p
Old Aug 16, 2009 | 07:49 PM
  #6465
NegroC230's Avatar
08 ML CDI
anybody running 10" wide wheels in the back?
Well, finally after researching which wheels to go with , i got shot down Lorenzos WL18 are discontinued and 4 wheel stores that were carrying them, dont have any pieces left for me to even put a set together. Anyway , over the weekend i found a local used set of similar looking wheels, only problem is , they are 10" wide in the back with 45ET , i hope 5mm spacer will fix the problem , becasue without it the wheel is touching inner side of the wheel well. Quick question Benz peeps, the seller states that these are MB custom made, what vehicle were they made for? W203/CL203 Aftermarket Wheel Thread - All you want to know-wheel.jpg
And ofcourse , they will be fixed up powder coated black, including lips
Old Aug 16, 2009 | 08:59 PM
  #6466
ChokuDorian's Avatar
c230
wow. i literally have another tab open right now deciding to buy the wl18 or not...i guess that a not.
https://mbworld.org/forums/c-class-w...de-thread.html
starting post... hes running a fat tire too. but didnt give offset.
i would think 5-10mm would fix you up.(if there is an issue at all) but then you will be about 5-10 mm further out than a 9.5+35
Old Aug 16, 2009 | 09:30 PM
  #6467
c230
bigger sidewall will always have better ride.
what widths and offsets? how low are you, do you have room to run 255? the more you stagger your tire size the more your car will want to understeer, generally. idk of any reason you should switch from 245-255...unless you just want to
did you use same brand/model tires on 17's and 19's?
Old Aug 16, 2009 | 10:19 PM
  #6468
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
been there done that.
19x8.5 et28 and 19x10 et35. Carlsson 1/16 BE. one you posted are replicas of the 1/16.
about the same as my LM 19x9.5 et27 rear.
request sent to have this merged with the wheel thread.
Old Aug 16, 2009 | 10:41 PM
  #6469
NegroC230's Avatar
08 ML CDI
ohh ****..those are carlsson replicas then ...nice
Old Aug 16, 2009 | 11:02 PM
  #6470
advans's Avatar
C55 ///AMG, 535xi
^ no.... not really, the reps doesnt have that CARLSSON written all over, which is the hottest part OF the wheels
Old Aug 17, 2009 | 12:17 AM
  #6471
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
some reps used to have letters too, but they spell out "CARLLSON"...
I rather have reps with no letters and run the MB caps then reps with idiotic letters "i.e. AMC, Carllson...
Old Aug 17, 2009 | 02:39 AM
  #6472
XsuperbeeX's Avatar
C320 coupe
Old Aug 17, 2009 | 03:58 AM
  #6473
W203E35's Avatar
2006 C350 Sport 6MT
hahaha wtf? I would laugh my *** off if I saw someone with Carllson wheels. I would literally point and laugh.
Save yourself the humiliation and stick with the stock wheels lool
Old Aug 17, 2009 | 04:10 AM
  #6474
on 17 its the amg 5 star , 19 i vote for bremmas tsw
Old Aug 17, 2009 | 05:00 AM
  #6475
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i say get 19's, the c200 is already slow so might as well look good.
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
