View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Jul 10, 2011 | 03:43 PM
  #6901
phister's Avatar
06 C230 SS 6spd
Originally Posted by MBullock
Ok Ok...found some wheels with these specs
18x8.5 +32 front
18x9.5 +30 rear
Can I fit these on an 05 C230K SS? I don't plan on lowering the car at all, but I'm mostly concerned if whether or not the fronts are too wide and if the rear offset of +30 will work.
Also, recommend tire size? I was thinking 225/35 and 245/35 for a little bit of stretch.
TIA
actually your fronts offset might not be low enough depending on the design of the wheels. You have to consider them fitting over the sport calipers you have. The rears will be ok with that offset. Most people get 8.5 front and 9.5 in the rear when they upgrade wheels.
As for tires I would go with 225/40/18 and 255/35/18 but you can also go with 235/40/18 front and 265/35/18 in the rears. just depends on how much meat you want on your wheels.
Old Jul 27, 2011 | 12:17 AM
  #6902
glocati's Avatar
2016 GLE 350
Bremmerkraft BR05's
Staggered - 18"x8" - 32 ET front 18"x9" - 35ET rear.
Attached Thumbnails W203/CL203 Aftermarket Wheel Thread - All you want to know-benz-003.jpg   W203/CL203 Aftermarket Wheel Thread - All you want to know-benz-014.jpg   W203/CL203 Aftermarket Wheel Thread - All you want to know-benz-006.jpg   W203/CL203 Aftermarket Wheel Thread - All you want to know-benz-013.jpg
Old Jul 27, 2011 | 09:04 AM
  #6903
phister's Avatar
06 C230 SS 6spd
Looking good glocati! Always love the concave look. One of my fave wagons on here.
Old Jul 27, 2011 | 01:00 PM
  #6904
glocati's Avatar
2016 GLE 350
Thanks phister ! In turn, i am a big fan of your sedan
Old Jul 27, 2011 | 02:49 PM
  #6905
phister's Avatar
06 C230 SS 6spd
Thanks... I guess we both went away from the panda look lol
Old Jul 27, 2011 | 04:11 PM
  #6906
glocati's Avatar
2016 GLE 350
That's funny. i always called it the storm trooper look.
Old Aug 23, 2011 | 01:43 AM
  #6907
lepez's Avatar
CLS320cdi, GL350BT, ML270cdi
I'm in doubt, I'm looking at a new set of wheels, but don't know if I'll be able to run them in the back ...
front :8,5jx18 et 35
rear : 9,5jx18 et 40
I'm guessing front is no problem at all, but for the rears, I'm not sure.
would I need spacers on that or not ?
grtz
Old Aug 23, 2011 | 03:28 AM
  #6908
phister's Avatar
06 C230 SS 6spd
grtz
Lowest I'd go on offset is +35 maybe +38. You can always buy 5mm spacers just in case. But I'd test fit the wheels first. Since you have larger front brakes +35 might be close depending on how the wheel is designed. I had to get 10mm spacers in front even though my offset was +30. If you can, test fit the wheels first.
Old Aug 24, 2011 | 06:06 PM
  #6909
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
Anyone know how long the rear hub is? how many mm's it sticks out?
thanks!
Old Aug 25, 2011 | 04:33 PM
  #6910
shcctx's Avatar
CLK 430
Rubbing Issue
Originally Posted by jac1502
Got the wheels on all the way now have some rubbing in the back though any thoughts what it could be? I will take the wheel off in a few days and see if I find any wear marks. The wheels are ruff 19 8.5 235/35/19 front and 19 265/30/19 rear 35mm offset with 5mm spacer all the way around with stock suspension. Not sure if it needs lowered or not yet.
Take off rear wheels, check the plastic wheel well liner rubbing against tire, you can trim with razor blade, put wheels back on and see if it's gone.
Old Aug 26, 2011 | 03:48 AM
  #6911
phister's Avatar
06 C230 SS 6spd
Most common area where it rubs is where the rear bumper and fender meet. Sometimes the tires will rub against the bracket on the inside. A little fender rolling will get rid of it. I've also noticed that the plastic tabs holding the inner liner will sometimes make contact but that's usually on lowered cars.
Old Aug 31, 2011 | 11:24 PM
  #6912
SkankZ's Avatar
2006 C230 SS
You guys want to help me choose my next set of wheels!?
It will have to be from HRE 560 collection.
560C
563C
565C
567C
It'll be going on this
I'm leaning heavily towards the 560 and 563 in second, but i'd like others opinions.
Old Aug 31, 2011 | 11:36 PM
  #6913
ahmadk's Avatar
2011 E550 Sedan
560C
563C
565C
567C
560 or 567 .... but 560 more
Old Aug 31, 2011 | 11:47 PM
  #6914
phister's Avatar
06 C230 SS 6spd
i like the 563C
Old Sep 1, 2011 | 12:37 AM
  #6915
SkankZ's Avatar
2006 C230 SS
@phister: yeah! i was thinking that one also because my past 3 wheels were all mesh. As much as i love mesh wheels.. i thought about getting something different this time. Although, I'm not really sure if it would look right on a w203. I need to see it first Seeing is believing!
Thanks for the replies guys.
Old Sep 1, 2011 | 02:26 AM
  #6916
ROLLNNN's Avatar
are you only choosing from HRE?
did you sell your vs-xx already?
Old Sep 1, 2011 | 03:01 AM
  #6917
SkankZ's Avatar
2006 C230 SS
sadly yeah. I guess i couldn't stand having the fronts sticking out too much!
long story short, i ended up with a set of HRE for dirt dirt cheap but i needed to replace 2 of the faces. HRE is willing to replace the faces for me but with the 560 series for a discounted price and using my existing wheel halves(inner/outer lip).
Old Sep 1, 2011 | 04:10 AM
  #6918
C350_Coupe's Avatar
C350 Coupe (CL203)
<SNIP...>
567C
Old Sep 1, 2011 | 07:08 AM
  #6919
snacks's Avatar
2006 c230
i'm biased towards the 563c
Old Sep 1, 2011 | 08:33 AM
  #6920
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
another vote for the 563c. me like multi-spokes.
Old Sep 1, 2011 | 02:19 PM
  #6921
ROLLNNN's Avatar
in that case i would go with the 560
Old Sep 1, 2011 | 02:31 PM
  #6922
SkankZ's Avatar
2006 C230 SS
Now that I've been thinking it over. I think I might go with the 563. I googled the wheels on actual cars and I think the 563 looks better than the 560. In the picture I showed you guys it looked nice but real pictures it look okay.
Now! Brushed aluminum finished or the cliche gunmetal on silver combo!
Old Sep 1, 2011 | 04:22 PM
  #6923
phister's Avatar
06 C230 SS 6spd
the 563 have a more aggressive look IMHO. just looks sportier, I always like brushed aluminum over gunmetal.
Old Sep 2, 2011 | 01:41 PM
  #6924
C350_Coupe's Avatar
C350 Coupe (CL203)
does anyone know the brabus part numbers and details (sizes etc) that i should be using for my monoblock VI's on my 2005 C Class post facelift Coupe ?
Front alloy wheels: 18x8.5"
Wheel part number: BRA 61285835RDK
Rear alloy wheels: 18x9.5"
Wheel part number: BRA 61295835RDK
Old Sep 2, 2011 | 07:29 PM
  #6925
SkankZ's Avatar
2006 C230 SS
So I'll have details by next tuesday! HRE gave me a really good deal on new faces + paint. Now they're just checking the wheels if the barrels are crack or bent.
I'm going with 563 with a brushed aluminum finish. I would love the 560 but i think i'll try something different, since i've always gotten mesh wheels.
Now for tires?? It's going to be 18x9 et 37 all around. I currently have a set of 4 245/45/18's. I guess I can use them for the back? But for sure it's impossible for the fronts!
What should I get for the fronts?
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
