Sway Bar end link broke... can I remove it and drive until tomorrow?
Old Aug 7, 2008 | 04:16 PM
RedC230K's Avatar
'04 Mars Red C230K 6 sp.
If I take it easy and remove the link temporarily, can I drive the car until the part comes in tomorrow?
Cheers,
JB
Old Aug 7, 2008 | 04:47 PM
amanonfire's Avatar
W203
Yes.
You don't technically "need" a sway bar, yet your car will not perform well in corners as the sway bar balances load and controls body roll.
Avoid aggressive cornering.
Old Aug 7, 2008 | 04:53 PM
RedC230K's Avatar
Gotcha. Thank you!
Old Aug 8, 2008 | 07:16 AM
JLD2k3's Avatar
2002 C320
Keep in mind the stiffness of the end you take the link off of will decrease significantly. If you are talking about the front, then you'll be likely to spin out; lots of understeer if you're talking about the back. Like amanonfire said, take it easy, especially if it's wet.
Old Aug 8, 2008 | 11:10 AM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Actually in the wet, I would be inclined to think you could get more traction. No sway bar would allow the car to "Load" on the outside. Thus more grip.
I would undo both sides, and insure that nothing is going to get banged on.
E
Old Aug 8, 2008 | 01:00 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
E
I concur with Ed.
Last thing you want is the swaybar moving up and down to possibly knock something else loose and even worse, until it eventually falls off and causes a road hazard for other motorists
Old Aug 8, 2008 | 03:19 PM
JLD2k3's Avatar
2002 C320
E
You're right about that for the end where the sway bar is taken off. What I'm saying is the difference in stiffness between the front and back can cause the car to either spin (lots of grip up front, little in the back) or push (lots of grip in the back, little in the front) when only one sway bar is in place.
Old Aug 8, 2008 | 06:21 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it'll be like driving a old *** Caddy.
Old Aug 9, 2008 | 09:02 AM
RedC230K's Avatar
I only drove short distances and now have the part in hand, so I can install it today. Thanks to all for the advice!
Old Aug 9, 2008 | 01:17 PM
drexappeal's Avatar
glad it worked out with no issues. while u install or have it installed, I suggest checking everything else, just to be sure. u want to make sure that no excess stress was placed on other parts of the suspension.
Old Jan 23, 2014 | 07:24 AM
CHolmes's Avatar
2000 E320
I really don't think you'll be "likely to spin out" unless your Sterling Marlin of course, in fact I bet you never notice the difference, I have a W210 and the bar itself is worn on the end, I took it off until I can find one, noooo noticeable difference. Oh there was that one time I was doing 140 on the slalom course.
