Wow Check engine light
Old May 27, 2009 | 08:03 AM
  #101
auteck's Avatar
2002 C240
Get those codes and post back in here so we can help you.
Old May 27, 2009 | 10:54 AM
  #102
Glyn M Ruck's Avatar
Super Moderator
Yeah - pull codes. We seem to be having a spate of wire problems on V6s - FrankW's C32 had wire problems the other day.
Old May 28, 2009 | 05:44 AM
  #103
batman6's Avatar
c32
okay bought the odb reader today. I tried to look for the plug to plug it in and couldnb't find it....I thought it was under the steering wheel...I can't find it all i found was a small amp that was held underneath by 2 torx screws. hmmmm....
Old May 28, 2009 | 08:09 AM
  #104
auteck's Avatar
2002 C240
You are not going to find the plug under steering wheel exposed, it has a small black plastic door that you need to open in order to gain access to the plug. Just look very well in that area and you will find it.
Old May 28, 2009 | 10:52 AM
  #105
Super Moderator
Small oblong hinged door
Old May 28, 2009 | 03:30 PM
  #106
batman6's Avatar
c32
thanks guys found it...well post codes in a min...
Old May 28, 2009 | 03:44 PM
  #107
batman6's Avatar
c32
okay...so stupid the obd reader I bought is missing the adapter to plug in my car. I must of bought one where someone stole the plug. gosh...btw glyn M ruck is it okay to drive the car when it's having this problem right now? i was thinking of just driving it to my mechanic to get him to give me the codes.
Old May 28, 2009 | 04:56 PM
  #108
Super Moderator
If fluid levels & temperature is OK you can drive it. Just don't do a 1000 mile trip.
Old May 28, 2009 | 06:51 PM
  #109
batman6's Avatar
c32
got the code it's po302-Cylinder 2 misfire. now what should i do next? keep in mind i'm no mechanic. and i'm not familiar w/ the internals.lol
Old May 29, 2009 | 05:19 AM
  #110
Super Moderator
Swap No 2 wire & coil with another cylinder. Mark them so you don't get confused. Cancel codes & go for a run. If the code changes cylinder then you know it is the wire/coil. If so - replace
Old May 29, 2009 | 06:11 PM
  #111
batman6's Avatar
c32
do you know if the coil/wire is on the left side of the engine or the ride side? also how do i even take the coil out? sorry for the stupid questions!
Old May 29, 2009 | 08:18 PM
  #112
Super Moderator
The coil packs are mounted on the cylinder head covers (rocker boxes) on either bank of the engine with wires going to 2 plugs per cylinder.
Attached Thumbnails Wow Check engine light-c32-coils.gif   Wow Check engine light-c32-engine2.gif
Old Jun 1, 2009 | 10:48 PM
  #113
batman6's Avatar
c32
i can't seem to get the spark plug wire off. anyone have any advice or tips to take em out i bought a spark plug wire plier but it doesn't seem to work. the plugs are just on too tight.
Old Jun 2, 2009 | 12:03 AM
  #114
batman6's Avatar
c32
okay loosen up the coil parks but I found this...is this bad? most of the oil i saw was on the left side of the engine.....see pic
Old Jun 2, 2009 | 01:15 AM
  #115
batman6's Avatar
c32
okay swapped the first 2 coil packs on the left side of the engine and tested it with the obd reader, it reads O. I started up the car and it sounds fine but there's shaking like something bad is going to happen. ANyways if the OBD reads Zero i'm guessing it's not the coil packs? what should I do now. should swap back the coil packs to the right places and then test with OBD reader again?
Old Jun 2, 2009 | 09:22 AM
  #116
Super Moderator
Drive the car for a few days & see if a misfire code returns and at what location. Those oil leaks are pretty common. Need new rocker box cover gaskets.
Old Jun 2, 2009 | 07:58 PM
  #117
batman6's Avatar
c32
code returned. it now reads po301 -cycliner 1 misfire. gonna replace the coil pack and that should do the trick. should i just replace all the spark plugs while i'm at it?
Old Jun 2, 2009 | 08:54 PM
  #118
auteck's Avatar
2002 C240
You still need to replace the valve cover gaskets (I did a year ago) you don't want all that oil dripping down on the spark plug wires, exhaust, etc... I would replace the wires and plugs as part of regular maintenance, then check the coil packs after that.
Old Jun 3, 2009 | 01:07 AM
  #119
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
replace the seal for the rockerbox gasket.
and you missed a "0" in your profile.
Old Jun 3, 2009 | 07:01 AM
  #120
batman6's Avatar
c32
anyone have a DIY on how to replace the seal for the rockerbox gasket?
Old Jun 3, 2009 | 08:19 AM
  #121
skittles's Avatar
Moped
quick question since you guys are talking about plugs. i just did a major tune-up on my car, oil change, tranny service, fuel filter, cleaned MAF, cleaned K&N filter, switched to NGK iridium spark plugs, old ones were bosch, replace battery, replace suspension bushings.
My car is a 2003 c230 sedan 75k miles.
my question: i used to get 23mpg to 27mpg. now i get 16mpg at idle and 19 city and 26 freeway. what could have caused this? spark plugs? MAF? or fuel filter? those are the only possibilities i could think of..
Old Jun 3, 2009 | 10:53 AM
  #122
Super Moderator
Good - I would replace 1 coilpack, all wires & plugs & do rocker gaskets. They are not leaking badly - a nip up might help them but you are delaying the inevitable. Good Luck
Old Jun 3, 2009 | 03:16 PM
  #123
batman6's Avatar
c32
by wires do you mean the ones connected to the coilpack and then to the spark plug part no. 17 on that picture you gave me? if that's the case my dealer quoted me about $70 per wire. WOuld that mean I would have to replace all 12 connector wires? that would be about $840!! again anyone have diy on replacing the gasket?
Old Jun 3, 2009 | 04:38 PM
  #124
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
16mpg at idle? I get 0mpg sitting still.
How long has it been since you did this service and how many tanks have you noticed be this much worse?
Old Jun 3, 2009 | 05:29 PM
  #125
auteck's Avatar
2002 C240
Stay away from the dealer for spark plugs and wires. Go to Napa and ask for Bosch replacement wires for your car. The cost about $18 each and they look just like the originals except they don't say Mercedes on it or have the star.
