Alarm Beep For C-Class?
02 C320 Sedan
Good Day Everyone,
I was wondering if there is any type of beep that the alarm makes when you hit the lock button on your key fob?
Is it something the dealer has to do?
you have to get it programmed. Some dealers might know how to do it, ask the tech at your dealer, he should know... Netherlands setting gives you the chirp but gets rid of the Panic feature. There is one setting that allows you to keep the panic, not too sure what setting it is though.. I have the Netherlands setting on mine, i don't think panic button is too important...
02 C320 Sedan
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Super Moderator Alumni
My dealer said that if they where hooking me up to computer anyway, they would do it for free.
02 C320 Sedan
Just wish it made a beep =/
If you don't plan on getting service at the dealer anytime soon, you can also try TWS, HMS or any Mercedes specialist with the star diagnosis system. I'm pretty sure none of these places will charge you that much...
It's been so long since I've been to the dealer...it was $106/hr. at MBLN last time.
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
or get some work done on your car next time MBenzNL comes to Cali.
As an added feature request some programming.
He can set the "Netherlands Setting" alarm beep and keep your PANIC feature active too.
That's what I have on both of my C-Classes.
That can only be done on his special version engineering version of DAS.
US MB dealers won't know how to do that.
Carlos
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Saprissa@aol.com
2003 C320 Sport Coupe
2004.5 C320 Sport Sedan
Carlos
Saprissa@aol.com
Is @ Home
Talk to one of the techs and make a deal with him *hint hint
Thats how I got my xenons set.
I think it is the US Buzzard that enables the beep and panic.
it depends on the year of W203 model.
Kris needs to update his profile on the left with YEAR of his C320 and model type (Coupe / Sedan).
Carlos
Saprissa@aol.com
- pre 2004.5
- facelifted 2005+
- 2007
Carlos
Saprissa@aol.com
MBworld Guru
white and whiter
i only paid $60 at a local MB shop to enable the netherland setting and the NAV menu. too bad they didn't know how to enable the fuel content or i would've done that as well.
I had my local MB dealership program the netherlands setting while it was in for an issue, and they didn't charge me anything. My panic feature still works as well. But here's the deal:
There are 2 types of beeps. A slower mellower beep, and a faster sharper beep. If you search for Netherlands setting, there are some threads that go into quite a bit of detail, with some video clip links. Or you can also search youtube for "netherlands setting."
I preferred the slower beep, but ended up with the faster one. Not sure if each car is coded to be able to choose which beep you want or not, but my thinking is that the older model vehicles from 2001 to early 2005 have the only the slower beep while the newer 2005 to 2007 models have only the faster beep. In fact, the loaner C's that I've had were all 2006 and 2007 models and all of them have the faster beeping. My car is a very late build 2005, having been built in Bremen with a date code of 04/2005. 2006 models started being produced in 05/2005. So, because it's so close to a 2006 model, mine has the faster beeping. Can anyone substantiate this?
BTW, my dealer also wasn't able to figure out how to enable the fuel gallons remaining feature.
Cintoman
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
02 C320 Sedan
How come some places have different productions options available? Did they figure that ppl in the US didn't want there car to make a beep sound?
Because its starting to sound like there are a lot of goodies that need to be enabled =/
That's sweet! Wow, I've got a list of things for my Dealership to do if I go back to them. This fuel setting is def. one of them as well as turning off the "NO PHONE" in my MFD. I've got all that Teleaid in my car, you know, the buttons in center arm rest, the SOS button, but none of it's hooked up. Why would you have all of that junk in the car, yet not have the COMAND or even a CD player?!
02 C320 Sedan
EDIT: Sorry, I didn't address your other remark. You can press those buttons, but nothing will happen if you don't have the phone system set up. It will state in the MFD that it is trying to call, but won't go through. Even pressing the "SOS" button won't go through, however though, you will get a loud beeping noise after the Teleaid attempts to connect and fails.
Super Moderator
Not quite sure what you mean by motion sensors for the windows? I know that there is a Motion Sensor alarm that you can install in your car, I believe someone here on the board did it and did a write up on it. The only other thing I can think of that you may be talking about is the opening and closing of the windows using your key fob?
The alarm is standard fitment in South Africa & even locks up the transmission. If you don't have the key then the only way to steal the car is to pick it up & put it on a truck etc. Car theft is more of a problem here than the US
Super Moderator
We don't have the chirp enabled here or the panick button. I don't have a clue how they decided on what to have for which markets
02 C320 Sedan
Do you have the panick button on your key fob? Kinda dumb if you ask me that they choose like that. Or why make them different for each market
Super Moderator
