MFD Multifunction Display Fading!!!
Old 02-28-2009, 10:45 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
Originally Posted by AzCamel
is the mileage store in the cluster or ecu? can i jsut replace the cluster without reprograming or throwing a code? and stupid question but i love the 05+ gauges, any hope that they will just plug and play?
u can get W209 cluster from MBenzNL
Old 02-28-2009, 10:52 AM
Super Moderator
Glyn M Ruck's Avatar
Is it a direct fit in the W203 - No mods required?
Old 02-28-2009, 11:40 AM
valexv's Avatar
02 cl203
it fits but the programming is still the issue
Old 02-28-2009, 11:00 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
it fits and all the electronic still work? i just nee to go to the dealer to switch the mileage
Old 03-01-2009, 08:09 AM
valexv's Avatar
02 cl203
programming i think is a grand or so, and switch DAS or MOST, which is replacing alot of stuff including your center console and steering wheel and other things. Simply put if not ready to drop a few grand don't think about. this is for 01-04 switching to +05 or the w209 cluster. I thought about it once, long time ago and moved on. I rather spend the money with other things. If you want more info search the MOST to DAS or whatever it is by Sunil (on board is his wither SUNILP or SUNMAN), he made a thread covering it.
Old 03-01-2009, 01:00 PM
acr2001's Avatar
2012 C300 4Matic
Thumbs down
Are you taking about D2B and MOST? That's the fiber bus. The cluster does not use the fiber bus. I believe you are partially correct about needing to upgrade one of the communication buses but D2B / MOST has nothing to do with it.
Old 03-01-2009, 02:16 PM
  #32
AzCamel's Avatar
well forget this mod,, lol..
Old 03-01-2009, 03:06 PM
  #33
Super Moderator
Sounds like a train smash!!
Old 03-01-2009, 06:17 PM
  #34
valexv's Avatar
02 cl203
well 2 years ago when i was thinking about it that is what i kept hearing, like i said search for sunil and even a couple of months ago someone was asking and that was the verdict
Old 03-02-2009, 11:52 AM
  #35
Super Moderator
MJ50's Avatar
bone stock E55 AMG
just a minor mod on IC bracket and lots of coding...
Old 03-02-2009, 11:54 AM
  #36
Super Moderator
MJ50's Avatar
bone stock E55 AMG
yes.
just drive to SoCal and u'll have installation and programming (including transferring the mileage) taken care of by MBenzNL
Old 03-02-2009, 11:56 AM
  #37
Super Moderator
MJ50's Avatar
bone stock E55 AMG
pre 05 CLKs used D2B although the cluster looked just like 05+ W203 and W209. thus, the retrofit is pretty easy.
sunil went nuts and converted D2B to MOST.
Old 03-02-2009, 01:57 PM
  #38
Super Moderator
Thanks - Most informative.
Old 04-27-2009, 09:29 AM
  #39
tommy's Avatar
2004 Civic Si. FWD for the Win!
Yes, I am bringing this thread back from the dead.
I was curious - has anyone sent their cluster to BBA to get the work done on it? Just started to warm up here, and my display is getting even worse than it was last summer. If someone could post up their experience, I'd appreciate it, before I send mine off. Thanks.
Old 04-27-2009, 09:36 AM
  #40
MBworld Guru
FrankW's Avatar
white and whiter
only heard about BBA when someone mentioned it last time. probably cost the same as you getting a used cluster and swap out the screen?
Old 04-27-2009, 10:06 AM
  #41
tommy's Avatar
I know that valexv got a used cluster off ebay for $50 (I think); hard to come by, though - did look every so often. My hope is that BBA would put a new screen in for that $225, which should work longer than me putting in a used one. I'm going to have to call BBA and try to find out exactly what they do; I know when I talked to them last year, they were vague about what they actually do.
Quick Reply: MFD Multifunction Display Fading!!!
